Transponder problems with ATC COMS - Video
Old November 25th 08, 06:59 PM posted to rec.aviation.owning
A Lieberma[_2_]
Default Transponder problems with ATC COMS - Video
On Nov 25, 10:59*am, "Robert M. Gary" wrote:
or asking a CFI. Its not fair to require 5
to 10 hour checkouts in every 172 just because some pilots will not
otherwise learn the avionics specific to the aircraft.
-Robert, CFII
Agree. Responsibility should be on the pilot for learning AND asking
a CFI for assistance on operating the avioncis so I see what direction
you are headed. It ultimately resides on the PIC for the safe outcome
of any flight which includes insuring they know how to handle the
avionics.
While I said rental, I kinda was really thinking more along the lines
of initial training that showing how to disable mode C. It did not
come out that way in my original post, my apologies.
At least with that training in the initial stage, then at least the
pilot has a chance should he come across similar type of avionics.
I never got that kind of training. We talked about it in ground
school, but never applied that training. While it's impossible to
cover every situation, this one I would think would be a situation to
be considered in training. It doesn't add to flight time.
May seem simple and basic, but when you got a new pilot up in the air
and something like this happens, it only adds to the stress level and
with **some foundation** for course of action at least there is a hope
for "resolution of the problem.
Even for me, it was something out of the ordinary, and having to
"think quick on the feet" to come up with something was more then what
the pilot would have done as she didn't even know how to operate the
Xponder. It was always left in the on position, so I am not even sure
if she would have known how to turn it off WHILE flying the plane.
She did do what she was taught to do and that was fly the plane and
left it to me to fiddle with the buttons.
Once we got clear of KJAN approach and went on our own, she settled
down and thought things completely through and we were able to work
the problem at a pace more manageable.
Ultimately, the safe outcome of the flight speaks for itself even
though our procedure of the decision making process may have been
flawed. We just dealt with the cards we were handed the best we could.
Old November 25th 08, 10:22 PM posted to rec.aviation.owning
Morgans[_2_]
Ok, so if you come in and want to rent a C-172 but have never flown
with a 430 should I require you to do a 5 hour training course?
Apples vs. oranges, to me, with that comparison.
A fancy GPS is not necessary to fly VFR in _any_ airspace, while a
transponder is. (in some airspace)
I have to agree that a 5 minute, or even 10 minutes (if it takes that long)
lesson on the transponder should be included in a checkout.
Old November 25th 08, 11:40 PM posted to rec.aviation.owning
"Morgans" wrote in message
long) lesson on the transponder should be included in a checkout.
Sounds like about 4.5 to 9.5 minutes too long. Even a GTX 330 is not all
that complicated. Instead of a 4 position function switch, you have 4
buttons. Instead of 4 code knobs, you have 8 buttons. You have an ident
button just like any other xponder and a VFR button which resets to 1200.
All of the buttons on the right can be ignored for basic operation.
Old November 26th 08, 12:04 AM posted to rec.aviation.owning
Robert M. Gary
But I'm not going to bill for 10 minutes. I'll bill an hour minimum.
If a pilot is checked out to fly 172's already I'm not going to
require that he pay me an hour simply because one 172 has a different
type of transponder. Again, its up to the pilot. If he *wants* some
instruction then I don't mind giving it but I'm not going to drive
down for 1/6 of an hour. I guess I care about this because I see it as
a big issue in the future. Many have suggested requiring the (by the
FAA) pilots to have endorsements for every combination of avionics in
the airplane (including author Richard Collins, etc). Unless its the
G1000 plane, I'm going to leave it up to the pilot to decide if he's
able to work the avionics. BTW: About 70% of the pilots I fly with
with the G1000 are already familiar with it because they've studied
the manuals at home and run the simulator (or even gone to one of the
local weekend ground seminars). I assume pilots are doing similar with
othe types of avionics.
-Robert
Old November 26th 08, 01:35 AM posted to rec.aviation.owning
A Lieberma[_2_]
Robert,
I think the operative word is "included" in the checkout, not for you
to specifically come out and give training on the Xponder.
I don't see it being unreasonable to cross check with the pilot snf
ensure he knows how to handle the Xponder on a checkout on a C172.
Again, bottom line is it does fall on the PIC to ensure they know how
to operate the equipment and questions should come out during the
checkout, but an inexperience pilot may not think about the subtle
things that the CFI has in his tool kit.
G1000 is standardized and I am not surprised you are encountering
pilots who did their research when they know ahead what avionics is in
the plane, but there are a lot of C172's that are rented with a mish
mash of avionics.
Old November 26th 08, 03:14 AM posted to rec.aviation.owning
BT
No problems "A", I enjoy watching your Sundowner videos. I flew Sundowners
in the late 07s in Maine.
The older equipment is not so much easier to understand, but it's what "we
grew up with", you really want to have fun, take the full G1000 Course for
IFR operations. The transponder and autopilot are built into the system, the
transponder select codes are on the soft switches at the bottom of the pilot
side PFD and the code/reply lights etc are in a little window on the screen.
BT
"A Lieberma" wrote in message
On Nov 24, 11:38 pm, "BT" wrote:
I'm somewhat surprised, if the pilot is part owner and flies this aircraft
regularly, she does not know the operation of her transponder. She can
select STBY, ALT and put in the code, but she does not understand it's
operation.
A nice thing about those transponders.. the VFR button will automatically
load 1200.
Thanks BT for the informative posts. My plane doesn't have all this
fancy gagetry, so I was literally winging it on a prayer and things
just didn't add up in my head, thus shutting the Xponder off..
With all the nuances of learning how to fly, learning how to own a
plane, it does not surprise me she didn't know the operation of her
transponder. Her "lesson" was set it and forget it OR let it do
everything automatically.
If you think about it, at least for me, even in my flight lessons, I
never got any instructions on how to operate the transponder other
then coding in the numbers or doing "one button operations". Never
once was I ever shown how to stop Mode C operations.
Old November 26th 08, 06:24 AM posted to rec.aviation.owning
BT
That should be the late 70s.. not 07s.. fingers got ahead of themselves
BT
"BT" wrote in message
the transponder select codes are on the soft switches at the bottom of the
pilot side PFD and the code/reply lights etc are in a little window on the
screen.
BT
aircraft
operation.
load 1200.
Old November 26th 08, 06:25 PM posted to rec.aviation.owning
Robert M. Gary
Generally if a pilot is signed off to fly the C-172's we don't require
they receive an additional checkout for each C-172 avionics
configuration.
-Robert
  #29
Old November 27th 08, 01:15 AM posted to rec.aviation.owning
B A R R Y[_2_]
A Lieberma wrote:
Little did we know how much "communicating" was in
her future!
You dog...
  #30
Old November 27th 08, 01:28 AM posted to rec.aviation.owning
B A R R Y[_2_]
configuration.
-Robert
Right.
Back when I was a renter, we'd be checked out on a type. Some of the
rentals had "wierd" avionics not installed in other aircraft in the
fleet. It should not be unreasonable for a pilot not familiar with the
equipment in a particular bird to either a.) ask for some free "ground
flying" time to get familiar, or b.) to come back into the FBO and ask
for one-on-one instruction on the particular equipment.
The bottom line is that the pilot should be familiar with all the
equipment on board the rented aircraft that will be used on a particular
flight, or should ASK for assistance or manuals before departure.
It's perfectly understandable for a Private Pilot not to understand
something like an autopilot or non-mapping GPS, as they can simply
choose to not use it. Any certificated pilot should know if a
transponder is required for a particular flight, and how to use the
example on board if it is.
If we're doing pattern laps at a non-towered field, who cares about the
transponder? But if we're requesting ATC services...
Transponder problems with ATC COMS - Video [email protected] Piloting 8 November 27th 08 12:56 AM
Pop up IFR clearance with ATC COMS - Video [email protected] Piloting 0 November 15th 08 05:05 PM
Pop up IFR clearance with ATC COMS - Video A Lieberma[_2_] Owning 0 November 15th 08 05:04 PM
Pop up IFR clearance with ATC COMS - Video [email protected] Instrument Flight Rules 0 November 15th 08 05:04 PM
No Gyro and ILS approach with ATC COMS - Video [email protected] Instrument Flight Rules 0 November 1st 08 04:10 AM
