lCambridge 302 Security Fail
Old December 8th 08, 07:26 PM posted to rec.aviation.soaring
Andy[_1_]
Default lCambridge 302 Security Fail
On Dec 8, 12:16*pm, Darryl Ramm wrote:
There are different symptoms and probably different causes.
I didn't have a bad seal indication. The seal was good, the security
was bad, next log had good security. I only realized the next log
had good security after I sent it back to be fixed. Hence the
conclusion that sending it back was a waste of money.
Andy
Old December 8th 08, 07:48 PM posted to rec.aviation.soaring
I didn't have a bad seal indication. *The seal was good, the security
was bad, next log had good security. * I only realized the next log
had good security after I sent it back to be fixed. *Hence the
Andy
I wonder if all units are vulnerable? Mine has several hundred hours
on it, memory was full when I bought it (Spring 08) and I've
subsequently put 80 odd flight hours on it with no failures. Sometime
this Fall I had the thought to go back and check every single log in
the recorder to see if there were any failures that I might have
missed (20 minute sled ride, aero-retrieve, etc.) and there are none.
So it does appear possible, at least occasionally, to completely fill
the 302 memory without inducing the security failure.
-Evan Ludeman / T8
Old December 8th 08, 08:03 PM posted to rec.aviation.soaring
Darryl Ramm
Andy
I wonder if all units are vulnerable? *Mine has several hundred hours
subsequently put 80 odd flight hours on it with no failures. *Sometime
-Evan Ludeman / T8
The problem is isolated and clearly many C302 can wrap log memory
(many times) with no problems, soem other 302s may never get to wrap
they log memory if they have slow log rates, don't fly much and/or are
are calibrated periodically (when log mmory will be cleared). All this
assumes that the folk law on wrapping the log memory is correct.
Maybe it's certain units that are more problematic, maybe it's related
to some pseudo random things like what memory address things happen to
start or end at and so maybe we are all playing Russian roulette. I
hope Cambridge have a handle on this now with the FLASH memory chip
change. Like I said I've stopped clearing memory and am running at 1Hz
log rate and will see.
So while irritating for us who experience this, it is nice to get such
quick turn around from the US based factory on service stuff.
Darryl
Old December 9th 08, 01:23 AM posted to rec.aviation.soaring
As the originator of this thread, today I did not get "Security Fail "
after my flight. Jeff, the main man at CAI stated this morning that
subsequential flights with S Fail problems most likely means a battery
issue. In review, I believe my problem yesterday may have been being
to quick to transfer flight info. after aircraft came to a stop. I
hope, anyway. This was the first burp on a unit with over 900 hours on
it. Lets see what happens tomorrow.
R
Old December 9th 08, 01:28 PM posted to rec.aviation.soaring
Andy[_1_]
That's interesting. Did Cambridge suggest there was some minimum time
that should elapse between landing and download?
Andy
Old December 9th 08, 06:56 PM posted to rec.aviation.soaring
Sorry it took so long to get back. I thought I read in the manual to
allow a few minutes after stopping for the unit to settle and log "on
ground". I waited only seconds after stopping to transfer before
climbing out of the cockpit. I'm not sure if there is a connection
with my S Fail indication. Looking at the above postings proves to me
I'm out on the fringe of understanding any of this.
R
Old December 10th 08, 09:58 PM posted to rec.aviation.soaring
Andy[_1_]
On Dec 9, 4:20*pm, Tim Newport-Peace ] wrote:
I am wondering if this problem is due to trying to download while still
recording.
Me too. I would be a **** poor design if the utility was allowed to
access the log file before it been properly closed but it wouldn't
surprise me. I suppose a useful test would be to try a download while
still in motion.
Something to try on a winter local flight perhaps.
Andy
Old December 11th 08, 07:48 PM posted to rec.aviation.soaring
recording
My 302A CFR has been giving me a security fail notice in the Cambidge
Utility progamme after every download for at least 2 seasons. Often I
have downloaded the flight log when de-rigging long after landing so
in my case at least I am sure that downloading while still recording
is not the cause of the problem.
I have cleared the memory on 2 separate occasions and that made no
difference either.
John Galloway
  #29
Old December 11th 08, 10:45 PM posted to rec.aviation.soaring
Peter Purdie[_3_]
Hooked up to a PDA or PC with a terminal program. typ VER return.
The 302A will give a text message, concluding (if there is a bad
electronic seal) with 'Security Fail'.
If so, in UK send it to me at RD Aviation or Dickie Feakes where it can be
resealed (after checking the memory battery voltage and replacing if
necessary).
Pete Purdie
At 19:48 11 December 2008, wrote:
still
recording
difference either.
John Galloway
  #30
Old December 12th 08, 01:51 AM posted to rec.aviation.soaring
Andy[_1_]
necessary).
The security fail report does not indicate that the seal is bad.
Please assist Cambridge with fixing the design problem rather than
using it to solicit business!
Andy
Pilots in India often fail alcohol tests Larry Dighera Piloting 1 June 27th 08 08:05 PM
Police fail to investigate another LASER attack Rowan General Aviation 7 June 10th 08 02:46 PM
IOF 240 Engine-Would it run if the batteries fail? Piperflyer Owning 6 May 10th 04 05:18 PM
F-89 rockets fail to stop Hellcat Paul Hirose Military Aviation 1 January 19th 04 02:46 PM
ADEN 25mm - why did it fail John Walker Military Aviation 2 August 17th 03 05:27 PM
