Couple followups to the responses on this thread.
First, I'm not doubting that you have to lean at higher altitudes; that is empirically most true. I'll try to restate the question below... Stealth Pilot wrote: "why do I lean my carb when I climb" is a bull**** question open to much misinterpretation. "why do I need to lean my carburettor at higher altitudes" is probably a better wording of the question. Sure, that's what I was asking in the original post. that is simple. the air is less dense so the amount of fuel it needs to achieve full combustion is reduced. the density of the fuel doesnt decrease so you need less of it. That I understand. It's also effectively a handwaving explanation to the original question. Here's the original question restated. Can somebody explain, why at higher altitudes, the less dense air does not automatically meter less fuel through a carb venturi, automatically making up for this difference. A carb venturi operates taking advantage of the decrease in pressure associated with the increase of velocity through the venturi -- a phenomenon which is dependent on the density of the air. This question doesn't apply to a fuel injected engine, where as I understand the fuel metering volume does not depend on air density, or to any carbs with a compensating device. |
On Tue, 20 Jan 2009 05:44:01 -0500, Tman
wrote: Couple followups to the responses on this thread. First, I'm not doubting that you have to lean at higher altitudes; that is empirically most true. I'll try to restate the question below... Stealth Pilot wrote: "why do I lean my carb when I climb" is a bull**** question open to much misinterpretation. "why do I need to lean my carburettor at higher altitudes" is probably a better wording of the question. Sure, that's what I was asking in the original post. that is simple. the air is less dense so the amount of fuel it needs to achieve full combustion is reduced. the density of the fuel doesnt decrease so you need less of it. That I understand. It's also effectively a handwaving explanation to the original question. Here's the original question restated. Can somebody explain, why at higher altitudes, the less dense air does not automatically meter less fuel through a carb venturi, automatically making up for this difference. A carb venturi operates taking advantage of the decrease in pressure associated with the increase of velocity through the venturi -- a phenomenon which is dependent on the density of the air. I think what actually happens in an aircraft carby is much cruder than the elegant descriptions would have you believe. in the marvel schebler ma3-spav there are a number of jets that all need to be tweaked just so for the damn thing to work. there is an accelerator jet which is pumped when the throttle goes in. it also unpumps when the throttle gets pulled out but that just refills it's barrel. the arm to this has three settings increasing or decreasing the pump stroke and once you have this just sweet for your engine dont change it. the outlet pipe needs to point just so into the inner venturi ring. there are a number of idle jets (actually just holes in the side) in the wall of the carby that keep it running around idle when the butterfly is almost closed. once this is adjusted for steady idle dont change it. then in the main jet comes in a whole number of sizes both in position and size of the apertures that allow fuel to escape. there is also an insert restricter in the base which is tweaked for each particular engine type. dicking around with this to get a sweet running engine can take ages. as for the changes in velocity or density actually changing the fuel flow well hmmmmm. if an engine can be run from sea level to about 6,000ft at full rich and still run and produce power, well that doesnt seem like too much of a flow change with density. jabiru use a bing altitude compensating carby. this has some sort of altitude sensing compensation mechanism in addition to the usual metering but that is a different animal. the old style carbys have a lot of tinkering behind the steady smooth metering in usual operation and have a simple adjustment that pilots can use to keep the mixture in the runnable range at other times. so my explanation is that if your surmise is correct I think it has only about a tenth of the effect you think it does. lots of tinkering and tweaking go behind making you think it does. Stealth Pilot |
On Jan 20, 6:32 am, Stealth Pilot
wrote: as for the changes in velocity or density actually changing the fuel flow well hmmmmm. if an engine can be run from sea level to about 6,000ft at full rich and still run and produce power, well that doesnt seem like too much of a flow change with density. Combustible mixtures range from 8:1 (air:fuel by weight) to 18:1. At sea level at full rich it'll be around 10:1. Pretty rich. As you climb it'll head for 8:1 as the air's density decreases and the engine will start to run rough and make black smoke. The mixture is changing and you need to do something about it. We have airplanes here at 3000' ASL that won't run nicely at all at full rich on a standard day and we have to lean them for takeoff if it's any warmer than that. Dan |
Q: Why do I need to lean out my carb when I climb?
Stealth Pilot is rude but he is also correct. I think your confusing volume with density. As the aircraft climbs into less dense air the amount of oxygen for a given volume decreases. That IO 360 engine (ie) is still breathing in 360 cubic inches of air every 2 revolutions, but that air is less dense and carries less Ox at altitude than it does down low. A rule of thumb is that 50% of the Ox in the atmosphere is below 18k'. |
Tman opined
Somebody posed that seemingly simple question to me, but kept coming back to the point that they stumped me.... And I am stumped. What do you see wrong with the logic in this dialog? Q: Why do I need to lean out my carb when I climb? A: Ahem, seems you forgot your PPL ground school. The air is less dense. Fewer air molecules per unit volume. Therefore, you need less gas, so you lean it out! Because the carb measures volume, and adds enough fuel for that volume. So, if the air is less dense, there is less mass of air entering the cylinders, and too much fuel. To correct that, you lean the mixture. -ash Cthulhu in 2012! Vote the greater evil. |
On Jan 19, 1:23*pm, Tman wrote:
Somebody posed that seemingly simple question to me, but kept coming back to the point that they stumped me.... And I am stumped. *What do you see wrong with the logic in this dialog? Q: Why do I need to lean out my carb when I climb? A: *Ahem, seems you forgot your PPL ground school. *The air is less dense. *Fewer air molecules per unit volume. *Therefore, you need less gas, so you lean it out! lots of really interesting stoichimetric ratio stuffage snipp-ed).... Anyone see what is amiss? T Yes, the obvious answer to any Texas Aggie: "because it's easier than leaning out the window". |
Learning to lean | WingFlaps | Piloting | 2 | March 12th 08 10:47 AM |
Have you ever experienced carb ice with an injector carb? | flybynightkarmarepair | Home Built | 1 | January 31st 05 01:48 AM |
Carb temp guage vs. Iceman carb ice detector | Mike Rapoport | Piloting | 1 | September 28th 04 03:13 AM |
Whether to Lean or Enrich | jls | Owning | 12 | March 3rd 04 07:56 AM |
Leaning / step climbing? | aaronw | Piloting | 30 | November 17th 03 05:44 PM |
