Trailer tires
Old January 21st 09, 05:38 PM posted to rec.aviation.soaring
kd6veb
Default Trailer tires
Hi Gang
There is another important consideration that has not been
thoroughly dealt with in this thread and that is trailer sway with
depends critically on the tires used and their pressures. What is
trailer sway? Well you are tootling down the highway at 50mph and
everything is great and then as you go through 65mph your trailer
begins to swing from side to side much to the consternation of anyone
following you. The only way to reduce this low frequency oscillation
is to slow down fast before the situation can get away from you. So
what are the factors affecting sway? Well the weight of the trailer is
one, the weight of the vehicle hauling, where the trailer wheels are
placed (front, middle or rear) but probably the most critical factor
is the lateral flex of the sidewalls of the tires, wand of course, the
pressure of the tires. When I received my Cobra trailer from Germany
the tire pressures were low about 25psi and what I described above is
a true story. So I pumped the tires up to 40psi and no sway to 70mph
when towing with a heavy vehicle.
In researching trailer sway more fully I found the general consensus
was to use tires with very stiff side walls such as 10 ply non radial
tires (truck tires) and to keep tire pressures up close to the
manufacturers maximum pressures especially if you are going to tow
with a small vehicle. I hope this is of some help.
Dave
Old January 22nd 09, 12:52 PM posted to rec.aviation.soaring
Andy[_1_]
On Jan 21, 10:38*am, kd6veb wrote:
Hi Gang
* There is another important consideration that has not been
placed (front, middle or rear) but probably the most critical *factor
* In researching trailer sway more fully I found the general consensus
Dave
Some people believe that the lateral stiffness of the towing vehicle
rear suspension and tires (tyres) is more important for sway control
than the stiffness in the trailer.
When observing a sway oscillation of a trailer and tow vehicle do you
see translation or rotation at the trailer axle? If both, which is
dominant?
Andy
Cobra Trailer Tires (US) RN Soaring 25 July 25th 08 06:11 AM
glider trailer tires Ken Ward Soaring 18 October 3rd 06 04:15 AM
Tires... Blueskies Home Built 0 May 10th 05 12:26 AM
Glider trailer tires Greg Arnold Soaring 7 December 7th 04 06:42 AM
Replacing Cobra trailer 13 inch tires with larger? Andy Blackburn Soaring 6 August 19th 04 03:15 AM
