... Trying to fly these in the game IL2 is a waste of time, they are really crap. I can't believe this was realistic in comparison to other fighters of the time. Anyone know how good the real planes were and/or what their major weaknesses were? Well if you would ask this question at UBI forums in Olegs Ready Room you would get some realy good answers to this, as this subject has been present their since IL-2s release. Best thing to do is forget everything Westren you have read on the Fw 190's performance, and learn IL-2s Fw 190s strengths & weaknesses. I fly the Fw 190 in IL-2 and have no problems with killing Soviet fighters as long as I forget attempting to turn with them, do not try to turn with La, Yak etc and dont attempt to climb away, unless you have good seperation. Use your speed to hit & run etc. Roll rate is the Fw 190s trump card, as well as massive firepower and level speed, use these advantages wisely, and you will be successful. Regards, John Waters |
Keith Willshaw wrote:
wrote in message ... Trying to fly these in the game IL2 is a waste of time, they are really crap. I can't believe this was realistic in comparison to other fighters of the time. Anyone know how good the real planes were and/or what their major weaknesses were? They were excellent fighters, when they first appeared they provided a nasty surprise for the RAF and outmatched the Spitfires until the Mk IX came along. They were certainly superior to the Soviet aircraft of the period. The biggest problem with most computer game FW-190s is the gamers flying them, and the nature of the game environment (assuming the flight model is decent). The 190 is an energy fighter, and you have to fight it that way. You can't just tug harder on the pole and tighten up your turn like you can in a Spit, seeing who will stall/snap out first; the 190 loses that game. The FW-190A's strengths, as someone wrote, were roll rate, cockpit visibility, good level and dive acceleration, decent sustained and good zoom climb, good level speeds for 1942 and still adequate for 1943, heavy armament, an easy to use power control, good hi-g tolerance seat position, excellent control harmony, good protection and durability. Disadvantages were poor turn radius, no-warning clean stall, and an accelerated stall, also no warning, which would snap the a/c over into the opposite bank and into an incipient spin if you didn't take quick corrective measures (which didn't do anything for the 'useful' turn rate/radius, as less experienced pilots were afraid to approach the a/c's limits), heavy elevator at high (dive) speeds which could limit pull-out ability, plus poor stability for instrument flying. Fighting against relatively light Spitfires etc. the 190 could bounce them, use their superior roll rate to stay with them through the first 90 degrees or so of turn while shooting, and then dive away, usually rolling 180 in the opposite direction so that the Spit was unable to follow (assuming it survived the intial pass). Such advantages tended to disappear when facing P-47s or P-51s, which had slower initial dive accel but would catch up if the dive were prolonged, reasonably high roll rates, and would outzoom it as well. I'd expect the fairly light Soviet fighters to be closer to the Spit than the heavier American types. The other main disadvantage for the FW-190 is the game environment itself. In real life, the majority of fighter kills were made in the first pass, with the target unaware of its adversary's presence until too late. Pilots could fly hours and hours and never see an enemy a/c, so sneaking up on someone was relatively common. But that's rarely the case in a computer game, where you can _expect_ there to be enemies about in a short period of time, and you can virtually guarantee that both sides will, if contact is made, initiate combat. In such circumstances an energy fighter like the 190's advantages are nullified. In real life that would often not be the case -- a group of faster fighters who were in a disadvantageous position would often just use their speed to disengage, figuring to come back with an advantage next time. BTW, here's some comparisions done with USN fighters against an FW-190A-5/U4: http://www.geocities.com/slakergmb/id88.htm There used to be a page with various British test reports including those of a captured FW-190A-4, but they seem to be gone: http://web.archive.org/web/200202102...eo/prodocs.htm only gets you the home page. Summarizing, the 190A was superior to the Spit V in every performance measure other than turn rate/radius, essentially equal or slightly ahead of the Spit IX at low/medium altitudes and inferior at higher altitudes, with each side having advantages and disadvantages depending on the situation, and inferior to the Mk.XIV in every performance measure except roll rate and dive acceleration. Fly the 190 against Soviet fighters like it's a P-40 or F4U flying against an Oscar/Zero. Guy |
![]() "ArtKramr" wrote in message ... Subject: WWII FW190's, how good were they in dogfights? From: nt (Krztalizer) Date: 5/20/04 9:03 PM Pacific Daylight Time Message-id: I saw something (I think) in here not too long ago, where someone had asked the late Adolf Galland about the fact that (on paper) the FW190 was superior to the 109. Galland gained most of his victories in the latter, and IIRC, his comment was that the 109 was much more 'comfortable' to fly, whereas the FW190 needed more attention from the pilot to just flying the aeroplane. I have always understood that manouvreability and stability in a fighter aircraft was a balancing act, too stable and it lacked agility, too agile and it was 'twitchy' and could be unpleasant to fly. Perhaps the 190 was on the edge of that envelope? Lots of folks flew both and comparisons between the two are all over the board. For some like Novotny, a 109 was an antiquated and poorly laid out has-been; he felt the 190's brilliantly thought out "T"-shaped instrument panel made his job far more instinctual than in the more labor intensive Messerschmitt cockpit. Others like Rall and Barkhorn felt that the small size of the 109 led one to feel as if they were "wearing" the Me, so movements were practically reflexive and coordinated between pilot and airframe. I think the demarcation between factions is frequently set at when that particular pilot began to fly German fighters -- 1942 and earlier, the pilots generally preferred the nimble 109, even after fighters of a better class were introduced. Conversely, the "young lions" that came along after the 109's heyday felt no great affinity for it when offered the technologically advanced Focke Wulf fighter. I guess once they survived into 1944 and 45, each group were entitled to latch onto whatever superstition had kept them alive when so many of their comrades had fallen. Look at Rudel - that frickin' Nazi started the war in a flight of Stukas, at one point transitioned to CAS FW-190s, then ended the war back in a flight of Stukas - at a time in the war when daylight operations in the Ju 87 were considered absolute suicide by Allied and most German airmen alike. Go figure. v/r Gordon Of the many German fighter pilots I spoke to in the Hofbrau Haus in Munich shortly after the war the majority opted for the ME 109. The Emil or "E " model seemed the number one choice. Many were saddened because the Emils were replaced by what they considered models that were not quite as good. These discussions were in the summer of 1945. In a bad landing at night the pug nosed FW190A could over nose and end up on its back. As the pilot was in a bubble canopy he could easily be killed and frequently was. The Me109 with its long nose, burried cockpit and famously weak undercarriage which simply collapsed was a virtue in these circumstances and the crews prefered it for this reason. Several of these aircraft were fitted with neptune radars with the intention of chasing Mosquitos. They worked well but after staring at the phosphors the pilot lost his precious night vision and the idea was dropped. |
Excellent post. I particularly liked the link to the USN tests. As the
Corsair's opponent was almost exclusively Japanese, it must have been a revelation to find there was an airplane it could outturn (okay, there was the P-47). The impact of a weapon system with an effective range of perhaps 1500 feet skews the weighting of A/C performance characteristics quite a bit when compared to modern machinery. But then as now, speed was life. R / John |
From: "The Enlightenment" Date: 5/22/04 12:50 AM Pacific Daylight Time In a bad landing at night the pug nosed FW190A could over nose and end up on its back. As the pilot was in a bubble canopy he could easily be killed and frequently was. Ol' Willie never could design a decent landing gear. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
"John Waters" wrote in message m...
wrote in message ... Trying to fly these in the game IL2 is a waste of time, they are really crap. I can't believe this was realistic in comparison to other fighters of the time. Anyone know how good the real planes were and/or what their major weaknesses were? Biggest problem about computer games I have discovered so far is Earth's G effect is ignored (the egg) along with no unloaded (zero-G) accleration increase. The gun ranges far exceed actual effective ranges in real life, as well as the lead requirements are way too small. For example, co-speed 400KIAS, 1500 foot range, 5 G, the pipper sags down below the nose in an F104A - your target's wings stick out each side of the radome. Also, fuel consumption is also way too low, at a guesstimate about 1/4 what it really is in combat. Walt BJ |
#29
![]() BTW, the Spitfires are nice till you get P51s but the Hurricanes have a turning radius and roll rate that seems to be an advantage in some engagements. I wonder if this reflects real conditions? I went about European Air War completely backwards - flying missions in Me 262s and P-47s against essentially sitting ducks (B-24s and He 111s, respectively). After a couple years playing it and trying nearly every aircraft, I flew a couple campaigns set on realistic (read: landing by parachute was considered a success) and the best fighter v fighter in the game was a Spit IX. Close second, as far as flying a whole campaign, was the Hurricane. That thing had a ton of guns and most of what was being fired back was light enough that, when hit, you could bail out over friendly territory and begin again. Defending Beachy Head from a sky full of 110s seemed pretty realistic, *for a game*. One thing I hate about WWII flight sims is that aircraft in bomber streams never seem to feel effects of turbulance. Formations bob ever so gently in rhythmic patterns at a set airspeed, like perfect robots. 10+ Mosquitos fly along at 12,000' in loose groups at 280 knots, serene as nuns as you fall in astern. Yah, that's realism. Has anyone seen a decent nightfighter sim? Something in a Mosquito or Beau..? v/r Gordon ====(A+C==== USN SAR An LZ is a place you want to land, not stay. |
#30
John Carrier wrote:
Excellent post. I particularly liked the link to the USN tests. As the Corsair's opponent was almost exclusively Japanese, it must have been a revelation to find there was an airplane it could outturn (okay, there was the P-47). The impact of a weapon system with an effective range of perhaps 1500 feet skews the weighting of A/C performance characteristics quite a bit when compared to modern machinery. But then as now, speed was life. In fairness I should mention that Eric Brown, who'd flown all three extensively, reached a different conclusion than this USN comparison. Re the Corsair II (F4U-1A with clipped wingtips) vs. the FW-190A-4, he wrote: "This would be a contest between a heavyweight and a lightweight fighter, with virtually all the advantages on the side of the latter. Having flown both a/c a lot, I have no doubt as to which I would rather fly. The FW-190A-4 could not be bested by the Corsair. "Verdict: The FW-190A-4 was arguably the best piston-engine fighter of World War II [Note: he probably means the FW-190 series. Later in the book, when rating the best performing piston-fighters of WW2 , he rates the Spit XIV number one with the inline-engined FW-190D-9 just a nose behind, and the P-51D (Mustang IV) a tad behind that, deliberately ignoring operational issues such as range]. It is a clear winner in combat with the Corsair." F6F-3 vs. FW-190A-4: "This would be a showdown between two classic fighters. The German had a speed advantage of 30 mph, the American a slight advantage in climb. Both were very maneuverable* and both had heavy firepower. By 1944 the FW-190 was a little long in the tooth, while the Hellcat was a relative newcomer; still, the superb technology built into the German fighter by Kurt Tank was not outmoded. The Hellcat had broken the iron grip of the Zeke in the Far East, but the FW-190A-4 was a far tougher opponent. "Verdict: This was a contest so finely balanced that the skill of the pilot would probably be the deciding factor." *A somewhat odd statement, as the Hellcat had the typically mushy Grumman ailerons. But it could certainly out-turn the 190. Guy |
Hiroshima/Nagasaki vs conventional B-17 bombing | zxcv | Military Aviation | 55 | April 4th 04 07:05 AM |
Good Ad! WWII Pilot | Joe | Military Aviation | 0 | January 11th 04 09:37 PM |
P-47/51 deflection shots into the belly of the German tanks,reality | ArtKramr | Military Aviation | 131 | September 7th 03 09:02 PM |
FA: WWII B-3jacket, B-1 pants, Class A uniform | N329DF | Military Aviation | 1 | August 16th 03 03:41 PM |
