#21
![]() "Guy Alcala" wrote in message . .. No, and just as importantly, they probably couldn't produce fuel of sufficiently high octane to allow it to produce the higher power it's capable of, even if they could build the engine, and chances are the oil would be inadequate as well (petroleum engineers with a history minor should now weigh in). If you want to postulate time travel for a one-time deal, fine, but if you're looking for something that could actually be produced 20 years earlier and be supported for the long term, it just ain't gonna happen. Guy Simple, just put some information on how to make a catalytic cracker in the cockpit. -E -- To reply, get the 5 out as if I were my own ISP. |
"Charles Talleyrand" wrote in message ...
Lets suppose you get to give a single new airplane design and a single prototype to a participant of World War One. You can offer the Austro-Hungarians the design for a B-52 if you wish. However, that might prove a manufacturing challenge to them (and one can only wonder about their supply of jet fuel). Your goal is to change history. You can hope for a German victory or just that the Allies win faster. It's up to you. So, what design do you offer, remembering that this design must be manufactured, fueled, and armed by the natives? Probably a Japanese Zero. The Zero could land and take off on a relitivly short grass runway as long as the ground is not soft. The engine should be within their capacity to build, and that is the main thing, a late 1930's evolved internal combustion aircraft engine with lots of power. The airframe had lots of wood and nothing very sophisticated in terms of metal parts. The 20mm cannons would make it's firepower something to be feared. A Zero would be a terror of the sky in 1918, it can outrun and out climb everything else. A small number with fuel and ammunition can rout the other side's airforce and do nasty things in ground attack, and recon especially given their speed and range. -snip |
"Eunometic" wrote in message om... My feeling is that knowledge of materials for engine development was what kept engine weight up and kept down the performance of most of these aircraft. For instance an engine of the quality of the cyclone seen on Charles Lindbergs Spirit of St Louise would have immeasurably improved the performance of these aircraft especially if fitted with NACA style cowlings. It most certainly was easily buidable by the fabrication techniwques of the day. Prior to that engines were bulky liquid cooled models or clumsy rotaries. Suppose someone gives them a construction manual and a prototype of a radial engine (probably without the turbocharger) for any common radial engine of the 1940s. Can they get the correct alloys and build to the needed tolerances? I think they would have to make the aluminium alloys for the heads of the cylinder from scratch but given the proportions they could make them. Might have to drop the compression ratio a bit to make use of the lower grade gasolines and fit an oversized oil cooler and change the oil more often. The engine would still be superior to what they had. |
![]() "alfred montestruc" wrote in message om... "Charles Talleyrand" wrote in message ... Lets suppose you get to give a single new airplane design and a single prototype to a participant of World War One. You can offer the Austro-Hungarians the design for a B-52 if you wish. However, that might prove a manufacturing challenge to them (and one can only wonder about their supply of jet fuel). Your goal is to change history. You can hope for a German victory or just that the Allies win faster. It's up to you. So, what design do you offer, remembering that this design must be manufactured, fueled, and armed by the natives? Probably a Japanese Zero. The Zero could land and take off on a relitivly short grass runway as long as the ground is not soft. The engine should be within their capacity to build, and that is the main thing, a late 1930's evolved internal combustion aircraft engine with lots of power. It wasnt, the engine was at least 2 generations beyond anything achievable in 1918. Keith ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
Keith Willshaw wrote: /Mitsubishi Zero../ It wasnt, the engine was at least 2 generations beyond anything achievable in 1918. I'd thought of the Ishak, but again the engine was well beyond anything possible in 1918. Best engines available were the Cosmos (later Bristol) Jupiter and the Napier Lion - hurrying these along by a few metallurgical nudges might have been possible, and it's not too much of a leap from the technology required for those to being able to build the Curtis V12 of the middle 1920s - which leads to my suggestion: The Fairey Fox 2 seat light bomber, first flew in IIRC 1926, when it was close on 50 mph faster than any fighter. Carried a decent load for its time (1.5 times or so the DH9A load, I think) and was also available as a heavy 2-seat fighter. Trying to deal with Foxes in 1917 or 18 with the fighters available then would be like trying to stop Canberras with 1944 fighters. Just not on. I'd suggest the Fox as one possibility. Another might be one of the big 1920s commercial transports plus gliders (the Lion, Jupiter or Curtis V12) could give enough power for glider tows. That would allow rapid re-supply of troops after advances across no-mans land (this was being done with smaller aeroplanes and parachute drops by 1918) and would mean that you could provide recently-advances troops with artillery pieces, heavy machine guns, wire entanglements and probably even light armoured vehicles - tankettes - by glider before the enemy could arrange a counter-attack. That would probably have the greatest effect of all. Perhaps something like a more powerfully-engined Vickers Victoria or similar? -- Andy Breen ~ Interplanetary Scintillation Research Group http://users.aber.ac.uk/azb/ "Time has stopped, says the Black Lion clock and eternity has begun" (Dylan Thomas) |
Guy Alcala writes: Charles Talleyrand wrote: "Eunometic" wrote in message om... My feeling is that knowledge of materials for engine development was what kept engine weight up and kept down the performance of most of these aircraft. For instance an engine of the quality of the cyclone seen on Charles Lindbergs Spirit of St Louise would have immeasurably improved the performance of these aircraft especially if fitted with NACA style cowlings. It most certainly was easily buidable by the fabrication techniwques of the day. Prior to that engines were bulky liquid cooled models or clumsy rotaries. Suppose someone gives them a construction manual and a prototype of a radial engine (probably without the turbocharger) for any common radial engine of the 1940s. Can they get the correct alloys and build to the needed tolerances? No, and just as importantly, they probably couldn't produce fuel of sufficiently high octane to allow it to produce the higher power it's capable of, even if they could build the engine, and chances are the oil would be inadequate as well (petroleum engineers with a history minor should now weigh in). Not a Petroleum Engineer, but some of teh vehicles in the Family Collection date from that period (In particular, the FWD 3-5 Ton Truck, and the Van Dorne 6-ton Tank (Renault FT). The Gasoline back then was a lot better than most people think - it was a byproduct of Kerosene production, and they'd basically boiled & squeexed anything that wasn't Iso-Octane out in order to maximize the yeld for teh other products. Of course, here aren't any good samples lying around, but I'd place teh Octane Rating at somewhere above 80, so it wouldn't be too dissimilar from 80/87 AVGAS. Materiels werent' a problem either - The Engine Block, Intake Manifolds, Transmission and Transfer Case on the FWD are Alumin(i)um, and nearly pure at that - (I took a sample to the Materiels Lab when I was working for the World's Largest Producer of Consumer Batteries and checked it out) much better than most Aluminum stock these days, but probably as expesive as All Get Out. A lot of that Octane Rating was wasted, though. Because of the need to actually get the thing started, and because the Electric Motors of teh day weren't up to it, the maximum Compression Ratio that was practical to use was around 4-4.5:1. (It took 3 guys to prop a 1650 cu-in Liberty, for example, and the 400 Cu-in on the FWD is a serious workout, even with an Impulse unit on teh Magneto to help) Note that this wasn't just confined to the 1910-1920s - many engines used flywheel starter systems, either hand-cranked or electrically driven, to store up enough energy to get the bit engines turned over. The big drawbacks to producing a high-powered engine at that time were Carburetion and Ignition. Carburetoes were simple in the extreme, adn weren't very good at atomizing fuel, or at adjusting to the varying air densities encountered by an airplane engine. Ignition systems were crude - they all worked with extremely high voltage, (70 Kvolts or so), to try to get the strongest spark they could, with the Spark Plugs that existed at that time. That's all well and good, but there weren't any good insulators available. This led to internal breakdowns in the Magnetos, and arcing and shorting of the plug leads. It's bad enough at Sea Level, and it's horrid at high altitude, where the dielectric properties of the air are much worse. (Heat tolerance by these materials was poor, as well.) Insulators were ceramic, Natural Rubber, and Mica. It took the development of Plastics in the late 1920s-early 1930s (Most Notably Bakelite and Formica) to produce reliable high-power Ignition Systems. If you want to postulate time travel for a one-time deal, fine, but if you're looking for something that could actually be produced 20 years earlier and be supported for the long term, it just ain't gonna happen. Concur - there were a lot of steps that had to be made before you could build anything more advanced than they were. In fact, teh Forst World War, and the technology race that it spawned was the major driver for those advances. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
"Eric Boyd" writes: "Guy Alcala" wrote in message . .. No, and just as importantly, they probably couldn't produce fuel of sufficiently high octane to allow it to produce the higher power it's capable of, even if they could build the engine, and chances are the oil would be inadequate as well (petroleum engineers with a history minor should now weigh in). If you want to postulate time travel for a one-time deal, fine, but if you're looking for something that could actually be produced 20 years earlier and be supported for the long term, it just ain't gonna happen. Guy Simple, just put some information on how to make a catalytic cracker in the cockpit. As pointed out in my reply to Guy's post, fuel quality wasn't the problem. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
#29
![]() "Charles Talleyrand" wrote in message ... Lets suppose you get to give a single new airplane design and a single prototype to a participant of World War One. You can offer the Austro-Hungarians the design for a B-52 if you wish. However, that might prove a manufacturing challenge to them (and one can only wonder about their supply of jet fuel). Given the lack of high-powered engines, would some of the early autogyro designs be easier to produce than a more advanced airplane? -- Zamboni |
#30
![]() "Keith Willshaw" wrote in message ... "Eunometic" wrote in message om... "Charles Talleyrand" wrote in message I suspect if an engineer of the capability of Hugo Junkers had of produced a light weight air cooled radial for mating with an Junker J1 style airframe an immensly fast and tough aircraft would have resulted. (I would say speeds of 160-170mph). What you are describing is basically the Bristol F2b Fighter of 1918, except that it had a water cooled engine. The type remained in service until 1932 Keith At a speed of 123mph it was far to slow and suffered form Albatross attacks even with its rear lewis gun. Only the realisation that it could dog fight as well as most fighters saved this scout from being a flop. A decisive advantage in WW1 would have required a speed of 160-170 mph which would be decisevly beyond anything. It would also require a bomb load of over 2200lbs as this would allow large torpoedoes and sticks of bombs and a range of up to 1000 miles for a bomber. Sufficient of these could shift the balance at sea, be able to destroy logistics, bridges, docks, etc and factories I think. |
FS: 1988 "Aces High" (Military Airplanes) Hardcover Edition Book | J.R. Sinclair | Aviation Marketplace | 0 | August 23rd 04 05:18 AM |
Ever heard of Nearly-New Airplanes, Inc.? | The Rainmaker | Aviation Marketplace | 1 | June 23rd 04 05:08 PM |
SMALLL airplanes.. | BllFs6 | Home Built | 12 | May 8th 04 12:48 PM |
FS: 1990 Cracker Jack "War Time Airplanes" Minis 6-Card (CJR-3) Set | J.R. Sinclair | Aviation Marketplace | 0 | April 12th 04 05:57 AM |
Sport Pilot Airplanes - Homebuilt? | Rich S. | Home Built | 8 | August 10th 03 11:41 PM |
