On May 6, 12:47*am, (Alan) wrote:
In article writes: Michael, I wanted to respond to your questions with the reasons that I advocate the takeoff technique described in the Flight Training Manual for Gliders. I recommend getting the glider balanced on the main wheel as soon as possible. *You can see why this is important if you look at what can happen if you keep either the tail wheel or the nose wheel on the ground too long. In a tail dragger, if you hold too much back pressure (or the elevator is trimmed too far back) the glider will lift off while the tail is still being =93pushed=94 into the ground by the elevator. *The glider can then lift it=92s main wheel off of the ground, but keep increasing it=92s angle of attack because the excess back pressure keeps the tail wheel on the ground. *The glider can either stall, or more likely, lurch into the air and climb rapidly. * This could pull the tail of the tow plane up, driving it=92s nose into the ground. * Or, as the glider lifts off rapidly, the pilot/student will often over control, causing the glider to slam back down to the ground, possibly starting a pilot induced oscillation. With a nose dragger, if you hold too much forward pressure (or the elevator is trimmed too far forward), the glider can reach flying speed, yet still not be flying because the angle of attack is too low to generate sufficient lift. * If the stick is then moved back to lift the nose, the glider can lurch into the air quickly, causing the same problems just described. And finally, look what could happen if the glider hits a bump while rolling on the nose or tail wheels, as opposed to what happens if it hits a bump while balanced on the main wheel. * A bump to the tail wheel can damage it, or drive the nose into the ground. *A bump to the nose wheel can cause a rapid increase in angle of attack which, if sufficient speed has been reached, can cause the glider to lurch into the air, or if flying speed has not been reached, the glider can slam onto the tail wheel, damaging it or the rear fuselage. *If you hit a bump while balancing on the main wheel, the force will act very near the center of gravity, and will not cause a change to the pitch or angle of attack. So, whether you are flying a tail dragger or a nose dragger, the goal should be to get the glider in to a flying attitude as soon as possible. * To achieve this, during the initial roll on take off, make sure the stick is held well forward in a tail dragger, or well aft in a nose dragger. I hope this helps to clear things up. Russell Holtz * Gee, and Charlie had me holding it forward of neutral in the 2-32, sort of the opposite of "well aft". * * * * Alan Alan You are comparing Russel's useful generalization and one good instructors' specific advice. If we could just read a book or ras and know everything we would not need those annoying flight instructors. Maybe Charlie was predisposed to baby the fragile tail wheel on a 2-32, or even if your 2-32 had a pneumatic wheel mod maybe he wanted to encourage babying the 2-32 tail wheel in general. Maybe he felt you were holding on too much back pressure (even without realizing it, e.g. causing an unexpected balloon up behind the tow plane) and was trying to help cure you of that. Or maybe one of several other reasons. Ask Charlie to explain the difference in his advice to the generalization in the textbook. Darryl |
Newbie holding questions | JohnK | Instrument Flight Rules | 106 | January 14th 06 09:44 AM |
Bose X - $995 and holding... | [email protected] | Piloting | 23 | November 30th 05 12:57 AM |
Holding pattern reporting | Yossarian | Instrument Flight Rules | 14 | July 4th 05 10:57 AM |
Holding at CHS | Stuart King | Instrument Flight Rules | 3 | November 10th 03 07:52 PM |
Holding Pattern Entries | Dan Luke | Instrument Flight Rules | 17 | July 11th 03 05:18 AM |
