RST Engineering - JIm wrote:
Yes. It was made by National Semiconductor and you could get it linear or logarithmic. It was obsoleted by National about fifteen years ago, but there are still a few of them in the pipeline at a pretty hefty price. Jim wrote in message ... Isn't there a voltage-to-LED-bar-graph IC? I seem to remember such a thing. That would make the circuit simple. Nope. It's still very much available in the surface mount package. |
By God, you are correct. When my supplier told me in 1999 that the LM3914
was no longer available, they failed to tell me that the LM3914-1 was a direct replacement and very much still in the pipeline, even as the larger 18 pin through-hole DIP package. Thanks for correcting me. Jim "Rip" wrote in message ... RST Engineering - JIm wrote: Yes. It was made by National Semiconductor and you could get it linear or logarithmic. It was obsoleted by National about fifteen years ago, but there are still a few of them in the pipeline at a pretty hefty price. Jim wrote in message ... Isn't there a voltage-to-LED-bar-graph IC? I seem to remember such a thing. That would make the circuit simple. Nope. It's still very much available in the surface mount package. |
By God, you are correct. When my supplier told me in 1999 that the LM3914 was no longer available, they failed to tell me that the LM3914-1 was a direct replacement and very much still in the pipeline, even as the larger 18 pin through-hole DIP package. Thanks for correcting me. Jim "Rip" wrote in message ... RST Engineering - JIm wrote: Yes. It was made by National Semiconductor and you could get it linear or logarithmic. It was obsoleted by National about fifteen years ago, but there are still a few of them in the pipeline at a pretty hefty price. Jim wrote in message ... Isn't there a voltage-to-LED-bar-graph IC? I seem to remember such a thing. That would make the circuit simple. Nope. It's still very much available in the surface mount package. My pleasure. This topic is timely, since I recently built myself a "Lift Reserve Indicator" based on the LM3914 and a Honeywell sensor. Now I'm doing a "true" angle of attack indicator based on the Maxim 4210 multiplier (and an op amp) to correct for airspeed ram pressure. A terrific treatise on the subject (with one inconsequential math error) can be found he http://users.cablemo.net/~jjshultz/sonex/aoa.html Rip |
Mike wrote:
Has anyone built an electronic angle of attack meter kit. It seems to be something that would be easy to design but beyond my feeble electronics background. I have seen the products that are out there and they are simple differential pressure gauges and are expensive. I don't like the round differential pressure gauges that many of the companies offer for this kind of system. I was wondering if there would be a way to put something together that would light up different color LED's for the different levels of lift that we could build at home without having to pay out hundreds of dollars for a prebuilt one. Something like http://www.barkeraircraft.com/AOA_kit.html EAA web site says June 07 Sport Aviation Magazine, but I thought it was more recent than that. Charlie |
Charlie wrote:
Mike wrote: Has anyone built an electronic angle of attack meter kit. It seems to be something that would be easy to design but beyond my feeble electronics background. I have seen the products that are out there and they are simple differential pressure gauges and are expensive. I don't like the round differential pressure gauges that many of the companies offer for this kind of system. I was wondering if there would be a way to put something together that would light up different color LED's for the different levels of lift that we could build at home without having to pay out hundreds of dollars for a prebuilt one. Something like http://www.barkeraircraft.com/AOA_kit.html EAA web site says June 07 Sport Aviation Magazine, but I thought it was more recent than that. Charlie That's a nice set up. It shouldn't be too hard to add an audio alarm or shaker. I just hope the pitot tube isn't heated. Dan, U.S. Air Force, retired |
Dan wrote:
Charlie wrote: Mike wrote: Has anyone built an electronic angle of attack meter kit. It seems to be something that would be easy to design but beyond my feeble electronics background. I have seen the products that are out there and they are simple differential pressure gauges and are expensive. I don't like the round differential pressure gauges that many of the companies offer for this kind of system. I was wondering if there would be a way to put something together that would light up different color LED's for the different levels of lift that we could build at home without having to pay out hundreds of dollars for a prebuilt one. Something like http://www.barkeraircraft.com/AOA_kit.html EAA web site says June 07 Sport Aviation Magazine, but I thought it was more recent than that. Charlie That's a nice set up. It shouldn't be too hard to add an audio alarm or shaker. I just hope the pitot tube isn't heated. Dan, U.S. Air Force, retired Speaking of which, I have a heated pitot tube head If anyone is in need of one, drop me a note. |
I've worked this problem for a number of years. Let me offer a few
simple points. Any system of measuring AOA will need to be calibrated. It doesn't really need to be linear since the major interest is in the region near stall and Cl max. It just needs to give a variable output that is related to AOA - and be very repeatable. If the cockpit is in clean free air flow as with a pusher or sailplane, an effective AOA indicator can be made with a simple string taped to the side of the canopy. On sailplanes, these 'pitch strings' tends to 'over-indicate' by about 2:1 which is fine as it increases the resolution of the indicator. Stall, Cl max and L/D max can be marked on the inside of the canopy with grease pencil. It helps to put one on each side of the canopy as they tend to validate each other. If you like the pressure differential AOA probes, this is a good one. http://www.cgmasi.com/aviation/index.html If you want NASA quality data, the gold standard is the pitch vane mounted on an air-data nose boom. There are a number of vendors who sell these for UAV's which are about the right size for homebuilt airplanes. Here's an example: http://www.spaceagecontrol.com/Adpmain Bill D On May 9, 6:30*am, Mike wrote: Has anyone built an electronic angle of attack meter kit. *It seems to be something that would be easy to design but beyond my feeble electronics background. I have seen the products that are out there and they are simple differential pressure gauges and are expensive. *I don't like the round differential pressure gauges that many of the companies offer for this kind of system. *I was wondering if there would be a way to put something together that would light up different color LED's for the different levels of lift that we could build at home without having to pay out hundreds of dollars for a prebuilt one. |
In addition to Bill's comments the calibrations process must consider the position of the flaps. Remember you are measuring the AOA of the airfoil, not just the airflow relative to the fuselage.
Wayne http://www.soaridaho.com/Schreder .. "bildan" wrote in message ... I've worked this problem for a number of years. Let me offer a few simple points. Any system of measuring AOA will need to be calibrated. It doesn't really need to be linear since the major interest is in the region near stall and Cl max. It just needs to give a variable output that is related to AOA - and be very repeatable. If the cockpit is in clean free air flow as with a pusher or sailplane, an effective AOA indicator can be made with a simple string taped to the side of the canopy. On sailplanes, these 'pitch strings' tends to 'over-indicate' by about 2:1 which is fine as it increases the resolution of the indicator. Stall, Cl max and L/D max can be marked on the inside of the canopy with grease pencil. It helps to put one on each side of the canopy as they tend to validate each other. If you like the pressure differential AOA probes, this is a good one. http://www.cgmasi.com/aviation/index.html If you want NASA quality data, the gold standard is the pitch vane mounted on an air-data nose boom. There are a number of vendors who sell these for UAV's which are about the right size for homebuilt airplanes. Here's an example: http://www.spaceagecontrol.com/Adpmain Bill D |
bildan wrote:
I've worked this problem for a number of years. Let me offer a few simple points. Any system of measuring AOA will need to be calibrated. It doesn't really need to be linear since the major interest is in the region near stall and Cl max. It just needs to give a variable output that is related to AOA - and be very repeatable. If the cockpit is in clean free air flow as with a pusher or sailplane, an effective AOA indicator can be made with a simple string taped to the side of the canopy. On sailplanes, these 'pitch strings' tends to 'over-indicate' by about 2:1 which is fine as it increases the resolution of the indicator. Stall, Cl max and L/D max can be marked on the inside of the canopy with grease pencil. It helps to put one on each side of the canopy as they tend to validate each other. If you like the pressure differential AOA probes, this is a good one. http://www.cgmasi.com/aviation/index.html It occurs to me that a differential system should be fairly simple to build. Solid state pressure sensors have been around a long time. Since AOA would be the ratio between the two sensors it should be simple to make a comparator to voltage converter since actual pressures are irrelevant as long as they are sufficient to be read. Airspeed would also not be a factor. I suppose a purely mechanical system could also be built by a mechanically inclined type. Pressure from each port would be sent to opposing bellows in an indicator which would position a needle. Dan, U.S. Air Force, retired |
On Sat, 9 May 2009 05:30:37 -0700 (PDT), Mike
wrote: Has anyone built an electronic angle of attack meter kit. It seems to be something that would be easy to design but beyond my feeble electronics background. I have seen the products that are out there and they are simple differential pressure gauges and are expensive. I don't like the round differential pressure gauges that many of the companies offer for this kind of system. I was wondering if there would be a way to put something together that would light up different color LED's for the different levels of lift that we could build at home without having to pay out hundreds of dollars for a prebuilt one. Buy an electronic differential pressureindicator and put a bar graph on it. Not cheap - new Setras are about $400 but they are available surplus occaisionally at good prices. You want 0-5 volt, not 20ma outputs. |
Prop angle of attack vs age | sid | Piloting | 47 | July 13th 08 04:46 PM |
Glider angle of attack indicator by SafeFlight | Bill Daniels | Soaring | 53 | December 20th 07 12:29 PM |
Angle of attack | Bill Daniels | Soaring | 27 | December 19th 07 06:17 AM |
preferrred bank angle indicator? | Matt Herron Jr. | Soaring | 34 | July 10th 06 02:22 PM |
Lift and Angle of Attack | Peter Duniho | Simulators | 9 | October 2nd 03 10:55 PM |
