#21
Andreas Maurer wrote:
Not to mention that a significant forward elevator is going to induce some serious negative G once the glider snapped out of the spin. With the ASK-21 you can find yourself in a sudden inverted spin if you push the stick fully forward. |
On Mon, 11 May 2009 15:51:27 -0700 (PDT), bildan
wrote: Read more carefully. I didn't write anything about trying a recovery with full up elevator. I wrote "until the auto-rotation slowed and only then applying down elevator" I know - what i wanted to say is that the rotation isn't going to slow down significantly in many gliders if you keep the elevator pulled up. Not to mention that a significant forward elevator is going to induce some serious negative G once the glider snapped out of the spin. Bye Andreas |
On Mon, 11 May 2009 15:28:18 -0700 (PDT), Darryl Ramm
wrote: Not surprising at all - it would surprise me if anybody really wants to teach this. Lets see - - A desire to teach a standardized recovery - Don't distract people with grabbing for a handle while under stress (or if not stress just physically being thrown around a little) - Likelyhood of grabbing the wrong handle (esp. if transitioning from another ship) and just moving it (i.e. opening full spoilers) - With full negative flap what happens to increased likelihood of entering another/reverse spin if the pilot recovers too "hard"? All of your points are right on the spot. However, I really teach this. The command is simple: "Push the flap lever forward". The other levers on the left side of the cockpit (gear and airbrakes) cannot be pushed forward, so no harm can be done by grabbing the wrong lever. Apart from the quicker recovery in negative flaps, there's one much more important point why it's absolutely necessary (in my opinion!) to move the flap lever forward as standard part of the spin recovery procedu In nost gliders (certainly all Schleicher ones), it is nearly impossible with positive flaps NOT to exceed the Vne for this flap setting during the recovery. And pulling significant G with too-positive flap setting is the best way to induce extremely high torsional load on the wing... with all its consequences. At the speeds during the recovery even the most negative flap setting won't lead to a secondary stall. Bye Andreas |
On Mon, 11 May 2009 16:07:29 -0700 (PDT), sisu1a
wrote: Actually flap settings are touched on in my first $0.02 I pitched in 9 posts ago... Hey... here in Europe we only move flaps positive and flaps negative, we don't retract them... we don't even know these fowler type things (apart from the ones on this Blanik thing)... ![]() although I make no mention of negative flaps I simply state that retracting them hastens the recovery process in it, and that it was probably not specific to V tails... The Fowler flaps on my Sisu had 0-20 deg, but no neg... but- flap setting as a concept was at least mentioned ![]() ![]() Let's wait tll the first one points out to retract the Schempp-Hirth type airbrakes due to structural reasons... Bye Andreas |
On Tue, 12 May 2009 01:27:30 +0200, John Smith
wrote: With the ASK-21 you can find yourself in a sudden inverted spin if you push the stick fully forward. So far I didn't dare to try this... ![]() Bye Andreas |
On Tue, 12 May 2009 01:25:24 +0200, John Smith
wrote: It may quicken up the recovery, but JAR-22 requires a sailplane to recover with any flap setting. Indeed - but many gliders who are still popular were designed before JAR-22. I'm always amazed about how much easier the ASW-27 handles in this regard compared to a, say, ASW-20. Bye Andreas |
At 23:54 11 May 2009, Andreas Maurer wrote:
On Tue, 12 May 2009 01:25:24 +0200, John Smith wrote: It may quicken up the recovery, but JAR-22 requires a sailplane to recover with any flap setting. Indeed - but many gliders who are still popular were designed before JAR-22. I'm always amazed about how much easier the ASW-27 handles in this regard compared to a, say, ASW-20. Bye Andreas Andreas is correct, the ASW17 was extremely reluctant to recover from a spin in anything above 0 flap and if it did recover the flap speed would be exceeded in the recovery a loose loose situation. I suspect for this reason the spin recovery action was: 1 Flaps to a non positive setting 2 Full opposite rudder 3 Pause 4 Stick progressively forward until the spinning stops 5 Recover I have never flown a Nimbus but I am told it is much the same. The pause between the application of rudder and moving the stick forward is frequently ommitted in modern teaching but there are valid reasons for it's inclusion. Having said that in most gliders, Puchaz excepted, as soon as the back pressure is released the glider stops spinning. The only glider I have ever flown that spun properly was the Slingsby Swallow which would wang round like a good un until the full recovery action was taken. |
Darryl Ramm wrote:
On May 11, 3:19 pm, Andreas Maurer wrote: I guess pretty many pilots here have flown the ASW-20 - recovering it with setting 4 (zhermal setting) with a medium to rearward CG ca take up to 2 turns, but with flaps 1 (fully negative) recovery takes at maximum 0.75 turns. Bye Andreas Not surprising at all - it would surprise me if anybody really wants to teach this. Lets see - - A desire to teach a standardized recovery - Don't distract people with grabbing for a handle while under stress (or if not stress just physically being thrown around a little) - Likelyhood of grabbing the wrong handle (esp. if transitioning from another ship) and just moving it (i.e. opening full spoilers) - With full negative flap what happens to increased likelihood of entering another/reverse spin if the pilot recovers too "hard"? Wouldn't the chance of another/reverse spin be even greater in a positive flap setting if the pilot recovers too "hard"? What I noticed in my ASW 20 and my ASH 26 E is going to negative flap immediately stopped the spin and there is nothing to "recover" from except a "mild" nose down attitude. I haven't tried waiting more than a half turn; perhaps waiting a full turn or more might be different, but I'm only concerned about immediate recovery attempts. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#29
On Tue, 12 May 2009 01:25:24 +0200, John Smith wrote: It may quicken up the recovery, but JAR-22 requires a sailplane to recover with any flap setting. Indeed - but many gliders who are still popular were designed before JAR-22. I'm always amazed about how much easier the ASW-27 handles in this regard compared to a, say, ASW-20. Bye Andreas Thanks to all who have contributed to answering my original question. I am especially interested in the comments about the ASK-21, especially in reference to changes in how it behaves as the spin continues through more than one or two turns. My club has one with the spin kit and we look forward to practicing but it is better to do so fully prepared with knowledge of the experiences others have had. Thanks! |
#30
In message , Andreas Maurer
writes On Mon, 11 May 2009 09:53:56 -0700 (PDT), bildan wrote: This led to the NACA standard spin recovery technique which called for anti-spin rudder while holding full up elevator until the auto- rotation slowed and only then applying down elevator. The reasoning was that full up elevator exposed more of the rudder to high energy flow. Trying this method in nearly any glider is a very safe way to get killed. I am pretty sure that most glasss gliders of the least 40 years will not recover from a spin if the elevator is held fully up during the recovery attempt - they simply are not going to stop rotation quickly enough. I heard about some folks spinning a K21 with the weights kit, and they nearly ended up bailing out. Later the instructor concluded that they hadn't been pushing the stick far enough forwards during the unsuccessful attempts. -- Surfer! Email to: ramwater at uk2 dot net |
Spin Recovery Training Before First Solo? | [email protected] | Piloting | 16 | September 9th 07 03:48 AM |
Spin Recovery Training Before First Solo? | [email protected] | Piloting | 1 | September 5th 07 09:51 PM |
SR22 Spin Recovery | gwengler | Piloting | 9 | September 24th 04 07:31 AM |
inverted spin recovery explanation | Alan Wood | Aerobatics | 18 | August 19th 04 03:32 PM |
Edelweiss - Spin recovery procedures | Uri Saovray | Soaring | 7 | March 15th 04 12:41 AM |
