ATC Radar Question
Old June 12th 09, 01:53 AM posted to rec.aviation.piloting
Jackie
Default ATC Radar Question
I understand that ATC radar uses an encoding altimeter and a transponder
operating with Mode C to determine an aircraft's altitude. Let's forget
about Mode C for a moment and switch to Mode A only or just a primary
return.
If an aircraft is at 18,000 ft (approx 3 nm) and 3 nm away from the
radar antenna, as seen on a map, how does the radar correct for slant
distance when distance is displayed (e.g. using concentric circle
distance markers on the scope or relative to a known distance, such as a
marker on the display)?
In other words how does the radar know that the aircraft is actually 3
nm away laterally and not 4.25 nm (approx slant distance at that altitude)?
below the radar Philip Stroh Aviation Photos 31 November 27th 06 03:12 PM
Integrating onboard weather radar data with satellite-fed Doppler radar [email protected] General Aviation 3 January 9th 05 08:57 PM
Question about the F-22 and it's radar. Scott Ferrin Military Aviation 128 June 13th 04 01:23 AM
Yet another "Radar Required" question. Roy Smith Instrument Flight Rules 14 April 27th 04 05:07 PM
F15E Radar question. Bill Silvey Military Aviation 5 August 30th 03 06:17 PM
