That would be a pass for me!
I would stop right there...... For a friend here.... he passed on 3 spinner cracks on a rental 172. One crack was 1 1/2 in long. They (others) continued to fly the aircraft for another week before the spinner was removed Dave .. On Mon, 27 Jul 2009 14:01:33 -0400, Gezellig wrote: On Mon, 27 Jul 2009 00:04:45 -0700, Ron Garret wrote: Depends on what counts as "significant deferrment" and what counts as "pre-flight". Which begs this question. How bad does a wood prop have to be to cancel a flight? I was going to take a flight in a DA20 which has a twin blade Sensenich W69EK7-63 wood propeller. On pre-flight, the prop was chipped in several places, no runs but then its painted or enameled white. http://www.controller.com/images/Con...e/80614723.jpg The edges were so rough I was concerned about catching a splinter. I passed. And you? |
Gezellig wrote:
How bad does a wood prop have to be to cancel a flight? I was going to take a flight in a DA20 which has a twin blade Sensenich W69EK7-63 wood propeller. On pre-flight, the prop was chipped in several places, no runs but then its painted or enameled white.... Oh boy, this thread is bringing the memories back - of a low level local VFR joy ride in the passenger seat - and we heard a pan call on the local frequency citing engine problems - then straight ahead, and descending quite fast was a 4 seater - with just HALF a prop slowly rotating - and down it went - under a power pylon at the edge of a field - which had us on the edge of our seats - but it rolled to a halt, and we saw two adults and two kids pile out. We called the home tower with location and loitered til a police car or ambulance arrived. It turned out a wood prop had been overtightened by a prestige big name FBO at Coventry - and the facility lost their prop authorization on the basis of that screw up..... Brian W |
On Jul 27, 12:41*am, D Ramapriya wrote:
Has any of you has ever discovered something during the pre-flight inspection that necessitated a significant deferrment of your flight plan or a cancelation altogether? Just curious, that's all. Thanks, Ramapriya Well, I found a flat tire, lots of water in the fuel tanks (early M20J fuel tank caps were hard to put on correctly), bird's nest in the engine campartment that took a while to remove, pitot tube not hot, bad nick in the prop. . . That's all that comes to mind with about 2000 hours TT. Prior to take off I found a broken carb heat cable in an M20C, one mag not working, Nav radio not working, I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. |
![]() "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn |
"vaughn" wrote in message
... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. On another occassion I saw one of the twin engine air taxis, I don't recall whether it was a Navajo or a C402, pull away with a rudder lock still in place. There was no radio available and no way to get a motor vehicle onto the ramp quickly enough; but the tower had a listed telephone number on that field, so I was able to call them before he got to the runway. Peter |
"Peter Dohm" wrote: "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. Heh, funny you should mention that. I once forgot to remove an orange cone that the FBO had "helpfully" placed in front of the prop. It's amazing what a propeller -- even one not moving at full speed -- can do to an orange cone. That one set me back quite a bit as well. rg |
On Mon, 27 Jul 2009 14:25:04 -0700, Ron Garret wrote:
In article , "Peter Dohm" wrote: "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. Heh, funny you should mention that. I once forgot to remove an orange cone that the FBO had "helpfully" placed in front of the prop. It's amazing what a propeller -- even one not moving at full speed -- can do to an orange cone. That one set me back quite a bit as well. rg Are cones expensive or are your poor? Franklin |
In article , lefty133
@bellsouth.net says... "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. How on earth did your pre-flight (spin the prop over?) not catch that one! ![]() -- Duncan |
On Tue, 28 Jul 2009 16:48:00 +1200, Dave Doe wrote:
In article , lefty133 @bellsouth.net says... "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. How on earth did your pre-flight (spin the prop over?) not catch that one! ![]() It is obvious that Vaughn is very inexperienced. |
"Dave Doe" wrote in message
... In article , lefty133 @bellsouth.net says... "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. How on earth did your pre-flight (spin the prop over?) not catch that one! ![]() -- Duncan It was a bit more than 25 years ago and I've forgotten the bit of trivia that led to the error, other than the fact that I was only there to exercise the engine and not to fly; but it was also a good illustration of why maintenance operations need the same attention to detail and safety as flight operations. The cowling shape of the particular aircraft allowed a cable type lock to remain partially hidden from view, when seated in the left front, and my solution was to add a bright yellow wrapping with tassels--so that any repetition would be obvious from inside the cabin and also nearly impossible to forget on the walkaround. Peter |
annual inspections | [email protected] | Soaring | 1 | October 20th 07 01:08 AM |
100 Hour Inspections | Judah | Piloting | 26 | December 1st 06 02:30 PM |
Homebuilt Inspections | john smith | Home Built | 8 | December 25th 04 02:20 PM |
Time Measurement for Inspections | O. Sami Saydjari | Owning | 15 | April 7th 04 05:26 AM |
Pre-buy inspections | Paul Folbrecht | Owning | 12 | March 1st 04 12:27 AM |
