#21
"Stealth Pilot" wrote (I think the problems I'm having with my truss fuselage are tipping me over the edge :-) ohhhhhh bugger column bending. why cant you just build things heavy ) Are you working on your Tailwind aeroplane, or a different project? -- Jim in NC |
Stealth Pilot wrote:
I'm a lousy dentist. what's the project? Stealth Pilot I'm converting auto electronic ignition parts for use on old motorcycles. I will be making a reluctor to replace the points cam, backing plates and mounts for the pickups. Tony |
"Stealth Pilot" wrote in message ... -------------much snipped----------- but you hafta admit that aerospace has way cooler x-prizes. there is one for a home made space vehicle plonked on the moon with a home made rocket. you hafta remotely drive up to some expensive nasa thingy on the moon and spray graffiti on it. I think thats what the task is... (I think the problems I'm having with my truss fuselage are tipping me over the edge :-) Tthat does seem just remotely possible... :-) :-) ;_) Peter |
On Aug 17, 3:19*pm, Anthony W wrote:
.. *I will be making a reluctor to replace the points cam, backing plates and mounts for the pickups. ---------------------------------------------------------------------------------------------- Dear Tony, Please don't read this the wrong way... After introduction of Hall Effect transistorized switches in the 1960's I spent two years developing an ignition system which used such switches to replace the points on VW ignition systems. By the time I had it perfected it was available as a plug-in module for about $50 :-) Mentioned here because magnetic reluctor triggering was one of the methods I considered and discarded. ------------------------------------------------------- Since you are working with motorcycle-scale components the odds are that a small lathe will do about as well as a large one. I've a 7x10 that is more than large enough to let kids help their grandpa. These are real parts (valve guides) turned out by real kids, who are learning on a real lathe. It just happens to be quite a bit smaller than the one grandpa is using. In my opinion, you need to be wary of lathes & mills that are CONVERTED to CNC. There are now a couple of small mills that are designed for CNC from the ground up. Not sure where I saw them... in one of the trade journals. As I recall their pricing reflected their origins, which seems fair: I've never found any 'bargain' tools that were worth a damn. -R.S.Hoover |
On Mon, 17 Aug 2009 19:04:51 -0700 (PDT), Veeduber
wrote: Since you are working with motorcycle-scale components the odds are that a small lathe will do about as well as a large one. I've a 7x10 that is more than large enough to let kids help their grandpa. These are real parts (valve guides) turned out by real kids, who are learning on a real lathe. It just happens to be quite a bit smaller than the one grandpa is using. lotsa good work is done on a Taig. : I've never found any 'bargain' tools that were worth a damn. -R.S.Hoover ditto. while I have a chinese mill that performs flawlessly chinese tooling is crap. mainly because the alloy the component is made from is never the correct or optimum alloy for the part. drill bits, insert cutters, milling cutters made in china are just utter crap quality. they wear out at an astonishing rate. buying any of them is an absolute waste of money. I relented a while ago and bought a chinese tap and die set to do a job needing 12" unc. I have to admit that the die produced an absolutely schmick thread ....but it was a full millimeter under diameter. it was bloody hard to screw on too. my vermont american tap and die set in UNF has never failed me for aviation work. the 1/2"unc was for a screw trim adjuster on a sonerai. the Sutton (Australian) tap and die produced flawlessly mating threads of the correct diameter. btw Anthony an old lathe like a South Bend, if it is good condition is a very good buy. my own lathe is a Hercus clone of the southbend produced just after the second world war. it wouldnt pass an occ. health and safety audit because of the exposed V belts but it is absolutely superb for the aviation machining I do. Stealth Pilot |
On Mon, 17 Aug 2009 14:11:58 -0400, "Morgans"
wrote: "Stealth Pilot" wrote (I think the problems I'm having with my truss fuselage are tipping me over the edge :-) ohhhhhh bugger column bending. why cant you just build things heavy ) Are you working on your Tailwind aeroplane, or a different project? eventually I will get and do a reverse engineer of the Tailwind. mine is 25 years/680 hours old so I dont think there is too much to worry about. the current project is a single seat taildragger ultralight as a learning tool. I accidently hit a shape/layout for a very conventional design that has superb weight and balance figures so I've been motivated to work the design to completion and build one. persistence is the key to success in aviation and structural design. trouble is it makes you feel so bloody dumb while you are persisting through the learning difficulties. :-) if it wasnt for the patience of a very schmicked up aero engineer I think I'd be screwed. the japanese have a saying "so much data so little understanding." my years of reading have represented just so much data! my friend's understanding and crystal clear insight is making this happen, slowly. btw Jim. I have a computed drag curve for the tailwind. you will know the classic diagram of induced and parasitic drag that has induced reducing in a curve to nothing while parasitic increases in a curve to maximum. the plot of resultant drag sits above the crossed lines as a U shape. it's a classic representation. for the W8 tailwind that classic U shape is centred on 80 knots. what that means is that on approach if you slow down to 60 knots you get in the area of rapidly increasing sink (which is why you approach at 70 knots) you havent just entered the "back side of the drag curve", you've always been in it. At 65 knots you are entering the vertical part of the left side of the U. at 70 knots you are at the bottom left corner. tailwinds *are* happiest flying fast. Stealth Pilot |
On Mon, 17 Aug 2009 19:04:51 -0700 (PDT), Veeduber wrote: Since you are working with motorcycle-scale components the odds are that a small lathe will do about as well as a large one. I've a 7x10 that is more than large enough to let kids help their grandpa. These are real parts (valve guides) turned out by real kids, who are learning on a real lathe. It just happens to be quite a bit smaller than the one grandpa is using. lotsa good work is done on a Taig. : I've never found any 'bargain' tools that were worth a damn. -R.S.Hoover ditto. while I have a chinese mill that performs flawlessly chinese tooling is crap. mainly because the alloy the component is made from is never the correct or optimum alloy for the part. drill bits, insert cutters, milling cutters made in china are just utter crap quality. they wear out at an astonishing rate. buying any of them is an absolute waste of money. I relented a while ago and bought a chinese tap and die set to do a job needing 12" unc. I have to admit that the die produced an absolutely schmick thread ....but it was a full millimeter under diameter. it was bloody hard to screw on too. my vermont american tap and die set in UNF has never failed me for aviation work. the 1/2"unc was for a screw trim adjuster on a sonerai. the Sutton (Australian) tap and die produced flawlessly mating threads of the correct diameter. btw Anthony an old lathe like a South Bend, if it is good condition is a very good buy. my own lathe is a Hercus clone of the southbend produced just after the second world war. it wouldnt pass an occ. health and safety audit because of the exposed V belts but it is absolutely superb for the aviation machining I do. Stealth Pilot A few years ago I bought a Chinese metric tap and die set to fill the gaps in my collection. The tap handle was nice. I'd sure like to know to what standard the taps and dies were made. The finish was rough and the dimensions were wrong. I kept the tap handle. One of the drawbacks to owning Huot dispensers for mills, taps, drills, reamers etc is one is aware of sizes one doesn't have. Once in awhile I fill the empty slots knowing full well I may never use those particular tools. Dan, U.S. Air Force, retired |
btw Anthony an old lathe like a South Bend, if it is good condition is a very good buy. my own lathe is a Hercus clone of the southbend produced just after the second world war. it wouldnt pass an occ. health and safety audit because of the exposed V belts but it is absolutely superb for the aviation machining I do. Stealth Pilot You won't find a good used South Bend lathe around here or at least not what I've seen. By the time they come up for sale, they're more than a little worn out. Tony |
#29
... On Mon, 17 Aug 2009 14:11:58 -0400, "Morgans" wrote: "Stealth Pilot" wrote (I think the problems I'm having with my truss fuselage are tipping me over the edge :-) ohhhhhh bugger column bending. why cant you just build things heavy ) Are you working on your Tailwind aeroplane, or a different project? eventually I will get and do a reverse engineer of the Tailwind. mine is 25 years/680 hours old so I dont think there is too much to worry about. the current project is a single seat taildragger ultralight as a learning tool. I accidently hit a shape/layout for a very conventional design that has superb weight and balance figures so I've been motivated to work the design to completion and build one. persistence is the key to success in aviation and structural design. trouble is it makes you feel so bloody dumb while you are persisting through the learning difficulties. :-) if it wasnt for the patience of a very schmicked up aero engineer I think I'd be screwed. the japanese have a saying "so much data so little understanding." To my eye, this looks like either a German or French saying; but I suppose that many others will recognize it as their own as well. (In some business oriented groups, the related saying is: "paralysis by analysis." my years of reading have represented just so much data! my friend's understanding and crystal clear insight is making this happen, slowly. btw Jim. I have a computed drag curve for the tailwind. you will know the classic diagram of induced and parasitic drag that has induced reducing in a curve to nothing while parasitic increases in a curve to maximum. the plot of resultant drag sits above the crossed lines as a U shape. it's a classic representation. for the W8 tailwind that classic U shape is centred on 80 knots. what that means is that on approach if you slow down to 60 knots you get in the area of rapidly increasing sink (which is why you approach at 70 knots) you havent just entered the "back side of the drag curve", you've always been in it. At 65 knots you are entering the vertical part of the left side of the U. at 70 knots you are at the bottom left corner. tailwinds *are* happiest flying fast. Stealth Pilot The tailwind is amoung the all time standouts in low parasitic drag, and the rapid rise of induced drag above the stall contributes to the short field landing performance. I lack any personal experience, but have been told that the short field performance is excellent. Peter |
#30
"Peter Dohm" wrote in message ... "Stealth Pilot" wrote in message ... On Mon, 17 Aug 2009 14:11:58 -0400, "Morgans" wrote: "Stealth Pilot" wrote (I think the problems I'm having with my truss fuselage are tipping me over the edge :-) ohhhhhh bugger column bending. why cant you just build things heavy ) Are you working on your Tailwind aeroplane, or a different project? eventually I will get and do a reverse engineer of the Tailwind. mine is 25 years/680 hours old so I dont think there is too much to worry about. the current project is a single seat taildragger ultralight as a learning tool. I accidently hit a shape/layout for a very conventional design that has superb weight and balance figures so I've been motivated to work the design to completion and build one. persistence is the key to success in aviation and structural design. trouble is it makes you feel so bloody dumb while you are persisting through the learning difficulties. :-) if it wasnt for the patience of a very schmicked up aero engineer I think I'd be screwed. the japanese have a saying "so much data so little understanding." To my eye, this looks like either a German or French saying; but I suppose that many others will recognize it as their own as well. (In some business oriented groups, the related saying is: "paralysis by analysis." my years of reading have represented just so much data! my friend's understanding and crystal clear insight is making this happen, slowly. btw Jim. I have a computed drag curve for the tailwind. you will know the classic diagram of induced and parasitic drag that has induced reducing in a curve to nothing while parasitic increases in a curve to maximum. the plot of resultant drag sits above the crossed lines as a U shape. it's a classic representation. for the W8 tailwind that classic U shape is centred on 80 knots. what that means is that on approach if you slow down to 60 knots you get in the area of rapidly increasing sink (which is why you approach at 70 knots) you havent just entered the "back side of the drag curve", you've always been in it. At 65 knots you are entering the vertical part of the left side of the U. at 70 knots you are at the bottom left corner. tailwinds *are* happiest flying fast. Stealth Pilot The tailwind is amoung the all time standouts in low parasitic drag, and the rapid rise of induced drag above the stall contributes to the short field landing performance. I lack any personal experience, but have been told that the short field performance is excellent. Peter Peter another that I found during my stint with DoD. "Get the money spent. We can find out what we did wrong later." |
| Thread Tools | |
| Display Modes | |
| The Home-made Home-builders Engine | Veeduber[_2_] | Home Built | 37 | June 12th 09 05:22 AM |
| F-111 comes home | Don Pyeatt | Aviation Photos | 1 | May 6th 08 12:26 AM |
| Foamy's Home Away From Home | Michael Baldwin, Bruce | Products | 0 | December 22nd 06 12:14 PM |
| Exclusive Custom Home Plans, and Essential information about building your New Home | orange tree | Home Built | 4 | November 20th 05 05:37 PM |
| Welcome Home | Meade Spotts | Naval Aviation | 0 | March 11th 04 02:17 AM |
