Emergency Descents with ATC COMS - Video
Old August 23rd 09, 07:52 PM posted to rec.aviation.piloting
Robert Moore
Default Emergency Descents with ATC COMS - Video
a wrote
I'm wondering why the 60 degree bank 30 degree pitch requirement of a
'chute for all occupants doesn't apply?
Because there was no one else on board except for a crewmember.
(c) Unless each occupant of the aircraft is wearing an approved
parachute, no pilot of a civil aircraft carrying any person (other than
a crewmember) may execute any intentional maneuver that exceeds—
(1) A bank of 60 degrees relative to the horizon; or
(2) A nose-up or nose-down attitude of 30 degrees relative to the
horizon.
(d) Paragraph (c) of this section does not apply to—
(1) Flight tests for pilot certification or rating; or
(2) Spins and other flight maneuvers required by the regulations for any
certificate or rating when given by—
(i) A certificated flight instructor;
If you do not have a copy of the U.S. Aviation Regulations, they can be
found he
http://www.landings.com/evird.acgi$pass*58994814!_h-www.landings.com/
_landings/pages/regulations.html
Bob Moore
Old August 23rd 09, 10:58 PM posted to rec.aviation.piloting
a[_3_]
On Aug 23, 2:52*pm, Robert Moore wrote:
a wrote
I'm wondering why the *60 degree bank 30 degree pitch requirement of a
horizon.
found he
Bob Moore
Thanks. The part I read did not have the parans excluding crew
members. It's a non issue for me, My m20J does not (intentionally) see
anything like those pitch and bank limits.
I still maintain the fastest way down is a strong slip. As somone
mentioned, for non preasurized airplanes, the most likely need to get
down fast is a fire, and a slip may keep the flames away from the
cabin. Mooney's slip really well but losing energy while flying
coordinated is a chore -- come in hot for a landing and you'll float
forever. I''ll have to try a turn while slipping sometime although a
turn into the low wing side makes it a little more coordinated and I
would be reluctant to try to turn into my blind (high wing) side.
Old August 25th 09, 02:12 PM posted to rec.aviation.piloting
Ricky
On Aug 23, 8:17*am, Robert Moore wrote:
Jeeze...damn amateurs.......
Jeeze...grumpy, retired, ex-military, old men.......lighten up. Your experience and knowlege is very valuable here, but it would be much more well received with some grace and kindness.
Bob Moore
P-3B
P-3, huh? I am cutting my A&P teeth on a rehab of a P-3, which is what
my company does. My first P-3 is about to take it's maiden flight
after a 3 year rebuild, and after we get all the tank leaks sealed
(again).
Ricky
Old August 25th 09, 03:27 PM posted to rec.aviation.piloting
Robert Moore
When someone "preaches" as much BS as Flaps_50! did in his post, someone
needs to call it BS in no uncertain terms.
If Flaps_50! wants to instruct pilots, maybe he should study some more
himself.
Bob Moore
CFIing since 1970
Old August 31st 09, 02:08 PM posted to rec.aviation.piloting
Flaps_50!
Ah, I see YOU say BS 'cos you think the newsgroup is american. LOL
Cheers
Old August 25th 09, 03:36 PM posted to rec.aviation.piloting
a[_3_]
Bob Moore
P-3B
(again).
Ricky
The M20J is a wet wing tank sealed with something that was found to
like to disolve in what ever is added to 100 octane low lead. We had
to fix the leaks a couple of times in an early M20J, I expect the
problem has been solved a long time ago. What is the nature of the
leaks your P-3 has: inital sealant a little better than bubble gum?
Old August 27th 09, 05:05 PM posted to rec.aviation.piloting
Ricky
Bob Moore
P-3B
(again).
Ricky
Well, you may know the P-3 is a wet-wing also, with a wet belly tank,
too, just behind the bomb bay. The sealing procedure is very, very
extensive after all external and internal reapairs & work have been
done on the wings and belly. Every single Hi-Lok, rivet, Cherry-Max,
bolt, screw, plank, doubler, tripler, etc, etc. is a potential leak.
So, there are literally hundreds, perhaps thousands, of potential
escape routes for the Jet-A. The sealant we use is fine, great,
actually, but with so many potential leaks, it is simply impossible to
aassure the sealant job is leak-proof in every single place.
We pressurised the tanks for the first time 2 weeks ago & there were
several leaks, albeit small ones. This means we must find the leak,
then do a re-sealant job to that area. After two weeks we finally have
almost 100% integrity with the fuel tanks. We have started engine runs/
testing and the plane will go to the paint shop soon, then back into
service until the ancient (but wonderful) bird is retired or replaced
by 737s.
Ricky
Old August 31st 09, 11:44 AM posted to rec.aviation.piloting
Flaps_50!
On Aug 24, 1:17*am, Robert Moore wrote:
"Flaps_50!" wrote
You were conducting aerobatic flight.
TRUE
Breaking the law is one thing
IN WHAT RESPECT
but are you certified for aerobatics?
PILOTS DON'T HAVE TO BE CERTIFIED FOR AEROBATICS in the USofA
What about your aircraft?
When properly equipped, the B23 and C23 are approved for limited
aerobatics. (Wikipedia)
And was it equipped and what are those limits?
This could get you killed.
Normal takeoffs and landings kill a lot of pilots.
Not intentionally.
Let me remind you that aerobatics are maneuvers
outside those required for "normal" flight FAR 91.303.
LET ME REMIND YOU.... that the Sundowner is approved for Spins.
Irrelevant. That's not the point and you know it.
Google "Beechcraft Sundowner Spins" and you will find a reference
to "The Light Airplane Pilot's Guide to Stall/Spin Awareness By Rich
Stowell". I would suggest that you read the paragraphs on the following
web page.http://books.google.com/books?id=i8r...A304&lpg=PA304
&dq=Spins+in+sundowner&source=bl&ots=u0xxM-hDbY&sig=r8g_VtQN_AjTS8Cql-
tWtg0geRo&hl=en&ei=KD2RSo_BKoH8tge9p6TPBA&sa=X&oi= book_result&ct=result&
resnum=10#v=onepage&q=&f=false
Bob Moore
ATP B-727, B-707, L-188
USN S-2F , P-2V , P-3B
Flight Instructor ASE-I
PanAm (retired)
Jeez is that supposed to impress me or is it the PanAm (retired) bit?
Look up "appeal to authority" as a logical fallacy.
Cheers
Old August 23rd 09, 04:49 PM posted to rec.aviation.piloting
Blanche
I was taught a steep spiral for getting down really fast in a very
small area.
I don't have the Sundowner POH but I just checked my Musketeer
POH - 2.9, Maneuver Limits: Bank Angles no more than 60 deg.
Of course on the following page there's the remark
"Minimum flight crew: One (1) pilot"
Old August 23rd 09, 05:02 PM posted to rec.aviation.piloting
BeechSundowner
small area.
In my plane it's placarded allowed commercial maneuvers (Chandelles,
lazy eights come to mind). I do need to check the POH.to double
check the bank limitations, but I don't remember seeing such a
limitation. VNE is 152 knots.
I do remember seeing the same remark minimum flight crew of one
pilot. I guess that is the legalese way of saying that a pre-solo
student can't fly the plane solo legally LOL
Light gun work with ATC COMS - Video [email protected] Instrument Flight Rules 25 July 19th 09 12:07 AM
Light gun work with ATC COMS - Video [email protected] Piloting 5 July 15th 09 03:20 AM
Pop up IFR clearance with ATC COMS - Video [email protected] Piloting 0 November 15th 08 05:05 PM
Pop up IFR clearance with ATC COMS - Video A Lieberma[_2_] Owning 0 November 15th 08 05:04 PM
Pop up IFR clearance with ATC COMS - Video [email protected] Instrument Flight Rules 0 November 15th 08 05:04 PM
