Scared of mid-airs
Old August 6th 06, 05:44 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.military
Steven P. McNicoll[_1_]
Default Scared of mid-airs
"Ed Rasimus" wrote in message
Of course.
How else would a pilot without an instrument rating file a flight
plan?
Yes, I know, I was trying to help Larry understand.
  #302
Old August 6th 06, 05:46 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.military
"Jose" wrote in message
m...
Well, an IFR flight plan is a little more than that because it causes a
clearance to be issued before I take off (at least in controlled
airspace).
Not so. Lots of IFR flight plans are filed without causing any clearance to
be issued.
  #303
Old August 6th 06, 05:49 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.military
"Larry Dighera" wrote in message
Are there IFR and VFR flight plans?
Yes, but our resident fighter pilot asserts:
On Fri, 04 Aug 2006 16:34:22 GMT, Ed Rasimus
wrote in
Regardless, the flight plan type for the military is IFR.
If that were true, it prompts my questioning the need for VFR MTRs.
But he wrote that in response to your question. So what prompted you to ask
it?
  #304
Old August 6th 06, 06:24 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.military
Jose[_1_]
A flight plan is an expression of intention to fly.
Obviously you are being difficult. "Flying on an IFR flight plan"
implies either uncontrolled airspace, or a clearance. The former is an
invitation to an FAA hearing. The latter implies ATC coordination.
Guess which one I'm referring to.
When the flight launches, ATC then provides services.
Exactly.
Did you miss the part where I said ALL MILITARY FLIGHTS ARE OPERATING
ON FLIGHT PLANS AND IFR?
No. But you seem to be dodging the issue by hiding behind stuff like "A
flight plan is an expression of intention to fly." Did you miss the
part where you yourself said "Training time along an MTR, within a MOA,
in restricted airspace, or on a range is usually done without ATC
involvement."? The IFR I am familiar with always has ATC involvement.
Are you on an ATC clearance at that point? Are you on an ATC clearance
in an MTR (IR or VR)?
...they operate together and the sky does not seem
to be raining airplanes.
And, the military is NOT "blaming anybody who happens to be in the way
for the MAC."
Who was responsible for the MAC where the cessna, while attempting to
turn away, was speared by an F-something at 350 knots or so?
Yes, one example, but an egregious one in my book, and one you seem to
be defending.
Ever been on an airliner?
Ever flown a bug smasher?
Jose
The monkey turns the crank and thinks he's making the music.
  #305
Old August 6th 06, 06:25 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.military
Jose[_1_]
be issued.
All the IFR flight plans I filed caused a clearance to be issued before
I took off. (for the other ones I didn't take off).
Jose
  #306
Old August 6th 06, 06:27 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.military
m...
Obviously you are being difficult. "Flying on an IFR flight plan" implies
either uncontrolled airspace, or a clearance. The former is an invitation
How is the former an invitation to an FAA hearing?
  #307
Old August 6th 06, 06:30 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.military
m...
All the IFR flight plans I filed caused a clearance to be issued before I
You didn't limit your statement to IFR flight plans that you filed.
  #308
Old August 6th 06, 06:32 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.military
Larry Dighera
On Sun, 06 Aug 2006 16:49:53 GMT, "Steven P. McNicoll"
wrote in
. net:
wrote in
it?
It was largely rhetorical.
If Mr. Rasimus' assertion, that the flight plan type for the military
is IFR is correct, and MTRs are created for military use, why are
there VFR MTRs? Presumably the military won't be operating VFR on VFR
MTRs.
  #309
Old August 6th 06, 07:08 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.military
Jose[_1_]
There was a case where a pilot took off on an IFR flight plan in
uncontrolled airspace (yes I'm aware of the uncontrolled airspace below
700') and was cited for careless and reckless. I don't remember the
details, but somebody here will probably recognize the case.
Jose
  #310
Old August 6th 06, 07:09 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.military
Jose[_1_]
You are correct. I did limit it to "before I take off", but I suppose
that doesn't quite pass muster here.
Jose
UBL wants a truce - he's scared of the CIA UAV John Doe Aviation Marketplace 1 January 19th 06 08:58 PM
The kids are scared, was Saddam evacuated D. Strang Military Aviation 0 April 7th 04 10:36 PM
Scared and trigger-happy John Galt Military Aviation 5 January 31st 04 12:11 AM
