#331
This paper is related because it gives convincing data that the current
warming is not a natural event, as opposed to the MWP, which *had* to be natural: http://www.pnas.org/cgi/content/full/94/16/8370?ck=nck "The probability of the observed [modern] changes occurring through natural, as opposed to anthropogenic, causes appears to be exceedingly small. First, although a major ice age causes a larger temperature change than has happened so far in response to CO2, the temperature increase that occurred between 1920 and 1990 would have taken more than 2,000 years even at the historically rapid rate of the last deglaciation. During deglaciation, transient warming in the North Atlantic after a Heinrich event was faster (35), but there is no evidence for a Heinrich event during the last few centuries. Second, internal climate oscillations, shifts in storm tracks, and the like obviously can change local and regional climate by much larger amounts than observed in the hemispheric averages. These regional fluctuations appear to be superimposed on the general global trend. Additionally, such internal oscillations produce warm and cool regions that interchange over decade to century time scales (32, 36), but whose effects largely cancel in hemispheric averages. Third, while there is reasonable evidence for greater climate variability during the Holocene than has been observed during the period where instrumental data are available (37, 38), there is no evidence in the statistics that a major unidentified source of natural variation is present during the instrumental record. Such a source would have to mimic, perversely, either solar irradiance changes or the changes in atmospheric CO2 to cause the observed temperature changes and to be mistaken for them. Similarly, while mindful of the many caveats on data quality, spatial coverage, etc. given in ref. 1, the appearance of possible leap-year artifacts at a level below 10 mK in the residuals suggests that the data cannot be as untrustworthy as is occasionally implied. The residual temperature variation remaining once the known effects of precession, solar irradiance changes, and atmospheric CO2 concentration are removed bound unknown effects to about 200 mK peak-to peak in the hemispheric average series during the last century. Consider the null hypothesis that the observed temperature fluctuations and atmospheric CO2 levels are independent: The probability that the hemispheric temperatures would fluctuate purely by chance in such a way to produce the observed coherences with CO2 is exceedingly low. Given that the records encompass more than a century, the probability is so low that one would not expect to see such an event by chance during the age of the earth. The probability of the observed coherence between atmospheric CO2 and changes in the timing of the seasons shown in figure 13 of ref. 2 without a causal connection is similarly low. Consequently one must strongly reject the hypothesis of independence between atmospheric CO2 and temperature. The alternative hypothesis, that increasing levels of atmospheric CO2 plus a slight change in solar irradiance are causally responsible for the observed changes in temperature, in contrast, results in test statistics that are ordinary in every way. Because major changes in climate as a response to human use of fossil fuels have been predicted for more than a century (39, 40), their detection can hardly be considered surprising. " |
#332
![]() "Don Tabor" wrote in message ... On Fri, 13 Apr 2007 20:20:13 -0000, Jim Logajan wrote: Don Tabor wrote: I have seen NO refutations of the MWP that don't rely on asking for proof of a negative. "There are not enough records available to reconstruct global or even hemispheric mean temperature prior to about 600 years ago with a high degree of confidence. What records that do exist show is that there was no multi-century periods when global or hemispheric temperatures were the same or warmer than in the 20th century. ... So, because there were no instruments, the MWP did not happen? Norsemen raised cattle and grains in coastal Greenland. Grapes were grown in Scotland and higher in the Alps than is now possible. China enjoyed longer growing seasons and higher food production. None of those things is possible unless there was a prolonged period of much warmer weather. /except When Eric the Red led the Norwegian Vikings to Greenland in the late 900s, it was an ice-free farm country--grass for sheep and cattle, open water for fishing, a livable climate--so good a colony that by 1100 there were 3,000 people living there. Then came the Ice Age. By 1400, average temperatures had declined by 2.7 degrees Fahrenheit, the glaciers had crushed southward across the farmlands and harbors, and the Vikings did not survive. Such global temperature fluctuations are not surprising, for looking back in history we see a regular pattern of warming and cooling. From 200 B.C. to A.D. 600 saw the Roman Warming period; from 600 to 900, the cold period of the Dark Ages; from 900 to 1300 was the Medieval warming period; and 1300 to 1850, the Little Ice Age. During the 20th century the earth did indeed warm--by 1 degree Fahrenheit. But a look at the data shows that within the century temperatures varied with time: from 1900 to 1910 the world cooled; from 1910 to 1940 it warmed; from 1940 to the late 1970s it cooled again, and since then it has been warming. Today our climate is 1/20th of a degree Fahrenheit warmer than it was in 2001. /end In summary, it appears that the 20th century, and in particular the late 20th century, is likely the warmest the Earth has seen in at least 1200 years." Compare 1F with 2.7F Matt - "Why did 60 % of global warming since 1850 occur before 1940, when 80 % of the human-emitted carbon dioxide occurred after 1940? |
#333
![]() "Tony Cox" wrote in message ups.com... "Jim Logajan" wrote in message .. . "Tony Cox" wrote: A good model makes predictions that can be tested. One that I know of -- predicting increasing temperatures in the stratosphere -- it has apparently failed. The others involve climate variation which can't be measured until after the proponents have conveniently retired. This doesn't give one much confidence. Um, Dr. James Hansen is not yet retired. There's obvious controversy about Hansen discussed below this post. It seems from his work (which you quote) that he believes that the "emphasis on extreme scenarios may have been appropriate". Right there, thinking people ought to start wondering why a scientist -- supposedly objective -- thinks it right to overstate his case. Clearly, he *believes* in GW as a cause that needs to be presented even if the science doesn't support it. Further, he apparently decided (20 years ago) to extrapolate the data along several possible future paths and now pulls the least inaccurate one out from his metaphorical hat in a presentation before Congress as proof that somehow he was right all along. Ought I to be impressed? Perhaps he should retire. It seems that he has missed his calling as a stage magician. How do you account for the correlation between observations and the temperature changes his model predicted some 20 years ago? You mean how do I account for the correlation between CO2 and temperature changes in _one_ of the several possible future extrapolations developed by Hansen? Well, the first thing I'd say is that "correlation" doesn't imply "causation", as I"m sure you're aware. That they are linked is interesting. That they were counter-correlated between 1940 and 1975 is also interesting. That temperature also correlates with solar wind activity I also find fascinating. This indicates to me that the mechanisms for global warming are not yet well understood, despite the harangues of various self-aggrandizing Scientainers claiming otherwise. What's more, there is no correlation between Hansen's model and the subsequent 20 years, anymore than Jean Dixon predicted JFK getting shot. |
#334
.. . I think that there is a lot of "hot air" about "global warming" from many people on both sides of the issue. I had no interest in stating my opinion on the subject on this newsgroup and appealed for to people to drop the subject. Instead some people actually used my post as a starting point to continue the debate! Okay - so I decided since neither side had the mental discipline to take their arguments to relevant newsgroups (like alt.global-warming, sci.environment, sci.geo.meteorology, sci.math.num-analysis, and sci.physics.computational.fluid-dynamics) that I couldn't make the situation any worse. What a pompous, presumtious chump...and a fraud to boot. Geez...right down the path with Mike Hulme. |
#335
![]() "Don Tabor" wrote: Since at worst that will be a sea level rise of no more than a foot and a half (more likely, less than 6 inches), longer growing seasons and a longer bikini season, I don't see the point. At worst? What research can you cite to support this? IPCC Working Group 1 Technical Summary, section on sea level rise. The 23 inch rise reported in the Summary for Policymakers is the A1F1 scenario, which the scientists rejected as unrealistic, but the bureaucrats put back in. The TS gives a worst case 100 year rise as 17 inches. Further, the forever rise, the maximum without melting the Central Greenland and Antarctic Ice sheets, is only a meter. Since those ice sheets are above the snow line for any plausible temperature rise, it ain't gonna happen. Melting those would take a 68 degree F rise in temps, and the worst case temp prediction is only 11 degrees. Even at the 68 degree rise, it would take thousands of years to melt them. Cite? Graphs I've seen show it could take as little as a thousand years at an 8 deg. C rise, even if poorly understood melting acceleration processes are not included. "Models for continental ice melting are not yet capable of capturing the complex features that NASA satellites are now discovering in these ice fields. Important processes may be missing from models." http://www.aaas.org/news/releases/20...ppenheimer.pdf "Instead of melting slowly, like a giant ice cube, ice in Greenland and elsewhere seems capable of melting much more rapidly. Reports back from the field are noticing disturbing trends in this regard." http://cires.colorado.edu/science/gr...land/melt2005/ http://earthobservatory.nasa.gov/New...hp3?img_id=173 -- Dan C172RG at BFM |
#336
![]() "Matt Barrow" wrote: ...and a fraud to boot. Says the guy who posted a bogus cut-and-paste, and then wouldn't respond when called on it. Say, Matt, didn't you just claim that you'd KF'd Logajan a lonnngggg time ago? Fraud, indeed. -- Dan C172RG at BFM |
#337
Dan Luke wrote:
"Don Tabor" wrote in message And if a tree falls in the forest and no one is there to hear it, there is no sound. Correct, but irrelevant. No, that isn't correct. A tree falling in the forest makes sounds irrespective of whether anyone is able to hear the sound. Matt |
#338
![]() "Matt Whiting" wrote in message ... Dan Luke wrote: "Don Tabor" wrote in message And if a tree falls in the forest and no one is there to hear it, there is no sound. Correct, but irrelevant. No, that isn't correct. A tree falling in the forest makes sounds irrespective of whether anyone is able to hear the sound. I've always read that "sound" is the result of the brain processing vibrations transmitted by the aural organs, and that vibrations are nothing more than that: waves in the medium. There are plenty of these vibrations around us all the time that we don't perceive. When do they become sound? It's mostly a semantic argument, I suppose. -- Dan C172RG at BFM |
#339
Dan Luke wrote:
"Matt Whiting" wrote in message ... Dan Luke wrote: "Don Tabor" wrote in message And if a tree falls in the forest and no one is there to hear it, there is no sound. Correct, but irrelevant. No, that isn't correct. A tree falling in the forest makes sounds irrespective of whether anyone is able to hear the sound. I've always read that "sound" is the result of the brain processing vibrations transmitted by the aural organs, and that vibrations are nothing more than that: waves in the medium. There are plenty of these vibrations around us all the time that we don't perceive. When do they become sound? It's mostly a semantic argument, I suppose. Sound has many definitions, but most include something like this which speaks of vibrations in some medium. Detecting the vibrations isn't required in order for them to exist. http://www.thefreedictionary.com/sound If you close your eyes so that you can't see the sun, does that make the sun disappear from existence? Matt |
#340
![]() "Matt Whiting" wrote: Sound has many definitions, but most include something like this which speaks of vibrations in some medium. Detecting the vibrations isn't required in order for them to exist. http://www.thefreedictionary.com/sound If you close your eyes so that you can't see the sun, does that make the sun disappear from existence? No, but light is a physical thing entire of itself. It has photons. Anyway, you win. I can't think of a defensible exclusion of sound existing in the absence of a listener. -- Dan C172RG at BFM |
Spoof on Gore's movie has cool av scenes | R.L. | Piloting | 0 | May 25th 06 01:33 PM |
Spoof on Gore's movie has cool av scenes | R.L. | Aerobatics | 0 | May 25th 06 01:33 PM |
WTD:private pilot dvd course | orange | Owning | 0 | May 10th 06 05:46 AM |
Private Exam | Slick | Piloting | 8 | December 3rd 04 04:27 AM |
Private air strip..... yes or no??? | Wdtabor | Piloting | 81 | February 15th 04 08:15 AM |
