#31
Can I fly it at night?
"Jim Macklin" wrote in message news:Qf0vf.40490$QW2.8070@dukeread08... Field approval. No doubt there is an approved wind generator from the 1940s. The conversion should be a simple matter, even on a certificated airplane. Field approvals are not always so simple. |
#32
Michael Ware wrote:
Someone mentioned the LED anti-collision light, I know Whelen offers LED nav lights as well. Perhaps a call to them to find out what the draw would be for anti-collision and the 3 nav lights to make him legal and safe, then see what the different scenarios would be (i.e. a fully charged, 15 pound gel cell battery might run those lights reliably for 3 hours). The light retro would be a little costly, but it would be a simple system to maintain, versus introducing an alternator or generator, and a belt or propellor or whatever else you might need to run the thing. I would be surprised if Whelen has an STC for a '41 Aeronca, but it's worth a try. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
#33
True, when you are doing something strange, new and
unproven. Wind generators and pumps are common, have been in use for decades. The only change is that you might be changing from a DC generator to an alternator with a solid state rectifier for DC output. The mount design and location should already be present in approved data, for a heavier generator. So, a field approval should be well within the stricture of "at least as good as original." -- James H. Macklin ATP,CFI,A&P "Steven P. McNicoll" wrote in message ink.net... | | "Jim Macklin" wrote in message | news:Qf0vf.40490$QW2.8070@dukeread08... | | Field approval. No doubt there is an approved wind | generator from the 1940s. The conversion should be a simple | matter, even on a certificated airplane. | | | Field approvals are not always so simple. | | |
#34
A PMA/STC'd part can be installed and approved by a mechanic
and given a field approval by the local FAA. The parts will be performing the same purpose, weigh the same or less and make no change in structure, electrical load, or aerodynamics. Before I bought parts, I'd certainly ask the local federal inspector and be prepared to show why I thought it complied with 43.13 and CAR3/FAR23, etc. In general, such things as lights are approved generically, as replacements for any previously approved installation. Such hardware as autopilots and engine controls do require more extensive approval, but changing from [or adding] approved type lights is very minor, W&B being perhaps the most critical. -- James H. Macklin ATP,CFI,A&P "George Patterson" wrote in message news:Nj0vf.17936$Uf7.12519@trnddc01... | Michael Ware wrote: | Someone mentioned the LED anti-collision light, I know Whelen offers LED nav | lights as well. Perhaps a call to them to find out what the draw would be | for anti-collision and the 3 nav lights to make him legal and safe, then see | what the different scenarios would be (i.e. a fully charged, 15 pound gel | cell battery might run those lights reliably for 3 hours). The light retro | would be a little costly, but it would be a simple system to maintain, | versus introducing an alternator or generator, and a belt or propellor or | whatever else you might need to run the thing. | | I would be surprised if Whelen has an STC for a '41 Aeronca, but it's worth a try. | | George Patterson | Coffee is only a way of stealing time that should by rights belong to | your slightly older self. |
#35
"Jim Macklin" wrote in message news:Zk0vf.40492$QW2.9687@dukeread08... True, when you are doing something strange, new and unproven. Wind generators and pumps are common, have been in use for decades. The only change is that you might be changing from a DC generator to an alternator with a solid state rectifier for DC output. The mount design and location should already be present in approved data, for a heavier generator. So, a field approval should be well within the stricture of "at least as good as original." There is no original. An anticollision light installation on a 1941 Aeronca Chief IS something strange, new and unproven. |
#36
Jim Macklin wrote:
Field approval. No doubt there is an approved wind generator from the 1940s. The conversion should be a simple matter, even on a certificated airplane. Finding one may not be a simple matter. A friend of mine has an L-4. He was looking for the correct generator for years. Dunno if he ever found one. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
#37
Jim Macklin wrote:
In general, such things as lights are approved generically, as replacements for any previously approved installation. Right. Tell that to Jay Honeck (who spent several thousand dollars removing unapproved strobe lights from his Warrior). George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
#38
There may not have been an anti-collision light on the 1941
Aeronca, but there are on newer airplanes of the same general type. Strange and unproven would be a multi-colored smoke generator, with high output lasers and fireworks dispensers. Engineering drawings, FAA approved data, an general acceptable standards and practices exist for installation of lights that are PMA/TC parts and they can be installed very easily. The cost of parts, the extra utility gained by night flying vs. the expense and paperwork are the obstacles. FAA field approval is a minor bump. see http://www.aopa.org/whatsnew/newsite...4/ac43-210.pdf -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Steven P. McNicoll" wrote in message ink.net... | | "Jim Macklin" wrote in message | news:Zk0vf.40492$QW2.9687@dukeread08... | | True, when you are doing something strange, new and | unproven. Wind generators and pumps are common, have been | in use for decades. The only change is that you might be | changing from a DC generator to an alternator with a solid | state rectifier for DC output. The mount design and | location should already be present in approved data, for a | heavier generator. So, a field approval should be well | within the stricture of "at least as good as original." | | | There is no original. An anticollision light installation on a 1941 Aeronca | Chief IS something strange, new and unproven. | | |
#39
If you can't find an original wind generator and mount
system, the drawings should be available and you can fabricate repair parts. -- James H. Macklin ATP,CFI,A&P "George Patterson" wrote in message news:jM0vf.5086$Yc2.4180@trnddc04... | Jim Macklin wrote: | Field approval. No doubt there is an approved wind | generator from the 1940s. The conversion should be a simple | matter, even on a certificated airplane. | | Finding one may not be a simple matter. A friend of mine has an L-4. He was | looking for the correct generator for years. Dunno if he ever found one. | | George Patterson | Coffee is only a way of stealing time that should by rights belong to | your slightly older self. |
#40
You and your mechanic visit the local Fed over a cup of
coffee and talk about the proposed modification. You get the "ducks in a row" and get something in writing before you order parts. You do the conversion and the FAA signs off on the field approval [see http://www.aopa.org/whatsnew/newsite...4/ac43-210.pdf ]. If you make the changes and call in the FAA after the fact, you have shown a rebel streak and if the Fed is an a..hole he can refuse to do what is reasonable and proper. There FAA has many nice aviation people and a few retired AF Col. who didn't make their star. Talk to the local EAA chapter, the local DER and then make friends with the FAA guys and gals. Most are great people, but have the right attitude. Ask the Feds advice, "What's the best way to add anti-collision lights to my airplane, I think they'll make flying safer for everybody?" Don't say, "I think FAA rules are too strict, I want to add these parts I bought to my airplane and that jerk over in maintenance won't sign the field approval." -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "George Patterson" wrote in message newsO0vf.5087$Yc2.3298@trnddc04... | Jim Macklin wrote: | | In general, such things as lights are approved generically, | as replacements for any previously approved installation. | | Right. Tell that to Jay Honeck (who spent several thousand dollars removing | unapproved strobe lights from his Warrior). | | George Patterson | Coffee is only a way of stealing time that should by rights belong to | your slightly older self. |
Similar Threads | ||||
FAA PPL night flight requirement - does it have to be DUAL? | Peter Clark | Piloting | 21 | January 6th 05 12:38 AM |
Night solo XC? | G. Burkhart | Piloting | 51 | October 14th 04 03:11 PM |
Night of the bombers - the most daring special mission of Finnishbombers in WW2 | Jukka O. Kauppinen | Military Aviation | 4 | March 22nd 04 11:19 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
