#31
On Sep 25, 6:51*pm, Frank Whiteley wrote:
On Sep 25, 5:08*pm, wrote: On Sep 24, 5:02*pm, Martin Gregorie wrote: On Wed, 23 Sep 2009 17:53:24 -0700, snead1 wrote: Shat is a thermal detector? Typically an DC amplifier watching a tiny, naked fast response thermistor on a 5m (15ft) pole. The thermistor should be sensitive to air temp, so it is fitted with a sunshade to keep direct or reflected sunlight off it. They are also typically high resistance units (20K is a sensible minimum) so the sensing voltage doesn't warm them. If this happens the detector is sensitive to wind speed - something we don't want. Output is normally an analogue dial or a chart recorder built from RC servos though I have seen one with an audio output tone that rose and fell with temperature. Thermal detectors can be quite sensitive. Full scale deflection with a 0.8 C temperature change is not uncommon, so the better units are designed to let the zero setting track average day temperature. All have a gain control, needed because the temperature swing as a thermal blows through rises during the day, peaking in mid-afternoon. Some people use digital thermometers, but there are problems - the sampling rate is often far too slow (usually every 3 or 10 seconds) and the sensitivity to small temperature variations is limited by the display. I've seen none that can show changes of less than 0.1 degree.. That's probably more than you wanted to know, but there you go. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Does anyone have experience with using thermal detectors to increase the "get away rate" when auto or winch towing full size gliders? Bill When driving the winch, I often advise whether to turn left or right at the top of the launch. *Most don't listen. Frank Radio exchange immediately after winch launch:-) Frank: "Why are you circling right? I said turn left. Me: "I'm climbing at 8 knots." Frank: "Oh." Actually, a system which could reliably locate thermals in the vicinity of a winch would be extremely useful even though most pilots find a thermal and soar away on better than 50% of their launches in thermic conditions. AFAIK, there are three methods that show promise. The cheapest is anemometer/wind vanes on the four corners of the airfield which can show surface inflow to a thermal. Connecting these with radio modems and plotting the wind vectors on a laptop screen should indicate the surface location of a thermal. Wireless weather stations are off-the-shelf items. Both lasers (LIDAR) and microwave (RADAR) can directly detect vertical air motion by reflecting the beam off entrained dust, pollen and/or insects. None of these are exactly cheap but that has to be weighed against the utility of reliably finding thermals from a cheap winch launch. |
#32
On Sep 26, 1:13*pm, bildan wrote:
On Sep 25, 6:51*pm, Frank Whiteley wrote: On Sep 25, 5:08*pm, wrote: On Sep 24, 5:02*pm, Martin Gregorie wrote: On Wed, 23 Sep 2009 17:53:24 -0700, snead1 wrote: Shat is a thermal detector? Typically an DC amplifier watching a tiny, naked fast response thermistor on a 5m (15ft) pole. The thermistor should be sensitive to air temp, so it is fitted with a sunshade to keep direct or reflected sunlight off it. They are also typically high resistance units (20K is a sensible minimum) so the sensing voltage doesn't warm them. If this happens the detector is sensitive to wind speed - something we don't want. Output is normally an analogue dial or a chart recorder built from RC servos though I have seen one with an audio output tone that rose and fell with temperature. Thermal detectors can be quite sensitive. Full scale deflection with a 0.8 C temperature change is not uncommon, so the better units are designed to let the zero setting track average day temperature. All have a gain control, needed because the temperature swing as a thermal blows through rises during the day, peaking in mid-afternoon. Some people use digital thermometers, but there are problems - the sampling rate is often far too slow (usually every 3 or 10 seconds) and the sensitivity to small temperature variations is limited by the display. I've seen none that can show changes of less than 0.1 degree. That's probably more than you wanted to know, but there you go. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Does anyone have experience with using thermal detectors to increase the "get away rate" when auto or winch towing full size gliders? Bill When driving the winch, I often advise whether to turn left or right at the top of the launch. *Most don't listen. Frank Radio exchange immediately after winch launch:-) Frank: "Why are you circling right? *I said turn left. Me: "I'm climbing at 8 knots." Frank: "Oh." Actually, a system which could reliably locate thermals in the vicinity of a winch would be extremely useful even though most pilots find a thermal and soar away on better than 50% of their launches in thermic conditions. AFAIK, there are three methods that show promise. The cheapest is anemometer/wind vanes on the four corners of the airfield which can show surface inflow to a thermal. *Connecting these with radio modems and plotting the wind vectors on a laptop screen should indicate the surface location of a thermal. *Wireless weather stations are off-the-shelf items. Both lasers (LIDAR) and microwave (RADAR) can directly detect vertical air motion by reflecting the beam off entrained dust, pollen and/or insects. *None of these are exactly cheap but that has to be weighed against the utility of reliably finding thermals from a cheap winch launch. 1 out of 8 maybe;^) Frank |
#33
On Sep 25, 10:21*pm, Brad wrote:
I regularly find that the best thermals are found on my downwind leg right before i want to turn on base. Perhaps that's what he meant by the "downwind corner of the field" ![]() your field is like that too eh? hmmmmmmmm................ Brad I never worry about getting low in the pattern anymore, I always find a boomer abeam my aimpoint! Curiously, I don't seem to be able to find them anywhere else.... |
#34
Frank
Checking my logbook I find that, excluding training flights, my sucess rate on winch launch is about 60%. Sucess is rated by climbing to a height that allows me to glide to the next thermal. Some of our pilots have better percentages because they are more "discerning" about when they will take a flight. Bob |
#35
On Sep 27, 8:49*am, Bob wrote:
Frank Checking my logbook I find that, excluding training flights, my sucess rate on winch launch is about 60%. Sucess is rated by climbing to a height that allows me to glide to the next thermal. Some of our pilots have better percentages because they are more "discerning" about when they will take a flight. Bob Wish I could spell success! Bob |
#36
On Sep 27, 12:49*am, Bob wrote:
Frank Checking my logbook I find that, excluding training flights, my sucess rate on winch launch is about 60%. Sucess is rated by climbing to a height that allows me to glide to the next thermal. Some of our pilots have better percentages because they are more "discerning" about when they will take a flight. Bob Actually, on thermic days our club achieves about an 80 percent 'hook' rate. Pilots often release from aero tow lower than nominal winch release height in similar conditions. What winch pilots find is that lift starts quite early many days. The aero tow queue piles up about 1pm. Several days include two shears, surface flow to about 600-800ft, and another about 1400-1600ft and may be impacted by the passage of one or two convergence lines in the afternoon resulting in temporary or permanent 180 degree wind shifts. We have a house thermal area near the most common IP, but sometimes it's clear that the best lift is in the opposite direction, or over the launch point rather than the winch. Thanks when I give a nudge. Frank |
Which Way is That Thermal? | ContestID67 | Soaring | 26 | September 9th 06 08:30 PM |
Thermal Divider | RST Engineering \(jw\) | Home Built | 18 | May 30th 06 05:03 PM |
Thermal Data Files Thermal Mapping Project Australia | Mal | Soaring | 0 | December 2nd 05 11:14 PM |
thermal lift | ekantian | Soaring | 0 | October 5th 04 02:55 PM |
Thermal mapping | John | Soaring | 35 | April 27th 04 04:29 PM |
