#31
On Dec 15, 1:35*pm, Eric Greenwell wrote:
wrote: Why is the ability to stall in a steep turn a useful criteria? It sounds like a safety problem to me. Gives adequate pitch authority to pull to max lift coefficient, thus tightest turn. From my experience, this is usually about 75-80% aft in manufacturer's approved range. UH How steep is the turn for which you still desire the ability to stall? And how close to the ground or hillside do you expect to need this ability? It's not clear to me this would be a useful ability for a pilot that is trying to thermal away from a hillside, mountain, or during a low save. If you never fly faster than 25 second turns -- and a lot of us don't -- then it really isn't an issue. When I'm on my game, I can thermal with 14 second turns, full of water. 12 seconds, dry. Good trick to have in the bag when presented with an usually strong, tight core (are you reading, #44? -- good fun!). And yeah, the cg has to be in the right place to do that. "Ability to stall" is only an indicator that the ship is set up correctly. -Evan Ludeman / T8 |
#32
On Dec 15, 10:42*am, Andy wrote:
On Dec 15, 6:52*am, wrote: Gives adequate pitch authority to pull to max lift coefficient, thus tightest turn. From my experience, this is usually about 75-80% aft in manufacturer's approved range. UH It's not quite that simple though is it? For the ASW-28, and probably other modern gliders, the "manufacturer's approved CG range" is dependent on the glider mass. * Again for the 28, a cg position of 75-80 of approved range at min weight (315-321 mm aft of root leading edge) will be behind the approved aft CG limit at max gross wt (306mm). I used to think that the change in aft cg limit with increasing mass was to protect for the case where the tail tank fails to dump. *If that is true then ASW 28 built without the optional tail tank would not have the variable aft limit. *Do they? Comments or other explanations of the variable aft limit? Hank - Where is your 28 CG at max gross or at the max weight you fly at if lower? Andy (GY) My glider is set up for about 75% dry- about 315mm. Water goes in tail tank to maintain this position when water goes in wings. My manual doesn't have variable limit but does suggest a dry position of 300-310 mm. My glider is also set up to retain relationship of tail to main water during dumping. Only exception is ridge flying when I use less tail weight to unload ship in gusts. FWIW UH |
#33
wrote: Why is the ability to stall in a steep turn a useful criteria? It sounds like a safety problem to me. Gives adequate pitch authority to pull to max lift coefficient, thus tightest turn. From my experience, this is usually about 75-80% aft in manufacturer's approved range. UH How steep is the turn for which you still desire the ability to stall? And how close to the ground or hillside do you expect to need this ability? It's not clear to me this would be a useful ability for a pilot that is trying to thermal away from a hillside, mountain, or during a low save. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly I want to be able to fly at 45 deg bank without running out of elevator. I rarely thermal steeper than that because sink rate rises and I'm mostly interested in the smallest circle. Note that I am NOT advocating far aft CG position- actually quite the opposite. FWIW UH |
#34
On Dec 15, 10:56*am, jimboffin wrote:
Are you sure you are reading the manual right? Don't need to read it. The allowable mass/cg envelope is depicted graphically on page 5.10 of the flight handbook. I only have the German version on hand, the English translation is in the glider. The graph shows an aft limit of 345mm from 300Kg to 380kg, then reducing linearly to 322 mm at about 460 kg then linearly to about 306 mm at 525 kg max gross. The envelope also shows that the forward limit moves forward above 380kg but the shift is much smaller than for the aft limit. It also clearly shows that the aft end of the recommended cg range of 300-310mm falls outside the aft cg limit at max gross. Hank - what is on page 5.10 of your 28 flight handbook? If it is a mass/cg envelope what is the allowable CG at 525kg? I'm surprised that 2 28's both with tail tanks would have different limits. Mine is serial 28048. Andy (GY) |
#35
On Dec 15, 11:14*pm, Andy wrote:
On Dec 15, 10:56*am, jimboffin wrote: Are you sure you are reading the manual right? Don't need to read it. *The allowable mass/cg envelope is depicted graphically on page 5.10 of the flight handbook. *I only have the German version on hand, the English translation is in the glider. The graph shows an aft limit of 345mm from 300Kg to 380kg, then reducing linearly to 322 mm at about 460 kg then linearly to about 306 mm at 525 kg max gross. The envelope also shows that the forward limit moves forward above 380kg but the shift is much smaller than for the aft limit. *It also clearly shows that the aft end of the recommended cg range of 300-310mm falls outside the aft cg limit at max gross. Hank - what is on page 5.10 of your 28 flight handbook? *If it is a mass/cg envelope what is the allowable CG at 525kg? *I'm surprised that 2 28's both with tail tanks would have different limits. *Mine is serial 28048. Andy (GY) OK oops- I have to admit not paying large amount of attention to variable CG since I don't remember the last time I flew above about 480kg. Easterner ya know. I suspect this limitation relates to Waibel trying to ensure not going out the back if mains dump and tail doesn't. Gotta admit it doesn't interest me enough to do the math. Review does show that empirically through flight experience, I've pretty much confirmed that the factory suggested range works well. UH |
#36
![]() One more little tid-bid. I have found when flying a flapped ship and my CG was in the correct position for best performance, I never touched the trim knob! I'm flying a standard class bird now, so this doesn't apply, but in the H-301, ASW-20, Nimbus-3, LS-6 and ASH-25 it did. Moving the flaps did all the speed changes and moving the trim was not necessary. How's that check with you flapped guys? JJ |
#37
On Dec 16, 6:48*am, wrote:
OK oops- I have to admit not paying large amount of attention to variable CG since I don't remember the last time I flew above about 480kg. Glad to know we have the same limits. Even out West I have never filled the glider. My typical ballast load puts me at 497kg. (9.7 psf loading) So back to the point that got me interested in this discussion: Gives adequate pitch authority to pull to max lift coefficient, thus tightest turn. From my experience, this is usually about 75-80% aft in manufacturer's approved range. UH It's not quite that simple though is it? The statement about optimum cg should perhaps be: "Optimum cg is usually about 75-80% of the manufacturer's approved range at minimum flight mass, but no further aft than the aft limit at the actual flight mass." BTW I manage my cg to be about 320mm dry and 305mm ballasted. I want the cg to go aft for better climb performance if I dump because of weak conditions. I have to change that at Parowan (strong conditions and no ballast) so I add a nose trim disc to bring the dry cg to about 310 so I don't run out of trim in the fast glides. (For those that want that in percent of limits the minimum flight mass range is 227-345mm). Andy |
#38
On Dec 16, 9:31*am, JJ Sinclair wrote:
One more little tid-bid. I have found when flying a flapped ship and my CG was in the correct position for best performance, I never touched the trim knob! *I'm flying a standard class bird now, so this doesn't apply, but in the H-301, ASW-20, Nimbus-3, LS-6 and ASH-25 it did. Moving the flaps did all the speed changes and moving the *trim was not necessary. How's that check with you flapped guys? JJ Dissabled the trimmer completely on '20 (tape around trigger). Nice to feel elevator feedback. '27 doesn't seem to like this as much though have reduced trimming force. When CG is far enough back on '27 to "fly the flaps" , it doesn't seem to fly as nice, at least for me. That said, in CG position I like, the stick doesn't move much. '28- always trim-trim trim- good reason not to circle. UH |
#39
My old LS-3 was set up so the stick position was about the same at min
sink (straight ahead, not turning), best L/D, and--from memory--80 kts. Took a tape measure with me a few times and measured the distance between the stick and instrument panel. That's probably a better indication of drag caused by control deflection (if that's what you're worried about) than trim position. I flew it mostly using the flaps, with a little elevator to initiate the pull up and push over if I was in a hurry. The push over at the top of a steep zoomie by going full negative flaps, then popping them down into thermaling position as I turned was a wonderfully smooth feeling. Thermaling itself was whatever combination of stick and flap that worked. The end result was the CG on the aft limit (dry). Performed really well but was pitch sensitive in gusty thermals. I was told that was an issue with that airfoild, shared by other gliders that used it (PIK, Nimbus II, et al.). I followed UH's (and Herr Waibel's) advice when I got my ASW 24 and set the CG about 2/3 to 3/4 back in the range. Flies and performs great. Which is good because I don't have nearly as much time to fiddle with gliders as I did in earlier times. ![]() Chip Bearden ASW 24 "JB" USA |
Need a little more range for your 304S jet? | Marc Ramsey[_2_] | Soaring | 1 | July 22nd 07 01:39 PM |
VOR volume range | kevmor | Instrument Flight Rules | 7 | February 7th 07 10:46 PM |
Long range Wx | Paul kgyy | Piloting | 4 | December 31st 04 04:25 PM |
What is the range of the B-1B? | user | Military Aviation | 10 | December 24th 03 04:15 AM |
Fuel Range | Toks Desalu | Home Built | 2 | November 14th 03 12:51 PM |
