#31
"Morgans" wrote:
"GARY BOGGS" wrote in message . .. I am amazed that anyone with a pilots certificate would actually think anything hanging in the cockpit would tell you anything about the horizon!!!! Please tell me these aren't certified pilots! Amen. It is completely possible to have the string pointed at the floor in a 90 degree bank, or even upside-down. I believe it is impossible for a force vector of weight (always at 0 degrees; indicating down) added to a centrifugal force (at 90 degrees in your example) to yield a resultant that is also at 90 degrees. Unless maybe you're pulling infinite gees in those turns! Since there is a structural limit to how much one can bank a plane or glider and keep the resultant force vector directly through the floor, there is a moderately large range of bank angles around 90 degrees where you shouldn't be able to get the string pointed through the floor. If you hadn't chosen a 90 degree bank as one of your examples I wouldn't have been able to contest your post. Your statement appears to be true for all other bank angles. :-) |
#32
Bob Whelan wrote:
Youthful ignorance aside, everybody raise their hands who'd rather have been VFR-on-top in the above-mentioned conditions withOUT the two pieces of information that worked in this instance...let's talk afterwards! ![]() Bob - forces matter - W. Can I do without that information as long as I promise to power up the T&B when I'm VFR on top? Regardless of what technique or device you want to use in that situation, please practice with it at least a few times a year. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly |
#33
Jim Logajan wrote:
"Morgans" wrote: Amen. It is completely possible to have the string pointed at the floor in a 90 degree bank, or even upside-down. I believe it is impossible for a force vector of weight (always at 0 degrees; indicating down) added to a centrifugal force (at 90 degrees in your example) to yield a resultant that is also at 90 degrees. Unless maybe you're pulling infinite gees in those turns! Correcting myself - I was assuming that level flight was being maintained or attempted during the turn. Take away that assumption and it is no problem having the string point through the floor in a 90 degree bank. So never mind! |
#34
On Dec 29, 4:28*pm, brian whatcott wrote:
Andy wrote: Anything hanging in the cockpit like a pendulum (or any instruments working on the same principle) DOES NOT tell you which way is up./snip/ 9B If you are going to take on the school master role, you had better be right. Current solid state angular rate sensors act like a mini pendulum or tuning fork - when *turned, the pendulum retains spatial inertia. Foucault, an' all that. Remember? Brian W That has zero practical relevance. I'll leave the school master stuff to Andy (and here I was thinking he's a management consultant with a masters in aeronautical engineering), anyhow I managed to waste part of my life working on precision sensors for general relativity physics experiments. MEMS rate based devices like tuning fork designs etc. vibrate many orders of magnitude above the signal frequency. Hanging a weight on an about a foot long string will give a resonant period of about one second. For movement of the aircraft that happen of order ~seconds the mass on a string is essentially a plumb-bob and the "pendulum" will be perturbed. Again a focualt pendulum is oscillating in it's inertial frame with a resonant frequency orders of magnitude above above any signal frequency (the earth's rotation). --- The pendulum in the cockpit is one of the most goofball things I've heard in a while. On the other hand the cat idea has promise. The cat also has the benefit of being an amusing companion in the event of a landout, or a nutritious food source in the event of a more serious survival situation. But unfortunately until I I can overcome my cat allergy it's a plain old (non-edible) T&B backup for me. --- As others have pointed out, the important thing is to go try this and practice, with an instructor if needed. The advice from some others about the benign spiral, always needs a caveat - whether your ship will benign spiral or not is glider design and possibly W&B dependent. My ASH-26E at my normal W&B will not benign spiral. So I carry a pictorial T&B for backup just in case, and I've spent enough time under a hood to remind me I really don't want to go there. Darryl |
#35
On 30 Dec, 05:59, Darryl Ramm wrote:
As others have pointed out, the important thing is to go try this and practice, with an instructor if needed. The advice from some others about the benign spiral, always needs a caveat - whether your ship will benign spiral or not is glider design and possibly W&B dependent. My ASH-26E at my normal W&B will not benign spiral. So I carry a pictorial T&B for backup just in case, and I've spent enough time under a hood to remind me I really don't want to go there. Darryl At last...my Discus would do a benign spiral without going VNE with wheel down, brakes out, and hands off. My ASW27 won't and will fall to bits. I suggest everyone try hanging everything out and taking hands off to see what happens. If speed goes through rough air, pull out. You will then know whether you can safely use this technique or not. I have practised using string for slip, ears for speed, and gps for turn. I reckon that I could descend without my horizon through cloud most times without spinning or over speeding. Failing that I guess it is, pull the wings off then pull the chute! Jim |
#36
bildan wrote:
One thing I think would work is pitot tubes on each wing tip connected to a Winter type variometer with the vario rotated so the needle pointed up. Air would flow from the faster wing tip to the slower one through the vario which would show rate of turn. It's the only "non- gyro" rate of turn instrument I can think of. Yes, I see that. Reminds me that some folk have played with a GPS on each wingtip and some decode software - not very fast on its feet though, I don't think - even at 5 frames a second... Brian W |
#37
Jim Logajan wrote:
I believe it is impossible for a force vector of weight (always at 0 degrees; indicating down) added to a centrifugal force (at 90 degrees in your example) to yield a resultant that is also at 90 degrees. Unless maybe you're pulling infinite gees in those turns! Actually, in this hypothetical, the bank angle was 90 degrees. To place a bob towards the floor, it is necessary to induce some slip too.... Brian W (The impossible takes a little longer) |
#38
Darryl Ramm wrote:
/snip/ If you are going to take on the school master role, you had better be right. /snip/ Brian W That has zero practical relevance. I'll leave the school master stuff to Andy (and here I was thinking he's a management consultant with a masters in aeronautical engineering), anyhow I managed to waste part of my life working on precision sensors for general relativity physics experiments. /snip/ Darryl For a person who appreciates practical relevance, can I suggest you actually DO the experiment? Swing a bob on a foot long string in your right hand. Turn at a reasonable rate in place. Notice what happens to the pendulum's plane of rotation? Regards Brian W p.s. I can usually detect someone with physics background: no matter how much they have forgotten, they always retain that 'physics' attitude :-) |
#39
jimboffin wrote:
On 30 Dec, 05:59, Darryl Ramm wrote: As others have pointed out, the important thing is to go try this and practice, with an instructor if needed. The advice from some others about the benign spiral, always needs a caveat - whether your ship will benign spiral or not is glider design and possibly W&B dependent. My ASH-26E at my normal W&B will not benign spiral. So I carry a pictorial T&B for backup just in case, and I've spent enough time under a hood to remind me I really don't want to go there. Darryl At last...my Discus would do a benign spiral without going VNE with wheel down, brakes out, and hands off. My ASW27 won't and will fall to bits. I suggest everyone try hanging everything out and taking hands off to see what happens. If speed goes through rough air, pull out. You will then know whether you can safely use this technique or not. I have practised using string for slip, ears for speed, and gps for turn. I reckon that I could descend without my horizon through cloud most times without spinning or over speeding. Failing that I guess it is, pull the wings off then pull the chute! Jim Now THERE'S a post worth repeating: students are not taught about 'the fatal spiral' for nothing.... Brian W |
#40
The cat theory may have merit.
http://www.youtube.com/watch?v=wvRzWYCZ2e0 "Darryl Ramm" wrote in message ... On Dec 29, 4:28 pm, brian whatcott wrote: Andy wrote: Anything hanging in the cockpit like a pendulum (or any instruments working on the same principle) DOES NOT tell you which way is up./snip/ 9B If you are going to take on the school master role, you had better be right. Current solid state angular rate sensors act like a mini pendulum or tuning fork - when turned, the pendulum retains spatial inertia. Foucault, an' all that. Remember? Brian W That has zero practical relevance. I'll leave the school master stuff to Andy (and here I was thinking he's a management consultant with a masters in aeronautical engineering), anyhow I managed to waste part of my life working on precision sensors for general relativity physics experiments. MEMS rate based devices like tuning fork designs etc. vibrate many orders of magnitude above the signal frequency. Hanging a weight on an about a foot long string will give a resonant period of about one second. For movement of the aircraft that happen of order ~seconds the mass on a string is essentially a plumb-bob and the "pendulum" will be perturbed. Again a focualt pendulum is oscillating in it's inertial frame with a resonant frequency orders of magnitude above above any signal frequency (the earth's rotation). --- The pendulum in the cockpit is one of the most goofball things I've heard in a while. On the other hand the cat idea has promise. The cat also has the benefit of being an amusing companion in the event of a landout, or a nutritious food source in the event of a more serious survival situation. But unfortunately until I I can overcome my cat allergy it's a plain old (non-edible) T&B backup for me. --- As others have pointed out, the important thing is to go try this and practice, with an instructor if needed. The advice from some others about the benign spiral, always needs a caveat - whether your ship will benign spiral or not is glider design and possibly W&B dependent. My ASH-26E at my normal W&B will not benign spiral. So I carry a pictorial T&B for backup just in case, and I've spent enough time under a hood to remind me I really don't want to go there. Darryl |
SNEFA Artificial Horizon | nimbus | Soaring | 2 | December 21st 08 09:00 AM |
Electronic Artificial Horizon | Stuart Kinnear | Soaring | 14 | May 3rd 07 06:56 PM |
artificial horizon | DavidH | Home Built | 14 | March 14th 07 07:47 AM |
Artificial horizon pinout? | [email protected] | Home Built | 3 | July 16th 06 02:02 PM |
Artificial Horizon testing | Rory O'Conor | Soaring | 6 | April 5th 05 11:48 PM |
