Gel coat removal - water sanding vs. straight line sanding
Old February 11th 10, 05:30 AM posted to rec.aviation.soaring
Morgans[_2_]
Default Gel coat removal - water sanding vs. straight line sanding
"shkdriver" wrote
Hello,
Having refinished only a shk which is primarily wood construction with
fiberglass cockpit and leading edges, IMHO if you decide to purchase a
pneumatic (air) driven sander, dual action orbital or "air file" there
is a world of difference between quality tools and Harbor freight cheap
imports.
I recomend Hutchins brand tools, powerful, smooth action, and easy on
air demand. also you can use a water flood with air tools.
I can only agree with the comment to buy quality air tools, made by any of a
number of manufacturers. The difference in air consumption between a cheap
one and a better one doing the same amount of work can easily be twice as
much air being consumed by the cheap one. No kidding.
  #32
Old February 11th 10, 05:55 AM posted to rec.aviation.soaring
Brad[_2_]
On Feb 9, 7:42*pm, shkdriver
Hello,
imports.
I recomend *Hutchins brand tools, powerful, smooth action, and easy on
For heavens sake wear a high quality air mask, that previous comment of
not needing one because the particles are too big is B.S. and
dangerous!
As an ICU RN I work with pulmonologists every day and ran that one by
them, one simply stated "I wouldn't breath that with your lungs"
As far as time required, I removed three complete top coats of paint
(about 75 lbs worth) and primers and fillers. brought up the new
coatings and used polyurethane top coat, 18 meter wings, 4 foot wing
root, big constant taper fuse, about 1100 hours.
B.T.W. prestec products ROCK!
Good luck and best
wishes!
Scott W.
shkdriver
Scott..............Prestec isn't a PU product is it?
I'll be looking at a total paint job of the HP-24 sometime soon. Right
now it is all bare carbon. Can't decide if I want to go with Simtec
products or use a 2-pack PU. a-la PPG concept.
Brad
  #33
Old February 11th 10, 02:56 PM posted to rec.aviation.soaring
JJ Sinclair
Hello,
imports.
dangerous!
Good luck and best
wishes!
Scott W.
shkdriver
Brad- Hide quoted text -
- Show quoted text -
I recommend PPG Concept (90288 super white) with PCL polyprimer (907
white) for primer. You must be very careful when spraying acrylic
urathane, this stuff can kill you! Get a respirator with hose outside
the spray booth, use plastic gloves, hat and glasses leaving no
exposed skin. You will need about 3 gallons of mixed product which
means 2 gal of paint, 1 gal of catalist and half gal of thinner ($1000
bucks or so). Spray on 4 medium coats or until you get good orange
peal everywhere which is an indication you have enough paint on. Let
it cure out for 24 hours at 70 degrees, then block sand (wet) with 600
followed by 800. I spray on guide coat (spray can) before hitting it
with 600 then use the black powder rubbed on in the area before
hitting it with 800. Then let it cure out for a good 3 more days
before buffing with a wool pad and liquid rubbing compound.
Hope this helps,
JJ
  #34
Old February 11th 10, 05:20 PM posted to rec.aviation.soaring
Brad[_2_]
Hello,
imports.
dangerous!
Good luck and best
wishes!
Scott W.
shkdriver
followed by 800. *I spray on guide coat (spray can) before hitting it
Hope this helps,
JJ
Hey JJ,
This sounds like what I'll end up doing. I'll probably spray the
Polyprimer myself (this is a polyester right?). Then..........I'll
sand the primer, fill pin holes, repeat as needed, then take it to a
pro to have the top coat/PPG sprayed on.
My backyard tarp shed probably won't work!
Brad
  #35
Old February 11th 10, 09:52 PM posted to rec.aviation.soaring
JJ Sinclair
Hello,
imports.
dangerous!
Good luck and best
wishes!
Scott W.
shkdriver
Hope this helps,
JJ
Hey JJ,
Brad, Have a talk with the painter to make sure you're both on the
same page. An auto paint shop will normally give it 2 coats and it
should come out bright and shinny and that might be all you want. In
this case you want to do final sanding with 220 grit. If, on the other
hand, you wish to wet sand it as in my earlier post, you need 4 coats
with orange-peal. The painter will think your nuts, just tell him you
need lots of paint so's you can sand one coat off and have it
perfectly smooth, which his car paint job isn't. For a 4 coat job,
the final sanding can be done with 80 grit on a long board followed by
a pass with 150 (hand sanded) to knock down the high scratch marks.
This gives your paint good 'tooth' and you shouldn't be pulling any
paint when removing wing tape. The 80 grit scratch marks will
disappear after the second coat of paint is applied. Many auto paint
shops aren't ready to do a 25' wing and will probably end up with lots
of over-spray...........not a problem if your going to wet sand later.
I think 4 coat then wet sanded and buffed is the way to go. Williams
Soaring has a paint booth and Rex can deliver whatever you wish. I saw
an RV-8 he painted with 2 passes and it looked great.
Have fun,
JJ
  #36
Old February 12th 10, 01:11 AM posted to rec.aviation.soaring
Papa3
Hello,
imports.
dangerous!
Good luck and best
wishes!
Scott W.
shkdriver
Hope this helps,
JJ
Hey JJ,
perfectly smooth, which his car paint job isn't. For a *4 coat job,
Have fun,
JJ- Hide quoted text -
Hey JJ,
Scratching my head a bit on this one. I think what you were driving
at is that the final primer coat is left at 150 grit, followed by the
four coats of top coat. Or did I miss something?
P3
  #37
Old February 12th 10, 01:21 AM posted to rec.aviation.soaring
Brad[_2_]
Hello,
imports.
dangerous!
Good luck and best
wishes!
Scott W.
shkdriver
Hope this helps,
JJ
Hey JJ,
Have fun,
Hey JJ,
Scratching my head a bit on this one. * I think what you were driving
four coats of top coat. *Or did I miss something?
P3
I think JJ was referring to using 80 grit followed by 150 on the
Polyspray primer, as you said.
A final coat at 80/150 would be ah...........not so good!
Brad
  #38
Old February 12th 10, 01:25 PM posted to rec.aviation.soaring
Doug Hoffman[_3_]
[big snip]
Great tips on painting JJ! You have just answered several questions I
have had for some time. Thanks for sharing your know-how on this
difficult subject.
Regards,
-Doug
  #39
Old February 12th 10, 02:27 PM posted to rec.aviation.soaring
JJ Sinclair
Hello,
imports.
dangerous!
Good luck and best
wishes!
Scott W.
shkdriver
I'll be looking at a total paint job of the HP-24 sometime soon.. Right
Hope this helps,
JJ
Hey JJ,
of over-spray...........not a problem if your going to wet sand later..
Have fun,
Hey JJ,
P3
There's two schools of thought here guys; Auto painting and sailplane
re-finishing. The auto painter is going to sand his light primer coat
with no less than 220 and probably more like 320, then spray on two
medium coats, then he's done. Its shiny, cure it out and give it to
the customer!
The sailplane re-finisher breaks all the above rules. He primes real
heavy, maybe 4 coats, depending on what he has to fill to end up with
a good block sanded surface. He jumps on this with his 18" sanding
board with 45 left/ 45 right action and hopes it comes out smooooth as
a baby's bottom without going through the primer and show raw glass.
When all is good, I hand sands it with 150 just to remove any rough
edges, but I'm going to spray on 4 coats of paint and then wet sand
it, so I don't need the 220/320 action. In fact I dont want to do that
because my paint won't have killer good adhesion (AKA tooth) and it
will peal paint from the finished product when Mr. Customer peals off
his wing tape. The 80 grit scratches will disappear with the second
coat of paint, but even if they don't, your first pass with 600 wet
will make them go away.
That's what I have done for the better part of 35 years,
JJ
PS; Oh , yeah body putty. If you have little pin-holes showing through
your primer, wipe in medium body putty and hit those areas with 150.
  #40
Old February 12th 10, 05:26 PM posted to rec.aviation.soaring
Brad[_2_]
Hello,
imports.
dangerous!
Good luck and best
wishes!
Scott W.
shkdriver
peal everywhere which is an indication you have enough paint on.. Let
Hope this helps,
JJ
Hey JJ,
Have fun,
Hey JJ,
P3
the customer!
JJ
JJ....................my glider bits came out of the mold with no
primer, paint or anything, just black carbon with probably a million
little pin holes. My plan is the sand the surface of everything with
150 grit, clean all the dust and bits of sanding debris off with air
and.........(insert suggestion here)................then, if I flood
the surface with polyprime, will that fill the pin holes and give me a
good base to work with?
thanks,
Brad
Sanding of plywood before epoxy [email protected] Home Built 6 July 15th 08 01:21 PM
Sanding or Waxing - PIK 20 Question culverflyer Soaring 22 September 22nd 05 09:01 PM
Advice on sanding fibreglass [email protected] Home Built 12 April 28th 05 10:39 PM
Sanding composites [email protected] Home Built 12 January 31st 05 06:47 AM
Fear of Sanding Stuart Grant Soaring 7 January 17th 05 05:28 PM
