DIY Two-Stroke Engine Construction Methods
Old March 11th 10, 03:17 PM posted to rec.aviation.homebuilt,rec.aviation.ultralight,rec.crafts.metalworking,rec.models.scale,uk.rec.models.engineering
Charles Vincent
Default DIY Two-Stroke Engine Construction Methods
cavelamb wrote:
frank wrote:
Anything that flies a person has to be certified by the FAA anyway.
Especially homebuilts due to some fatal crashes early on.
When did this start???
Which? Stupidity on the internet or stupidity in our government?
Charles
  #32
Old March 11th 10, 03:58 PM posted to rec.aviation.homebuilt,rec.aviation.ultralight,rec.crafts.metalworking,rec.models.scale,uk.rec.models.engineering
Which? *Stupidity on the internet or stupidity in our government?
Government stupidity came first. Al G. just wanted to bring it to the
general public .................
Leon
  #33
Old March 11th 10, 04:29 PM posted to rec.aviation.homebuilt,rec.aviation.ultralight,rec.crafts.metalworking,rec.models.scale,uk.rec.models.engineering
Tim Wescott
frank wrote:
On Mar 10, 9:02 pm, Rufus wrote:
durabol wrote:
The two main methods for homebuilt construction would be casting vs.
machining or some combination of both (probably the best option).
Forging probably isn't appropriate for home construction (either the
-- snip --
like a motorcycle engine - strip it down and just build the parts and
accessories required to make it turn a prop. And along the way one can
also machine it's component parts down to lighten it...run it on the
ground, if it breaks, you know you went too far.
- Rufus (pilot, engineer, jeweler, model builder...yadda, yadda...)
The FAA licensing process for homebuilts is much lighter weight than for
'regular' aircraft. People can and do convert automotive engines for
homebuilts, and fly them. There are many building processes that aren't
certified for general aviation, but which are acceptable to the FAA
inspectors for homebuilts.
Check the EAA website (eaa.org?) -- they'll have something.
Tim Wescott
Control system and signal processing consulting
www.wescottdesign.com
  #35
Old March 11th 10, 05:07 PM posted to rec.aviation.homebuilt,rec.aviation.ultralight,rec.crafts.metalworking,rec.models.scale,uk.rec.models.engineering
jan olieslagers[_2_]
cavelamb schreef:
What? This?
This is completely false!
The sheer fact that he implies the FAA has worldwide authority shows he
doesn't know what he is talking about. Least said soonest forgotten.
  #37
Old March 11th 10, 09:37 PM posted to rec.aviation.homebuilt,rec.aviation.ultralight,rec.crafts.metalworking,rec.models.scale,uk.rec.models.engineering
On Thu, 11 Mar 2010 00:45:04 -0800 (PST), frank
piston or connecting rod).
One method I have thought of is to produce a wax model of the engine
with molds (to a fairly high tolerance to minimize machining) which is
then cast using lost wax casting techniques. I planned to have an
integral cylinder head/cylinder/half the crank case (this is for an
opposed style engine). The only bolts would be to bolt the two halves
together.
As someone whom has done lost wax casting, I wouldn't recommend doing
that for something I was going to bet my life on...not without investing
LARGE amounts of capital in equipment - a centrifugal or pressure
injection foundry...sand casting (which I've also done) is a far better
alternative for casting a raw engine casing. Â*Make a durable wooden
master model, preferably of a hardwood.
In any event, you're still going to have to sleeve the cylinders with
some alloy of machined, durable steel - which will have to be hardened
and polished in some way and interference fit into the block or stud.
And you need to match coefficients of thermal expansion when choosing
your materials in order to keep it all tight - same goes for choosing
and tolerancing your bolts and every other component in direct
contact...which means you also need to do some thermal analysis and
figure out how hot, as well as how, your engine is going to run...
A completely machined engine would need a large block of aluminium to
start with which I'm not sure how practical that would be. Perhaps
lost foam casting could be used as a general model of the engine was
made in foam and then cast and the resulting casting could be
machined.
Brock
Again - big investment in big machines to insure uniformity of the
casting...which will kill the project (and the pilot) if you screw it
up. Â*Hot spots, porosity, voids...not that simple. Â*Best way to
spot/find/quality check castings involve die penetrant or x-ray.
Also - don't overlook the fact that you are going to have to heat treat,
case harden, or otherwise machine or post-work any part you produce
depending on choice and application of materials...I don't know what
kind of tools and resources the OP has at hand, but if he's starting
from scratch he better be prepared to spend the amount of money he'd
spend on a mid-size car in tooling just to get started with such a
project...make it a large luxury car, now that I think about it...
The far easier (and safer) alternative is to modify an existing engine -
accessories required to make it turn a prop. Â*And along the way one can
Â* Â* Â* - Rufus (pilot, engineer, jeweler, model builder...yadda, yadda...)
Not true.
Experimental/homebuilt can use ANY engine - absolutely no
certification required.
  #38
Old March 11th 10, 11:35 PM posted to rec.aviation.homebuilt,rec.aviation.ultralight,rec.crafts.metalworking,rec.models.scale,uk.rec.models.engineering
Garry O
"Tim Wescott" wrote in message
-- snip --
yadda...)
www.faa.gov the eaa is a pilot organisation, not a controling authotiry :-)
Tim Wescott
Remember Altitude is more important than Attitude
  #39
Old March 11th 10, 11:42 PM posted to rec.aviation.homebuilt,rec.aviation.ultralight,rec.crafts.metalworking,rec.models.scale,uk.rec.models.engineering
Garry O
"Garry O" wrote in message
u...
-- snip --
yadda...)
Tim Wescott
and I must remember to read what is written after the first coffee of the
day 'DOH
your correct, the EAA will have a lot of information on homebuilt and
experimental A/C, they will also want you to get regular inspections during
the construction, even on experimental I think, and at various benchmarks
during the build.
personally I wouldn't fly with any home made engine, and by home made I'm
talking about things like casting your own cylinders etc, why re-invent the
wheel when there is a plethora of R&D'd engines that can more easily and
cheaply be converted.
  #40
Old March 12th 10, 12:46 AM posted to rec.aviation.homebuilt,rec.aviation.ultralight,rec.crafts.metalworking,rec.models.scale,uk.rec.models.engineering
Jim Stewart
u...
-- snip --
can
yadda...)
for 'regular' aircraft. People can and do convert automotive engines
for homebuilts, and fly them. There are many building processes that
aren't certified for general aviation, but which are acceptable to
the FAA inspectors for homebuilts.
authotiry :-)
Tim Wescott
the day 'DOH
during the construction, even on experimental I think, and at various
benchmarks during the build.
I'm talking about things like casting your own cylinders etc, why
re-invent the wheel when there is a plethora of R&D'd engines that can
more easily and cheaply be converted.
I'd also point out that much of the homebuilt FAA
regulatory footwork is done by designated examiners
and inspectors that are EAA members.
DIY Two-Stroke Engine durabol[_2_] Home Built 55 April 5th 10 05:11 PM
Methods for altitude changes Mxsmanic Piloting 141 April 18th 07 12:48 AM
Small 4 stroke engine? Ron Wanttaja Home Built 35 July 2nd 05 07:25 PM
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 02:26 PM
engine construction blueprints Håken Military Aviation 0 April 27th 04 05:23 PM
