New Nationwide Squawk Code
Old April 3rd 10, 02:42 PM posted to rec.aviation.soaring
haven
Default New Nationwide Squawk Code
On Apr 2, 10:42*am, Fred wrote:
SoaringNV is sponsoring a Minden Wave Camp this week. *As part of our
camp we have invited the tower controllers from Reno TRACON to talk to
us about communication with them, something we do for every camp. *We
learned, quite inadvertantly, that a nationwide transponder squawk
code has been assigned to gliders: 1201.
SO, from now on your transponder should be set to squawk 1201 anywhere
in the US (including the Reno airspace, where we have used a different
squawk code by agreement between PASCO and the controllers.)
Please use 1201 squawk code in your glider transponder.
Fred LaSor
SoaringNV
775 790-4314
Minden, NV
Does this mean that when the engine quits in my 150 I should
immediately change my squawk for 1200 to 1201? H...
Old April 3rd 10, 02:50 PM posted to rec.aviation.soaring
I know your comment was intended as a joke; however, I would suggest when the 150's engine quits you squawk 7700.
"Haven" wrote in message ...
Old April 3rd 10, 04:51 PM posted to rec.aviation.soaring
Brian[_1_]
immediately change my squawk for 1200 to 1201? *H...- Hide quoted text -
- Show quoted text -
Only if you start climbing (thermaling or wave)
Old April 4th 10, 06:18 PM posted to rec.aviation.soaring
kd6veb
Hi Gang and Cindy
To me this is a classic example of lack of communications and follow
up. Who's to blame? Both the gliding community (SAA and Pasco) and the
FAA! Could there have been better communications? Absolutely. But
maybe there is little motivation to communicate.
A story. A couple of years ago I thoroughly researched what I should
do with the SparrowHawk. Should I register it experimental, ELSA or
just fly it under Part 103 with no registration. To make sure I got my
facts straight I contacted the local FSDO and had an FAA agent come
and inspect my SparrowHawk to determine if I would be legal under Part
103 and whether I was doing anything that might constitute a danger or
a liability. Nothing negative was found. At the same time I researched
who were the personnel at the FAA in Oklahoma who composed the rules
and regs around the then new LSA class of aircraft. I located the
authors and posed the question of why for a LSA glider was there a VNE
limitation of 120knots whereas for all other LSAs including balloons
there was not this limit? There was no answer and, of course, there is
no rational answer to that question. I then asked the question in
putting together the LSA rules for gliders had they worked with any
glider group such as the SSA or Pasco. No was the answer. So Cindy we
are now in 2010 and things have not changed. There is still no
meaningful dialog between the SSA and the FAA in the generation of
regs and rules. I stand by my original criticism of the SSA. The SSA
has shown itself to be a poor representative of the gliding community
over the years. As agreed by you there is a contradiction in what code
to use for a motor glider - 1200 or 1201. A little thought and better
communications might have avoided this contradiction and also the LSA
glider VNE spec.
Dave
PS If anyone is interested in my full writeup on the SparrowHawk and
the questions and answers whether to register it or not please email
me. If sufficient of you think it would be of interest I could post it
here on RAS.
Old April 4th 10, 07:21 PM posted to rec.aviation.soaring
Scott[_7_]
kd6veb wrote:
Hi Gang and Cindy
glider VNE spec.
Dave
here on RAS.
Maybe this will help explain the 120 Knot limit. Read through the whole
page and you will see it applies to gliders as well as powered aircraft.
http://www.sportpilot.org/learn/fina..._synopsis.html
Old April 4th 10, 07:31 PM posted to rec.aviation.soaring
Greg Arnold[_3_]
"Maximum speed in level flight with maximum continuous power (Vh)—138
mph (120 knots) CAS"
A glider can't maintain 120 knots in level flight, so does this restrict
a glider VNE to 120 knots?
Old April 5th 10, 12:29 AM posted to rec.aviation.soaring
Mike Schumann
On 4/4/2010 1:18 PM, kd6veb wrote:
Hi Gang and Cindy
glider VNE spec.
Dave
here on RAS.
Does the SSA have any national goals and strategies in its dealings with
the FAA? What are they? How does the SSA keep its members up to date
on what we are trying to accomplish.
To be effective in lobbying, do we have any regularly scheduled meetings
with top officials at the FAA to discuss our concerns and review the
status of initiatives? Do we invite any key FAA officials to our
meetings or our conventions? If so, do we do so in a timely manner, so
we actually have a chance on getting on their busy schedules?
In case we don't have any clearly defined objectives, here are some good
starting points:
1. Finalize and publicize the implementation of the 1201 squawk code,
including updates to the AIM and all related documentation, updates to
computers, training ATC personnel on what behaviors to expect from 1201
aircraft, etc.....
2. Establish certification standards to permit the commercialization of
MITRE's low cost ADS-B technology.
3. Permit pilots and their crews to use ground based fixed, handheld,
and mobile radios in support of glider operations without requiring FCC
ground station licenses (or obtain a blanket FCC license that covers all
SSA members).
One big issue is the lack of any transparency to the SSA membership of
what is going on. If you look at the governmental affairs homepage
(http://ssa.org/myhome.asp?mbr=8671991229&show=blog), it doesn't look
like there is much happening. Maybe that's not accurate. If there is
stuff going on behind the scenes, it should be made visible to the
membership (meeting schedules, minutes, correspondence, etc....), so
that SSA members who are interested in this area have the chance to
participate in the process.
Mike Schumann
Old April 3rd 10, 09:07 PM posted to rec.aviation.soaring
Scott[_7_]
SoaringNV is sponsoring a Minden Wave Camp this week. As part of our
us about communication with them, something we do for every camp. We
Fred LaSor
SoaringNV
775 790-4314
Minden, NV
Depending on your altitude, 7700 might be more appropriate.
squawk code 2000 Gordy Instrument Flight Rules 2 March 14th 07 11:21 PM
Nationwide aircraft rentals Lou Home Built 1 February 2nd 05 12:31 AM
Squawk Sheets Greg Esres Piloting 23 August 23rd 04 08:15 PM
Private strips nationwide - is there a LIST? [email protected] Piloting 9 November 20th 03 11:08 PM
