On 6/18/2010 2:45 PM, drbdanieli wrote:
In yacht racing, a competitor can ask for and be given redress for assisting another vessel that needs assistance. If memory serves me correctly, it's usally an average of the daily score that the assisting vessel obtained during the regatta. Although I haven't any idea how this mid-air occured, there are blind spots that people should be aware of. I had a near miss years ago at a nationals when I was ahead and below another glider. Obviously, I couldn't see above and behind me and he couldn't see "under his feet". When I got a thermal and zoomed up, my tail missed his cockpit by a few feet! The increased numbers of sailplanes in a contest, following the same line of cloud streets or ridges, a moment of in attention with your head in the panel, messing with your computer can all add up to a statistic. I think what we need to focus on is what can be learned from this accident and what can be done to minimize the chances of it happening to someone else. Personally, I think situations like this make a case for getting Flarm or an equivalent system established here in the US. Barry We don't need FLARM, we need MITRE's low cost ADS-B transceiver. The SSA needs to send a letter to Randy Babbitt using this accident as an example of why we need a green light to get this unit certified ASAP. -- Mike Schumann |
On Jun 18, 12:53*pm, John Cochrane
wrote: Does this seem like the sensible approach? Yes. As an aside to others... we could do without the name calling, thanks. -Evan Ludeman / T8 |
On Jun 18, 9:53*am, John Cochrane
wrote: On Jun 16, 1:48*pm, Andy wrote: [good stuff snipped] Does this seem like the sensible approach? Yes. Thanks for starting to get the ball rolling on this so quickly. Darryl |
On Jun 16, 11:48*am, Andy wrote:
SSA contest report indicates that 2 gliders made contact on the first day. *If the gliders are identified correctly then one continued to win the day and the other returned to the airport missing part of one wing and so far has no log posted. Any more information available? Andy. Maybe worth noting that there was also a mid-air collision at the 31st Worlds on Day 1 (4th July) between two standard class gliders which was also caught on IGC flight logs. According to the contest web site both gliders were able to land and the pilots are OK. See flight logs for 8K and GX (reported as FX on the score sheet). According to the contest site, one glider had an anti-collision device, presumably Flarm, the other did not. One glider was thermaling and the other appears to join the thermal (or at least try to avoid the thermal circle?) but misjudges and there is a collision. That pilot had the day disqualified and a two day suspension for what the CD determined was dangerous flying. As with the Parowan mid-air there was a gaggle stacked up above the collision point and the collision involves at least one of the gliders entering the thermal. Likely a lot of gliders to look at and I wonder in both cases how much the pilots may have been distracted from seeing the gliders at the same altitude by looking up at the gaggle above to help judge the thermal location. And as discussed in this thread earlier, continuing on task after a collision is specifically not allowed by FAI rules (Annex A 4.1.4). Here one glider did continue back to the contest airport/finish. He was already on the final leg but did seem to pass up several other closer options to land. I wonder how the CD interprets the 4.1.4 "land as soon as practicable" requirement, but moot in this case since the pilot was disqualified anyhow. I mention that only to point it out, not to judge, without knowing the condition of the glider and facilities available at the landing sites I do not know what I would do. Darryl |
On 7/5/2010 11:09 AM, Darryl Ramm wrote:
On Jun 16, 11:48 am, wrote: SSA contest report indicates that 2 gliders made contact on the first day. If the gliders are identified correctly then one continued to win the day and the other returned to the airport missing part of one wing and so far has no log posted. Any more information available? Andy. Maybe worth noting that there was also a mid-air collision at the 31st Worlds on Day 1 (4th July) between two standard class gliders which was also caught on IGC flight logs. According to the contest web site both gliders were able to land and the pilots are OK. See flight logs for 8K and GX (reported as FX on the score sheet). According to the contest site, one glider had an anti-collision device, presumably Flarm, the other did not. One glider was thermaling and the other appears to join the thermal (or at least try to avoid the thermal circle?) but misjudges and there is a collision. That pilot had the day disqualified and a two day suspension for what the CD determined was dangerous flying. As with the Parowan mid-air there was a gaggle stacked up above the collision point and the collision involves at least one of the gliders entering the thermal. Likely a lot of gliders to look at and I wonder in both cases how much the pilots may have been distracted from seeing the gliders at the same altitude by looking up at the gaggle above to help judge the thermal location. And as discussed in this thread earlier, continuing on task after a collision is specifically not allowed by FAI rules (Annex A 4.1.4). Here one glider did continue back to the contest airport/finish. He was already on the final leg but did seem to pass up several other closer options to land. I wonder how the CD interprets the 4.1.4 "land as soon as practicable" requirement, but moot in this case since the pilot was disqualified anyhow. I mention that only to point it out, not to judge, without knowing the condition of the glider and facilities available at the landing sites I do not know what I would do. Darryl I didn't see any mention that there were additional gliders in the vicinity of the Parowan mid-air. Is there some further documentation that describes this? -- Mike Schumann |
On Jul 5, 5:35*pm, Mike Schumann
wrote: On 7/5/2010 11:09 AM, Darryl Ramm wrote: On Jun 16, 11:48 am, *wrote: SSA contest report indicates that 2 gliders made contact on the first day. *If the gliders are identified correctly then one continued to win the day and the other returned to the airport missing part of one wing and so far has no log posted. Any more information available? Andy. Maybe worth noting that there was also a mid-air collision at the 31st Worlds on Day 1 (4th July) between two standard class gliders which was also caught on IGC flight logs. According to the contest web site both gliders were able to land and the pilots are OK. See flight logs for 8K and GX (reported as FX on the score sheet). According to the contest site, one glider had an anti-collision device, presumably Flarm, the other did not. One glider was thermaling and the other appears to join the thermal (or at least try to avoid the thermal circle?) but misjudges and there is a collision. That pilot had the day disqualified and a two day suspension for what the CD determined was dangerous flying. As with the Parowan mid-air there was a gaggle stacked up above the collision point and the collision involves at least one of the gliders entering the thermal. Likely a lot of gliders to look at and I wonder in both cases how much the pilots may have been distracted from seeing the gliders at the same altitude by looking up at the gaggle above to help judge the thermal location. And as discussed in this thread earlier, continuing on task after a collision is specifically not allowed by FAI rules (Annex A 4.1.4). Here one glider did continue back to the contest airport/finish. He was already on the final leg but did seem to pass up several other closer options to land. I wonder how the CD interprets the 4.1.4 "land as soon as practicable" requirement, but moot in this case since the pilot was disqualified anyhow. I mention that only to point it out, not to judge, without knowing the condition of the glider and facilities available at the landing sites I do not know what I would do. Darryl I didn't see any mention that there were additional gliders in the vicinity of the Parowan mid-air. *Is there some further documentation that describes this? -- Mike Schumann Download all the IGC files for that Parowan contest day and play those in SeeYou (EditAdd Flight and do a multiple select on all the IGC files). There were at least three gliders in a thermal, one just starting to leave, and the two gliders in the collision appear to be joining that thermal below those other gliders. I have _no_ idea if either pilot of the colliding gliders have ever commented on watching those gliders above or whether this was a factor. Darryl |
On Jul 5, 8:25*pm, Darryl Ramm wrote:
On Jul 5, 5:35*pm, Mike Schumann wrote: On 7/5/2010 11:09 AM, Darryl Ramm wrote: On Jun 16, 11:48 am, *wrote: SSA contest report indicates that 2 gliders made contact on the first day. *If the gliders are identified correctly then one continued to win the day and the other returned to the airport missing part of one wing and so far has no log posted. Any more information available? Andy. Maybe worth noting that there was also a mid-air collision at the 31st Worlds on Day 1 (4th July) between two standard class gliders which was also caught on IGC flight logs. According to the contest web site both gliders were able to land and the pilots are OK. See flight logs for 8K and GX (reported as FX on the score sheet). According to the contest site, one glider had an anti-collision device, presumably Flarm, the other did not. One glider was thermaling and the other appears to join the thermal (or at least try to avoid the thermal circle?) but misjudges and there is a collision. That pilot had the day disqualified and a two day suspension for what the CD determined was dangerous flying. As with the Parowan mid-air there was a gaggle stacked up above the collision point and the collision involves at least one of the gliders entering the thermal. Likely a lot of gliders to look at and I wonder in both cases how much the pilots may have been distracted from seeing the gliders at the same altitude by looking up at the gaggle above to help judge the thermal location. And as discussed in this thread earlier, continuing on task after a collision is specifically not allowed by FAI rules (Annex A 4.1.4). Here one glider did continue back to the contest airport/finish. He was already on the final leg but did seem to pass up several other closer options to land. I wonder how the CD interprets the 4.1.4 "land as soon as practicable" requirement, but moot in this case since the pilot was disqualified anyhow. I mention that only to point it out, not to judge, without knowing the condition of the glider and facilities available at the landing sites I do not know what I would do. Darryl I didn't see any mention that there were additional gliders in the vicinity of the Parowan mid-air. *Is there some further documentation that describes this? -- Mike Schumann Download all the IGC files for that Parowan contest day and play those in SeeYou (EditAdd Flight and do a multiple select on all the IGC files). There were at least three gliders in a thermal, one just starting to leave, and the two gliders in the collision appear to be joining that thermal below those other gliders. I have _no_ idea if either pilot of the colliding gliders have ever commented on watching those gliders above or whether this was a factor. Darryl i know one pilot who was under the colliding pilots in the same thermal. |
On Jul 5, 6:38*pm, Tony wrote:
On Jul 5, 8:25*pm, Darryl Ramm wrote: On Jul 5, 5:35*pm, Mike Schumann wrote: On 7/5/2010 11:09 AM, Darryl Ramm wrote: On Jun 16, 11:48 am, *wrote: SSA contest report indicates that 2 gliders made contact on the first day. *If the gliders are identified correctly then one continued to win the day and the other returned to the airport missing part of one wing and so far has no log posted. Any more information available? Andy. Maybe worth noting that there was also a mid-air collision at the 31st Worlds on Day 1 (4th July) between two standard class gliders which was also caught on IGC flight logs. According to the contest web site both gliders were able to land and the pilots are OK. See flight logs for 8K and GX (reported as FX on the score sheet). According to the contest site, one glider had an anti-collision device, presumably Flarm, the other did not. One glider was thermaling and the other appears to join the thermal (or at least try to avoid the thermal circle?) but misjudges and there is a collision. That pilot had the day disqualified and a two day suspension for what the CD determined was dangerous flying. As with the Parowan mid-air there was a gaggle stacked up above the collision point and the collision involves at least one of the gliders entering the thermal. Likely a lot of gliders to look at and I wonder in both cases how much the pilots may have been distracted from seeing the gliders at the same altitude by looking up at the gaggle above to help judge the thermal location. And as discussed in this thread earlier, continuing on task after a collision is specifically not allowed by FAI rules (Annex A 4.1.4). Here one glider did continue back to the contest airport/finish. He was already on the final leg but did seem to pass up several other closer options to land. I wonder how the CD interprets the 4.1.4 "land as soon as practicable" requirement, but moot in this case since the pilot was disqualified anyhow. I mention that only to point it out, not to judge, without knowing the condition of the glider and facilities available at the landing sites I do not know what I would do. Darryl I didn't see any mention that there were additional gliders in the vicinity of the Parowan mid-air. *Is there some further documentation that describes this? -- Mike Schumann Download all the IGC files for that Parowan contest day and play those in SeeYou (EditAdd Flight and do a multiple select on all the IGC files). There were at least three gliders in a thermal, one just starting to leave, and the two gliders in the collision appear to be joining that thermal below those other gliders. I have _no_ idea if either pilot of the colliding gliders have ever commented on watching those gliders above or whether this was a factor. Darryl i know one pilot who was under the colliding pilots in the same thermal. From the flight traces there appear to be two gliders below the general are of the collision, neither appear to be actually working the same thermal so I did not mention them. One of them in particular flies towards and under the gliders a short time after the collide. It's worth sitting down with SeeYou on a fast computer and playing either the Parowan or WGC collision in 3D (complete with all the other gliders) and imagine looking at that other traffic while joining a thermal. A healthy reminder how easy this is to happen when there are enough gliders around trying to work the same thermals. Darryl |
Midair near Minden | Fred | Soaring | 52 | September 1st 06 11:41 AM |
Midair near Minden | Jim Culp | Soaring | 0 | August 29th 06 05:52 PM |
Another midair! | tango4 | Soaring | 3 | April 27th 04 06:14 PM |
Pix of two midair F-18s | Pechs1 | Naval Aviation | 9 | January 8th 04 02:40 PM |
Midair in RI | Martin | Piloting | 3 | November 18th 03 10:29 PM |
