VFR Practise Approaches
Old October 1st 10, 09:48 PM posted to rec.aviation.ifr
Default VFR Practise Approaches
On Oct 1, 12:05*pm, Mxsmanic wrote:
writes:
YOUR ORIGINAL POST WAS WRONG.
Unless you explain the error that you believe it to have contained, your post
doesn't serve much purpose, does it?
I ALREADY DID.
  #33
Old October 1st 10, 10:32 PM posted to rec.aviation.ifr
Mxsmanic
writes:
I ALREADY DID.
If that were true, why would you bring it up again?
  #34
Old October 2nd 10, 01:07 AM posted to rec.aviation.ifr
Brian Whatcott
On 9/22/2010 6:16 AM, ChristianFro wrote:
If an approach says DME required but I dont have DME, can I still
execute a VFR practise approach?
On GPS (RNAV) approaches, can I deviate from the published procedures
with permission from the Tower or controlling agency if I am doing a VFR
practise approach? I.E. Altitude deviation for a fix.
If so, what is the reference?
Thanks in advance.
In VMC, there are VFR approaches, and practice IFR approaches.
In IMC there are IFR approaches. Full stop.
Required equipment for VFR approaches are one pair regulation eye-balls,
an ASI, altimeter and compass. A radio is helpful.
Brian W
  #35
Old October 2nd 10, 02:46 AM posted to rec.aviation.ifr
Brian,
I think it's ATC facility dependent for IFR approaches and full stops.
I get touch and goes on IFR approaches on IFR clearances routinely my
neck of the woods.
Touch and goes also can be done on IFR XC round robins. Just file to
a fix at the destination airport, pick up the approach clearance and
fly back home after the touch and go.
  #36
Old October 2nd 10, 02:47 AM posted to rec.aviation.ifr
On Oct 1, 4:32*pm, Mxsmanic wrote:
writes:
I ALREADY DID.
BECAUSE YOU ARE WRONG.
WHAT PART OF THAT DO YOU NOT UNDERSTAND???????????
  #38
Old October 2nd 10, 03:37 AM posted to rec.aviation.ifr
A Guy Called Tyketto
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Steven P. McNicoll wrote:
A Guy Called Tyketto wrote:
This is incorrect. You forget to take into account that ATC
doesn't need to talk to you at all. That in itself is restrictive. If
ATC tells you "Aircraft calling for Class B clearance remain outside
of Class B airspace", it is restrictive, even if they do not
acknowledge
you directly. If ATC doesn't answer your call, you are to remain
outside of Class B until they do. If they don't answer, too bad.
Answering you isn't enough, if ATC does not clear you into Class B airspace
you are to remain outside.
That's exactly my point. If ATC tells you 'remain outside of
Class Bravo Airspace', you're stuck. you remain outside it. If they
don't contact you, you remain outside. If they even identify you, and
you don't hear those magic words clearing you into the Bravo, you
remain outside. Anthony here isn't getting the point there.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.wizard.com/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
iD8DBQFMppr/yBkZmuMZ8L8RAuOrAKCMJXIRwaRpm+VTKJz4fyp3YkeQZwCfcs qw
q9guD6C/IrBvSiPohyY1VC8=
=WWus
-----END PGP SIGNATURE-----
  #39
Old October 2nd 10, 07:45 AM posted to rec.aviation.ifr
Mxsmanic
A Guy Called Tyketto writes:
remain outside.
Mxsmanic wrote:
If you are thinking Class B, you can do what you want in Class B, UNLESS ATC
tells you otherwise, and PROVIDED OF COURSE THAT YOU HAVE A CLEARANCE into the
airspace before you enter it.
(emphasis added)
  #40
Old October 2nd 10, 08:13 AM posted to rec.aviation.ifr
Hash: SHA1
remain outside.
(emphasis added)
You miss the point again. ATC does *NOT* have to reply to you
at all, despite all your calls for Class B clearance. If you do not
hear from them, you're not getting into the Bravo at all. So you'd
better get below it (assuming you can without passing through it), stay
above it (assuming you can without passing through it), or go around
it.
And for 'you can do what you want in Class B', 7-9-2.a of the
..65T tells you otherwise:
a. VFR aircraft must obtain an ATC clearance to operate in Class B
airspace.
PHRASEOLOGY:
CLEARED THROUGH/TO ENTER/OUT OF BRAVO AIRSPACE,
and as appropriate,
VIA (route). MAINTAIN (altitude) WHILE IN BRAVO AIRSPACE.
or
CLEARED AS REQUESTED.
(Additional instructions, as necessary.)
REMAIN OUTSIDE BRAVO AIRSPACE. (When necessary, reason and/or
additional instructions.)
So if you are told to maintain a given altitude while in the
Bravo with your clearance to enter the Bravo, you will be no where near
'you can do what you want'. In short, you're a guest in Class B
airspace, and at the command of what ATC needs you to do, based on
their workload, other traffic, and/or any other limitations.
BL.
iD8DBQFMptuAyBkZmuMZ8L8RAnKuAJ96qH9M1WSfwytZmNtrgq aFkdULuACeOHLb
VeeFHIHQ89aoo54hbMxY6Gk=
=//qC
LAS approaches Ron Garret Instrument Flight Rules 10 March 28th 09 06:46 AM
My First GPS Approaches john smith Instrument Flight Rules 10 November 9th 04 09:14 PM
ILS PRM approaches Riddler Instrument Flight Rules 2 October 28th 04 12:37 PM
Channel News Asia: Taiwan Jets Practise Emergency Landings on Freeway Amid Tensions with China Dionaea muscipula Military Aviation 0 July 21st 04 08:18 AM
NDB approaches -- what are they good for? Dylan Smith Instrument Flight Rules 15 July 10th 03 09:15 PM
