First Human Powered Ornithopter
Old October 11th 10, 03:35 AM posted to rec.aviation.homebuilt
Flash60601
Default First Human Powered Ornithopter
"Alan Baker" wrote in message
Tom De Moor wrote:
Alan, thanks for the links provided. This craft's claimn is to have
maintained altitude and airspeed for 19.3 seconds, as the videos show, and
that is certianly a notable step. Auto-tow for them versus a rail and
falling weight for the Wrights, fairenough. Good baby-steps, and nothing at
all to be discounted. This is not a finished projec is it?
I think that the "Figure eight around two pylons one-half mile apart,
starting and finishing at 3 meters altitude" that the Gossamer Condor did
for the Kremer prize they won in 1977 would be a good measure of flight, and
it will take a lot of engineering and experimentation to achieve that for an
ornithopter , as it did for the Gossamer bunch. What a goal ! But I'll bet
some ingenious soul is already working at that.
Flash
  #34
Old October 11th 10, 10:36 AM posted to rec.aviation.homebuilt
Tom De Moor
says...
There is quite a possibility that the Flapper would also take off
without its wings flapping. In that scenario the flapping can hardly be
described as sustained flight.
The Wright Flyer needed a run down a hill. Was that not sustained flight?
If you fire a Super Hornet off an aircraft carrier to get it up to
speed, does that mean that it's not sustained flight when it maintains
airspeed and altitude on its own?
Sustained flight as an aircraft =/= sustained flight as an ornithopter
The Wright Flyer is not an ornithopter but an airplane/glider.
The Flapper (jet powered or propellor pushed) was claimed to maintain
flight / propulsion by the sole use of flapping wings.
It is not certain that it achieved that because it is quite likely that
the lift originated from the small wing combined with the flapping wing
wether the big wing was flapping or not. So it is not certain that the
flapping did contribute to lift generation.
Otherwise building an ornithopter would be quite ease: take a glider and
when in flight open the canopy and flap your arms. The glider won't fall
(immédiately) out the sky but I suspect that the armflapping will add
nothing but drag.
In fact the first claims for ornithopter were following this method by
iirc the same German engineer who develloped the Messcherschmidt Comet.
He added clapping paddles to a glider.
Tom De Moor
  #35
Old October 11th 10, 06:14 PM posted to rec.aviation.homebuilt
Alan Baker
Tom De Moor wrote:
says...
Why? Why would the definition of "sustained flight" change depending on
the type of craft?
There was neither a jet nor a propellor involved.
There was no other source of thrust involved.
nothing but drag.
That won't meet the definition of "sustained flight" even if you don't
flap, because a glider cannot maintain both altitude and airspeed
simultaneously.
I'm sorry, but you're veering into weird, here...
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
  #36
Old October 11th 10, 08:39 PM posted to rec.aviation.homebuilt
Tom De Moor
says...
the type of craft?
Because the subject is not sustained flight but sustained flight by an
ORNITHOPTER
http://en.wikipedia.org/wiki/UTIAS_Ornithopter_No.1
http://www.youtube.com/watch?v=a-qS7oN-3tA
'unless your eyes are cheated by some spell'
See above
nothing but drag.
simultaneously.
http://www.ornithopter.org/a.schmid.shtml
Tom De Moor
  #37
Old October 11th 10, 09:07 PM posted to rec.aviation.homebuilt
Alan Baker
Tom De Moor wrote:
says...
the type of craft?
ORNITHOPTER
So why does that change the definition of "sustained flight"?
Try an answer that is not begging the question this time.
Right. Where's the jet or the propeller?
Again, where?
Sorry, but it's not there.
See above
I did see. Moreover, I looked. You should try it.
nothing but drag.
simultaneously.
Yup. "Sustained flight" requires constant altitude and airspeed. The
Comet didn't meet the second criterion.
Alan Baker
  #38
Old October 11th 10, 09:17 PM posted to rec.aviation.homebuilt
Alan Baker
Tom De Moor wrote:
says...
the type of craft?
ORNITHOPTER
http://ornithopter.net/images/fullscale640-hq.mpg
The ornithopter you claim has a jet engine or propellor moving away from
a standing start.
Where's the jet or propellor?
Alan Baker
  #39
Old October 11th 10, 10:29 PM posted to rec.aviation.homebuilt
TonyW
a standing start.
First read the article and then look closely at the pix. The article
mentions it and it's clearly visible in the pix if you're looking for
it. Also 300 meters isn't much of a flight. If it had flown a loop
around the field, it would be more believable...
As it has been mentioned before, you're acting as if you have a personal
stake in this and it seems more and more like that every time you post...
Tony
  #40
Old October 11th 10, 11:30 PM posted to rec.aviation.homebuilt
Alan Baker
a standing start.
The "article" is a page on Wikipedia that anyone can edit.
The first flight of the Wright Flyer was only 36 meters and was only
accomplished by taking off with gravity assist.
Deslaurier's craft took off from a level runway.
LOL
Alan Baker
World Record for first human powered ornithopter sustained flight Paul Remde Soaring 10 September 24th 10 05:48 PM
Human Powered Flight, pt 2 - Japan 12.jpg (1/1) Mitchell Holman[_2_] Aviation Photos 0 January 11th 09 01:21 PM
Human-powered gliders Mxsmanic Piloting 6 February 3rd 07 05:42 PM
human powered flight patrick timony Home Built 10 September 16th 03 03:38 AM
Illusive elastic powered Ornithopter Mike Hindle Home Built 6 September 15th 03 03:32 PM
