#31
"Jay Honeck" wrote:
What I SHOULD have said is "it doesn't burn a drop of oil beyond 'normal' consumption"... Whew! Our O-540 uses around one quart every 12 - 15 hours. More if I fill the sump beyond 8.5 quarts. That sounds ok. How did you find out what "normal" is? My O-360 burns a qt every 7.5 hours. I thought that was too much, but Lycoming said the rate could go as low as 3hrs/qt and still be within spec! I've had the cylinders rehoned and new rings installed twice (due to the rocker arm fiasco, not because of high oil consumption) and both times the rate went back to 7.5 hrs/qt after breakin. -- Dan C172RG at BFM |
#32
every 7.5 hours. I thought that was too much, but Lycoming said the rate could go as low as 3hrs/qt and still be within spec! Normal is what "feels" right, to me. If I was putting in a quart every 3 hours, I'd be bitching at my engine rebuilder! Right now, thoroughly broken in at 125 or so hours, the engine is so sweet. Using the JPI engine analyzer, we can see how each cylinder is performing -- and they are all pulling together like tractors. At altitude I can now lean so that they are all within 90 degrees of each other, which is excellent for a normally aspirated engine. Best of all, it starts easily, runs really smooth, leaks very little (just a drip or two around the stupid cylinder head covers -- I've GOT to get those neoprene gaskets one of these days), and runs wonderfully on that cheap car gas! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#33
Dan Luke c172rgATbellsouthDOTnet wrote:
: That sounds ok. How did you find out what "normal" is? My O-360 burns a qt : every 7.5 hours. I thought that was too much, but Lycoming said the rate : could go as low as 3hrs/qt and still be within spec! I've had the cylinders : rehoned and new rings installed twice (due to the rocker arm fiasco, not : because of high oil consumption) and both times the rate went back to 7.5 : hrs/qt after breakin. My Cherokee 180 just had a top job last winter from sticking valves (sat for a long time on a fresh rebuild). New rings and rehoned chrome jugs broke in for compression of 80/79/78/80 50 hours later. It burns right at about 1 qt in 8 hours... supposedly just like chrome jugs are supposed to. At least that's what I've heard. Hrm.. a bit of quick math turns that into about 30 mL/jug/hour. For an O-540 that would be about a quart in 6 hours. Hrm... 1/2 cup of oil per hour... starts to sound like a lot then. Oh well, from what I hear, it's better to burn a bit too much oil than not enough. The spec is a CYA for Lycoming so that it's not possible to run out of oil before you run out of gas and need to land and check. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
#34
I am getting about 13hrs/qt on my factory overhauled O-360-A1A. I now
have about 200 hours on it. It is installed in a C-172. Dan Luke wrote: "Jay Honeck" wrote: What I SHOULD have said is "it doesn't burn a drop of oil beyond 'normal' consumption"... Whew! Our O-540 uses around one quart every 12 - 15 hours. More if I fill the sump beyond 8.5 quarts. That sounds ok. How did you find out what "normal" is? My O-360 burns a qt every 7.5 hours. I thought that was too much, but Lycoming said the rate could go as low as 3hrs/qt and still be within spec! I've had the cylinders rehoned and new rings installed twice (due to the rocker arm fiasco, not because of high oil consumption) and both times the rate went back to 7.5 hrs/qt after breakin. -- Dan C172RG at BFM |
#35
Ross Richardson wrote:
: I am getting about 13hrs/qt on my factory overhauled O-360-A1A. I now : have about 200 hours on it. It is installed in a C-172. What flavor of jugs? Chrome, Nitride, Steel, etc? -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
#36
"Jay Honeck" wrote:
Using the JPI engine analyzer, we can see how each cylinder is: performing -- and they are all pulling together like tractors. At altitude I can now lean so that they are all within 90 degrees of each other, which is excellent for a normally aspirated engine. Gotta love the JPI. I especially love the fuel flow option. Mine always has the fuel used correct to within half a gallon when I top off. Having it hooked to the GPS is really great. On the KLN 90B I can display my fuel used, fuel required to destination, reserve required, excess fuel beyond reserve, GPH, etc. so I can leave the JPI switched to CHT/EGT. Best of all, it runs wonderfully on that cheap car gas! Yer killin' me, Honeck! :^) -- Dan C172RG at BFM |
#37
"Craig Prouse" wrote in message ... "Tom S." wrote: I'd love a 182RG with an IO-540 instead of the O-470. Does anyone do a conversion? The 182RG always had a Lycoming O-540 vice the Continental O-470. All you're missing is the fuel injection. Huh!! Memory isn't what it used to be :~( I wish Cessna would bring back the RG in it's current line. |
#38
Regular factory steel, I believe. The engine has been running great. Now
if I can get problems with the C/S prop fixed that'll be great. Ross wrote: Ross Richardson wrote: : I am getting about 13hrs/qt on my factory overhauled O-360-A1A. I now : have about 200 hours on it. It is installed in a C-172. What flavor of jugs? Chrome, Nitride, Steel, etc? -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
#39
Get any 182RG and you will have your Lyc.
Tom S. wrote: "Jay Honeck" wrote in message news:hzDib.753715$YN5.705721@sccrnsc01... In conclusion, I think it's a mistake to dismiss the IO-540 on the new Cessnas as an insignificant update to the type. The O-470 was a good engine, but the IO-540 rocks. It's easier to manage and more efficient. I agree -- the injected O-540 is a terrific engine. Heck, we absolutely LOVE our carbureted version. It's powerful, relatively smooth, can be throttled back to burn 10 gph all day long, or honked all the way forward to burn 23 gph -- and when you do that our Pathfinder will climb like a homesick angel! I'd love a 182RG with an IO-540 instead of the O-470. Does anyone do a conversion? |
#40
"Newps" wrote in message news:0J2jb.772488$Ho3.205780@sccrnsc03... Get any 182RG and you will have your Lyc. It's not necessarily a lycoming I want as I'd like to get rid of the carburator. Also, I'd like to have a three blade prop instead of the two blader. I know that sacrifices a bit of cruise speed and costs more to OH, but I've been in both (have most of my early flying career in a three blade T182RG) and found it MUCH smoother. Psychosomatic (sp?)??? Tom S. wrote: "Jay Honeck" wrote in message news:hzDib.753715$YN5.705721@sccrnsc01... In conclusion, I think it's a mistake to dismiss the IO-540 on the new Cessnas as an insignificant update to the type. The O-470 was a good engine, but the IO-540 rocks. It's easier to manage and more efficient. I agree -- the injected O-540 is a terrific engine. Heck, we absolutely LOVE our carbureted version. It's powerful, relatively smooth, can be throttled back to burn 10 gph all day long, or honked all the way forward to burn 23 gph -- and when you do that our Pathfinder will climb like a homesick angel! I'd love a 182RG with an IO-540 instead of the O-470. Does anyone do a conversion? |
| Thread Tools | |
| Display Modes | |
| 1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 04:40 PM |
| Cessna buyers in So. Cal. beware ! | Bill Berle | Aviation Marketplace | 93 | December 20th 04 03:17 PM |
| Cessna 182T w. G-1000 pirep | C J Campbell | Instrument Flight Rules | 63 | July 22nd 04 08:06 PM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 01:57 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
