PowerFlarm at Uvalde?
Old August 13th 11, 03:41 AM posted to rec.aviation.soaring
Darryl Ramm
Default PowerFlarm at Uvalde?
On 8/12/11 4:23 PM, Andrzej Kobus wrote:
On Aug 12, 2:01 pm, Darryl wrote:
On 8/12/11 6:46 AM, Andy wrote:
On Aug 10, 6:26 pm, Darryl wrote:
The need in the USA for a permanently attached FLARM antenna was the
FCC's requirement not something FLARM wanted to do.
How did you arrive at that conclusion?
The documentation on file at FCC clearly indicates that the reason the
antenna is locked into position is that the connector type is not FCC
approved. It is my conclusion that FLARM chose this compromise to
avoid the delay of changing to an approved connector.
To be clear (maybe to other readers) it is not an "FCC approved
connector" in that sense like they are using some cheap connector now
and need a technically better one, they require a connector that
prevents the user swapping the antenna for another non-approved one
(i.e. one different than the device passes FCC tests with). Its CFR 47
Sec. 15.203 - that rule exists because of the concern about users
substituting higher gain antennas and exceeding the radiated power and
other specs within the IMS band (in this case). The whole
fixed/removable antenna comes up in other FCC approved/unregulated
consumer devices e.g. with consumer FRS vs. licensed GMRS radios. In
most consumer (e.g. non-licensed user) devices this usually results in
the antenna or cable being permanently attached to the device. Some of
the FCC enforcement/interpretation of this stuff gets a bit head-scratching.
Darryl
So how is this going to work with a brick version, will there be an
external antenna or will the brick come with fixed internal or fixed
external antenna that limits our ability to put the brick where we
have space?
I don't think FLARM has got into specifics on this.
The Flarm transmitter antennas that the FCC really care about are not
"internal" on any FLARM unit (they have to point vertical, are too
large, and need to be clear of the components inside the box. They are
external--typically mounted on the case and outside the USA today there
are options for using a coax cable for remote mounting that antenna.
FLARM know what people have asked for/need here and I expect them to
have something that is remote installable. Small companies may not be
able to justify paying the setup/tooling costs for a custom RF connector
and matching antenna assembly. With different packaging of the brick
itself one option _may_ be a permanently fixed but "serviceable" antenna
coax connection. The sort of thing that comes "permanently" attached to
the unit but can be replaced/swapped for a longer one etc. by a
qualified installer able to open the box--and using standard connectors
inside the box.
Like I said, some of the FCC interpretation of this stuff can be a bit
head-scratching. So who knows exactly what Flarm will do, I have no
idea. I will worry about the exact details on how to instal my brick
once I see the final product announced/approved.
There are should be no issue with GPS receiver antennas or the 1090ES
receiver antenna, and the logical thing there is just have them be
external and removable using standard connectors (MCX, SMA, ...)
Looking forward to getting my brick...
Darryl
  #32
Old August 13th 11, 05:58 PM posted to rec.aviation.soaring
Andy[_1_]
On Aug 12, 6:46*am, Andy wrote:
That link to the single document does not seem to work. The following
should allow the complete document set to be viewed.
http://tinyurl.com/3m3mjx8
Andy
  #33
Old August 16th 11, 09:36 AM posted to rec.aviation.soaring
GC[_2_]
Absolutely. Actually, they tried to do it with bits of string and super
glue but too many people like you noticed (you are SO sharp!) and the
impedance was a bit high.
And then...total disaster! It has to be 30cm from all your other
antennae - AND THE COMPASS! If they were honest, trustworthy folks,
they would have made it a proper 12 inches instead of these uppity,
foreign "cm" things. You were right all along.
You'll also find that the current Power Flarms are just paper models
with a clockwork mechanism inside giving random target information that
they hope will fool most people until they can all go off on a holiday
to the Virgin Islands with their ill-gotten gains.
For God's sake give it a rest! Pick, pick. Pick, pick. Pick, pick, pick.
NOTHING Flarm ever does will make you happy. The thousands of satisfied
users all around the world who've had no trouble making it work for 5
years and think it's a brilliant piece of kit are a complete figment of
Flarm's imagination used only for marketing purposes in the USA to suck
in poor, innocent victims like you.
Take my advice. DON'T BUY ONE! You'll never regret it.
Just stop writing about something you clearly dislike intensely, have no
interest in and will never buy - and give us all a break.
Darryl - please - stop replying to his inane posts! It just encourages him.
GC
  #34
Old August 17th 11, 04:13 PM posted to rec.aviation.soaring
Andy[_1_]
You are wrong about all of this. I have 2 on order.
PowerFLARM at Uvalde Paul Remde Soaring 19 August 1st 11 06:52 AM
Status PowerFLARM for USA Andrzej Kobus Soaring 0 May 17th 11 11:21 PM
PowerFlarm rentals Lee[_11_] Soaring 20 November 22nd 10 10:23 PM
PowerFLARM Paul Remde Soaring 9 November 6th 10 05:30 AM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 10:32 AM
