Cambridge 302 Gear/Airbrake Warning - How to Test?
Old September 8th 11, 08:09 PM posted to rec.aviation.soaring
ContestID67[_2_]
Default Cambridge 302 Gear/Airbrake Warning - How to Test?
I am in the midst of a project to install a gear/airbrake warning
system on my glider based on the built-in capability of my Cambridge
302. This system is better than the simple "airbrakes open, gear up"
warning system (http://www.wingsandwheels.com/pdf/gear%20warning.pdf)
as it also alerts the pilot to "airbrakes open on tow".
My "sensors" will be strategically placed reed switches and associated
magnets (and tefzel wire of course). My primary question revolves
around how to do a pre-flight test of the system.
From the manual...
"Warnings depend on presence or absence of airspeed as well as the
switch contacts. Here
is the logic: Unlocking the airbrakes connects pin 7 to ground. When
airspeed rises above 25 knots, the
alarm sounds. The alarm is cancelled when the airbrakes are locked.
During flight with the
landing gear retracted, unlocking the airbrakes connects pin 7 to
ground and sounds the
alarm. Lowering the landing gear opens the connection between pin 8
and ground and
cancels the alarm."
Reading from the above it would seem that the alarm system is totally
inactive until the GPS indicates I am moving 25+ knots. If so, how
can I test this system on the ground? Anyone else install this system
and have any experience? This weekend I will experiment to see if
the 302 programming is smart enough to allow testing while I am
standing still.
Thanks, John DeRosa
Old September 8th 11, 08:59 PM posted to rec.aviation.soaring
Darryl Ramm
From the manual...
and ground and
cancels the alarm."
standing still.
Thanks, John DeRosa
Connect a large syringe (ideally with a ballast volume) to the pitot
tube system and use this to carefully increase pressure.
This feature of the C302 is very nice.
Darryl
Old September 8th 11, 09:29 PM posted to rec.aviation.soaring
ContestID67[_2_]
Darryl,
Thanks for the response. Yes, this does seem like a nice system.
Alerts no matter what the volume is set to, brakes on tow warning,
etc.
Questions/comments...
1) While the syringe approach to mimic moving at 25+ knots would
logically work, it isn't optimal as something easily done during each
day's pre-flight.
2) What is a "ballast volume"?
3) Do you know how the 302 determines the difference between a warning
for "brakes deployed while gear down and on tow" and the warning for
"brakes deployed while gear up and landing"? The two states seem a
contradiction. My only thought is that it determines the glider is
descending versus assending.
Thanks again.
Old September 9th 11, 05:29 AM posted to rec.aviation.soaring
Tom Serkowski
day's pre-flight.
How about using the spoilers to help aileron control during takeoff and
leave them open until 30 KIAS? ;-)
Actually, mine stopped working a few years ago... Tests just fine on
the bench, and the syringe on the pitot works too. But leaving the
spoilers unlocked to well over 30 KIAS doesn't set off the alarm. Had
Gary, when he was at CAI, check it out during the last calibration and
it worked just fine. Very odd indeed.
-Tom
Old September 9th 11, 06:07 AM posted to rec.aviation.soaring
Darryl Ramm
day's pre-flight.
Actually, mine stopped working a few years ago... Tests just fine on the
bench, and the syringe on the pitot works too. But leaving the spoilers
unlocked to well over 30 KIAS doesn't set off the alarm. Had Gary, when
he was at CAI, check it out during the last calibration and it worked
-Tom
Tom well then obviously you need to order a new ClearNav vario... I
expect/hope they are U/C and spoiler switch pinout compatible with the C302.
Darryl
Old September 9th 11, 06:05 AM posted to rec.aviation.soaring
Darryl Ramm
Darryl,
etc.
day's pre-flight.
It is possible to worry too much - You don't pre-flight test your ASI
and that is likely more critical than these warning buzzers. And you can
certainly test behavior of say the gear warning while in the air.
A bottle/flask connected in series with the syringe so that moving the
syringe plunger has less of an effect on the pressure than if used
directly. You really don't want to blow out instruments connected to the
system. You can disconnect the instruments but then the futzing with
connections itself may introduce problems. And it may just be easier to
just slide a tube over the pitot for these kind of tests.
And remember the manual says to connect the ASI and static ports on the
C302 to the ships pitot and static not that of the TE/triple probe - one
reason is to have these alarms etc. to work properly if the TE/triple
probe is left off
I believe it is simply state based. If the gear has been raised and the
airspeed is high then it knows its "gone flying" and is ready to detect
subsequent spoiler deployed before the gears is locked down. For example
I've pulled gear up while on tow and later cracked spoilers to handle a
little bit 'o rotor while on tow and had the undercarriage alarm go off
as expected. There is no way altitude or climb rate affects this. The
developers are too smart to do that.
Darryl
Old September 8th 11, 09:03 PM posted to rec.aviation.soaring
Mark
If your airbrakes "suck open" after you are going faster than 25 knots
it will not warn you, just FYI...
It would work a tad better if the "spoiler open on tow" worked until
the first "gear up" condition before it reverted to the "spoiler
open / gear not down" mode.
Old September 8th 11, 10:59 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
If you install the airbrake switch correctly, the Cambridge 302 will
warn you even before the airbrakes "suck open".
The Cambridge system is designed to work with a switch that detects when
the spoilers are _unlocked_, not after they are extended. It's an
important difference, but it's usually easy to install a switch that
does that. On the gliders I've had, there is at least 0.5" of movement
of the spoiler handle and connecting linkage to unlock the spoilers.
So, it's more accurate to refer to it as "spoiler's unlocked on tow",
instead of "spoilers open on tow".
email me)
Old September 9th 11, 04:00 PM posted to rec.aviation.soaring
Dan Marotta
If your spoilers "suck open" and you don't recognize it, you shouldn't be
flying.
"Mark" wrote in message
Old September 9th 11, 04:41 PM posted to rec.aviation.soaring
Darryl Ramm
be flying.
But those pilots clearly are flying. And are killing themselves and
hurting passengers etc.in depressingly familiar accidents.
In the case of the C302 (and hopefully ClearNav vario) this feature
works very well and I would connect in any glider I owned. The limit
with these things is does having a lots of these alarms just end up
confusing/distractions and can the pilot handle and respond to the alarm
(and given how far behind the aircraft some seem this may be a problem).
But a "it's there problem" attitude and just sitting by while pilots
kill themselves is not going to help this sport or those pilots. And yes
if somebody is clearly having problems with safe spoiler
operation/handling emergencies/distractions etc. my first call would be
time with a good instructor not add a gadget but those gadgets may have
a place as well.
Darryl
ASW-20C Gear Warning Switch Placement Jim Kellett Soaring 3 May 16th 09 01:20 AM
Gear Warning Gadget Guy Soaring 118 November 30th 05 10:43 PM
Gear Warning Gordon Schubert Soaring 11 November 22nd 05 03:27 AM
Gear Warning Gordon Schubert Soaring 0 November 18th 05 08:22 PM
gear warning plus K.P. Termaat Soaring 0 September 8th 03 08:33 AM
