#31
In article , OSKI 3
wrote: Have a fabric Biplane and use Simple Green. Spray it on WIPE it off. DO NOT USE SIMPLE GREEN ON AIRPLANES!!!! That stuff etches aluminum. |
#32
EDR wrote:
In article , OSKI 3 wrote: Have a fabric Biplane and use Simple Green. Spray it on WIPE it off. DO NOT USE SIMPLE GREEN ON AIRPLANES!!!! That stuff etches aluminum. Did you miss the part about "Have a fabric Biplane..."? |
#33
zatatime wrote:
: On Thu, 1 Jul 2004 20:14:11 -0600, "Vigo" : wrote: :Anyone ever just fly inverted through a thunder storm : :sorry in advance :vigo : That's funny. A level 4 would probably do the trick! : z Uh, I find that rain takes the paint off while leaving the dirt unaffected. Like a Massachusetts snowplow - digs out potholes without touching the snow. -- Aaron Coolidge |
#34
In article , Dave Butler
wrote: Have a fabric Biplane and use Simple Green. Spray it on WIPE it off. DO NOT USE SIMPLE GREEN ON AIRPLANES!!!! That stuff etches aluminum. Did you miss the part about "Have a fabric Biplane..."? If it is harsh enough to etch Al, what is it doing to the paint and fabric? |
#35
"EDR" wrote in message ... In article , OSKI 3 wrote: Have a fabric Biplane and use Simple Green. Spray it on WIPE it off. DO NOT USE SIMPLE GREEN ON AIRPLANES!!!! That stuff etches aluminum. Nonsense. Diluted to proper levels it is harmless. On fabric or paint it has no effect. Used properly it is fine for aircraft use. |
#36
"EDR" wrote in message ... In article , OSKI 3 wrote: Have a fabric Biplane and use Simple Green. Spray it on WIPE it off. DO NOT USE SIMPLE GREEN ON AIRPLANES!!!! That stuff etches aluminum. Nonsense. Diluted to proper levels it is harmless. On fabric or paint it has no effect. Used properly it is fine for aircraft use. The problem is it (and just about any other liquid) will leech into the joints between panels and there it sits and does its chemical thing. Sure, it's fine on the surface of the aluminum, but that's not where the damage occurs. Go ahead and use it properly, but you've been warned... No Spam |
#37
"No Spam" wrote in message ... "EDR" wrote in message ... In article , OSKI 3 wrote: Have a fabric Biplane and use Simple Green. Spray it on WIPE it off. DO NOT USE SIMPLE GREEN ON AIRPLANES!!!! That stuff etches aluminum. Nonsense. Diluted to proper levels it is harmless. On fabric or paint it has no effect. Used properly it is fine for aircraft use. The problem is it (and just about any other liquid) will leech into the joints between panels and there it sits and does its chemical thing. Sure, it's fine on the surface of the aluminum, but that's not where the damage occurs. Go ahead and use it properly, but you've been warned... No Spam If you let it leech into the joints of bare aluminum you are not using it properly. On a properly painted surface there should be no chance of it leeching into bare aluminum. |
#38
"No Spam" wrote in message ... "EDR" wrote in message ... In article , OSKI 3 wrote: Have a fabric Biplane and use Simple Green. Spray it on WIPE it off. DO NOT USE SIMPLE GREEN ON AIRPLANES!!!! That stuff etches aluminum. Nonsense. Diluted to proper levels it is harmless. On fabric or paint it has no effect. Used properly it is fine for aircraft use. The problem is it (and just about any other liquid) will leech into the joints between panels and there it sits and does its chemical thing. Sure, it's fine on the surface of the aluminum, but that's not where the damage occurs. Go ahead and use it properly, but you've been warned... No Spam If you let it leech into the joints of bare aluminum you are not using it properly. On a properly painted surface there should be no chance of it leeching into bare aluminum. It's not a matter of letting it - it will do it. Inspection panels may be properly painted, but it will get between the surfaces. Like I said, you've been warned. No Spam |
#39
No,
couldn't agree more. The idea of washing an aircraft and being able to keep fluid from creeping into seams and slits is preposterous. -- Thomas Borchert (EDDH) |
#40
I have been hearing the comments about Simple Green for years and that it
will etch or corrode Aluminum. I'm not saying they are true or not but I have NEVER had anyone give definitive proof that it actually happens. Everybody "read a report" or "has a friend who knows somebody". Who out there has actually USED it on aluminum and seen (with their own eyes) the damage? I DON'T use it on my Taylorcraft cowl (aluminum) because I DON'T KNOW if it will cause damage, but I have used it on a Concur Porsche, the fabric parts of the Taylorcraft (over steel tube), numerous steel parts and LOTS of bare and painted aluminum that is NOT in my plane. I have NEVER seen any corrosion or etching any worse than caused by Windex, soap and water, plain water or general etching of the surfaces from exposure to the elements (like lawn chairs). Has ANYONE ever seen these effects THEMSELVES or does anyone have an OFFICIAL report of this etching and corrosion ever happening? Like I said, I'm not saying it doesn't happen, and I can't prove it does, I just know the stuff is GREAT for cleaning all kinds of surfaces, smells good and is CONSTANTLY maligned by the aviation community WITH NO PROOF. If it's bad, I'll use it in the house and ban it from my hangar, if it's not bad, I want proof of that too. Who has it? Hank J "Thomas Borchert" wrote in message ... No, couldn't agree more. The idea of washing an aircraft and being able to keep fluid from creeping into seams and slits is preposterous. -- Thomas Borchert (EDDH) -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
| Thread Tools | |
| Display Modes | |
| Cleaning up brushes/dope? | Michael Horowitz | Home Built | 5 | June 23rd 11 03:11 AM |
| B-17 Belly Landing-How much damage? | Matt Wiser | Military Aviation | 0 | May 8th 04 11:28 PM |
| World War II-era B-17 makes belly landing THE ASSOCIATED PRESS | Otis Willie | Military Aviation | 0 | May 7th 04 04:02 AM |
| Belly Landing | Emilio | Military Aviation | 12 | November 26th 03 07:41 PM |
| P-47/51 deflection shots into the belly of the German tanks,reality | ArtKramr | Military Aviation | 131 | September 7th 03 10:02 PM |
