CHTs - What is acceptable?
Old August 20th 04, 12:30 PM
WARREN1157
on it. Any recommendations on how to use this rather "useless" gauge?
I had a 182 with the same. I would just use it for a quick reference. Lean it
until it was at the same place as before. For extended cruise I would re-lean
the engine by roughing the engine then smoothing it out.
Old August 20th 04, 03:58 AM
G.R. Patterson III
Steven Barnes wrote:
Our club's Skylane has one CHT gauge with a big 'ol green range & no temps
That's what my Maule has. I just keep it in the green during climb and descent and
check it every once in a while during cruise.
George Patterson
If you want to know God's opinion of money, just look at the people
he gives it to.
Old August 20th 04, 05:25 PM
Dan Thomas
"G.R. Patterson III" wrote in message ...
George Patterson
he gives it to.
All of the information most people need is available online at
http://www.airweb.faa.gov/Regulatory...e?OpenFrameSet
These are the Type Certificate Data Sheets (TCDS) for US made
airplanes, engines, propellers and appliances (equipment such as
Carbs, seat belts and so on).
Engine TCDS give CHTs and a lot of other stuff. The statement by
the engine guys that the airframe manufacturer sets CHTs is
misleading.
Dan
Old August 21st 04, 02:47 PM
Dan Thomas wrote:
: http://www.airweb.faa.gov/Regulatory...e?OpenFrameSet
: These are the Type Certificate Data Sheets (TCDS) for US made
: airplanes, engines, propellers and appliances (equipment such as
: Carbs, seat belts and so on).
: Engine TCDS give CHTs and a lot of other stuff. The statement by
: the engine guys that the airframe manufacturer sets CHTs is
: misleading.
: Dan
While the TCDS might contain the max CHTs and such, many people believe that
they are insane. The metalurgical changes that occur when you run a cylinder up to
the "approved" TCDS limit of 500 degrees are significant. Remember that once a TCDS
is approved, it's basically gospel and can never be changed.... in other words, it's
guaranteed to be wrong forever.
Different airframes' engine limits shouldn't be compared directly, but I know
I would try to take the lowest of all of them as a recommendation. The guys who know
engines say that running over 400 in cruise is bad.
-Cory
* Cory Papenfuss *
* Electrical Engineering Ph.D. Graduate Student *
Old August 21st 04, 02:14 PM
Tom Fleischman
In article , Steven
Keep it in the green.
Old August 21st 04, 02:19 PM
Jay Honeck
temps
That's what both our Warrior and Pathfinder had in the panel when we
obtained them. They were almost worse than useless, in my experience.
Using them for reference meant nothing, as leaning "by ear" turned out to be
easier and just as "accurate" (meaning not accurate at all).
As you may have noticed, we've got the one from our Pathfinder on display in
our lobby, along with a whole bunch of other "spare parts."
Heck, it's not even a good doorstop!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
High CHTs on Cessna 175 Ron Natalie Owning 2 September 9th 03 02:14 AM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 03:04 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 09:14 AM
