#31
Jon Kraus wrote:
My new partner and I are looking at a 1975 Mooney M20C. Hi John, Sorry, I'm a little late to this party, and this is not in direct answer to your specific question, but be sure you have looked at the Mooney prepurchase inspection article in the MAPA Log. Surf over to http://www.mooneypilots.com and click on the link "prepurchase inspections" under "MAPA Log Sample Articles". Dave |
#32
Thanks Dave. They have some good stuff there !! JK
Dave Butler wrote: Jon Kraus wrote: My new partner and I are looking at a 1975 Mooney M20C. Hi John, Sorry, I'm a little late to this party, and this is not in direct answer to your specific question, but be sure you have looked at the Mooney prepurchase inspection article in the MAPA Log. Surf over to http://www.mooneypilots.com and click on the link "prepurchase inspections" under "MAPA Log Sample Articles". Dave |
#33
In article , Jon Kraus
wrote: I agree with you 100%. Matter of fact the seller just informed my FBO that he will not allow the plane to inspected by Byerly Aviation who is a well respected Mooney shop. I think we are going to pass on this one. something to consider: The seller might not like the shop because of a bad experience. I know one A&P that I won't let touch my airplane ever again (but he's not in the IL area). -- Bob Noel Seen on Kerry's campaign airplane: "the real deal" oh yeah baby. |
#34
![]() "if they told me they can do it in 8 hours I believe them. Jon Kraus Dream on. You are not very mechanically inclined, are you? -- Jim in NC |
#35
Nope. Don't take my comment out of context, read the whole passage.
-- Jim Carter "Nomen Nescio" ] wrote in message ... -----BEGIN PGP SIGNED MESSAGE----- From: "Jim Carter" I can't understand why some people think the object is to get the lowest price You're joking, right? -----BEGIN PGP SIGNATURE----- Version: 2.6.2 iQCVAwUBQTLJ2JMoscYxZNI5AQGBhgP+Nb+a59iQbHisN6dPN3 TaXSu3HY9N/k9N Wef2n6f5SKRB2LxW8dzLWlm8eQT+i4zv9BGdzt9zhDzZqHkYST veBTCug2bkm2RU pE2dPnNCgECJsv0Us0PqgjAUf0lYY1z8wA1X8De+buyYxApjAD T5NyZQa8ihxUS6 imwXGCBcCdE= =4xer -----END PGP SIGNATURE----- |
#36
Probably more then you are ... you dream on Douggy.... :-)
Morgans wrote: "if they told me they can do it in 8 hours I believe them. Jon Kraus Dream on. You are not very mechanically inclined, are you? |
#37
![]() "Jon Kraus" wrote in message ... Probably more then you are ... you dream on Douggy.... :-) Hmm, a bit too sensitive? Plonk -- Jim in NC |
#38
The oil-in-the-cylinder thing is for the "automotive" type compression
test. There is another way to tell with the "leak down" type test given to aircraft. A mechanic should be able to tell you if its valves or rings. They can "hear" it leak with the leakdown test. What frequently goes on these Lycomings is the camshaft, which will be valve related on the compression, and that is a major overhaul (tear the engine apart). If you pull a cylinder, have the mic the cam. Engine life is always a bit of a gamble. Does it do book speeds and climb at book rates? Performance is also a good measure, but HARD to measure accurately. Is fuel consumption normal for the speeds being flown? That is probably the easiest way to tell. Use a GPS for you speeds and compensate for the wind and altitude to get IAS, as that is most accurate. Airspeed indicators are not always accurate. If you buy an Mooney, or any airplane like it, you need to be able to spring for an engine rebuild at any random moment in time. But these engines can run a long time without needing a rebuild. It partly depends on you, and how safe you feel with a questionable situation. I have a similar Lycoming 0360 in my Aviat Husky, and its 2200 on the tach. Still going strong. No compression problems or oil usage. But it is 2200 SNEW and has immaculate care. Jon Kraus wrote in message .. . Doug - Thanks for your remarks. The engine has 420 hours SMOH which included a new camshaft, new bearings ect. I'm wondering if the main issue (with the low compression) is that the 420 hours has been over 6 years (and the last year it hardly flew at all). IMHO the plane has not been flown enough. Like I said I'm an no expert but wouldn't you think that 70 hours a year is a little light on usage? Could this be the cause of the low compression on the cylinder? Maybe and mabe not. I have a mechanical background but it has been years since I turned a wrench but if I remember about compression checks the procedure was to take a reading and if it was low then you squirt oil into the low cylinder (wet compression check)and if the reading came up then the rings were either worn or sticking. This is because the oil would temporarily seal the rings but do nothing to seal up the valves. If the reading stayed the same then you would suspect a valve problem. Please don't flame me too bad on this because it has ben a while since I've done any engine work. Although I suspect I'll be doing some owner assisted things with whatever plane I end up. :-) Jon Kraus PP-ASEL-IA Student airplane purchaser Doug wrote: What is the TT on the engine, and what is the SMOH on the engine? If either are high, you may be in for a total rebuild. ONE cylinder with 62 would concern me. If it's near TBO, you're probably in for a rebuild. Typically as an engine ages, compression goes down and oil usage goes up. Also check to see if the last rebuild included crankshaft bearings, was it a total rebuild or just a top? Look for oil in the front of the engine, this is evidence of main bearings going out. A recently rebuilt engine can have cylinder replacements be successful, but a good engine shouldn't need them. Like I said, if it's near TBO, you're probably in for a rebuild, and if the last rebuild wasn't a major, your probably going to have to major it. Its not worth it to top a high time engine, IMO. You haven't made a deal yet, so you can do whatever you want at this point. Nothing wrong with buying knowing it will need a rebuild so long as the buy price reflects this. You might get lucky and get 500 more hours, doing nothing. If the compressions were all good, and no oil usage, you usually can count on 500 more hours, REGARDLESS of the time on the engine. Usually, not always. And nothing unusual about running it past TBO. These Lycomings typically will run well past TBO. Jon Kraus wrote in message . .. My new partner and I are looking at a 1975 Mooney M20C. It is a nicely upgraded IFR plane with a 400 hour O-360 engine. It is a rather high time airplane (7000) hours and the price reflects this fact. It is being sold by the owner of the FBO we fly out of for one of his friends. They just finished up an annual inspection on it. My IFR instructor has owned Mooneys in the past and even had the M20C for years. He suggested that we fly the plane to Byerly Aviation in Peoria IL (a little over an hour flight from Indianapolis) and have them do the pre-buy. He said it would probably cost in the $500.00 range. My partner and I think it is a good idea too. We are both buying our first plane and think the money would be well spent. One of the cylinders has a compression of 62 while the others are in the 70's. This concerns me even though it is within tolerances. Of course we would hate to buy something that needed immediate major engine work. The plane has not flown much for the past 2 years so I am wondering if after flying the thing a while if the compression might come back some (probably wishful thinking I know). I am interested in opinions or experiences in first plane purchases. Experience with Byerly Aviation. Or comments on the engine situation I described. Thanks!! Jon Kraus PP-ASEL-IA Student aircraft purchaser |
#39
Bob Noel wrote in message ...
In article , Jon Kraus wrote: I agree with you 100%. Matter of fact the seller just informed my FBO that he will not allow the plane to inspected by Byerly Aviation who is a well respected Mooney shop. I think we are going to pass on this one. something to consider: The seller might not like the shop because of a bad experience. I know one A&P that I won't let touch my airplane ever again (but he's not in the IL area). Friend of mine just sold his 172. Before the buyer took it to pre-buy, he (my friend) had his preferred mechanic do a compression check. One cylinder was OK (mid 60s) rest in the low 70s. The prospective buyer takes it to his guy, report comes back, one cylinder shot (58), two questionable (61-63) and one in the high 60s. None of the results matched up with the previous comp check. Buyer sez, "I want $2500 off because I'm going to have to replace three jugs instead of one like you said." My friend says, OK, how's about we take the plane together, tomorrow, to a third shop on the same field as your guy and get it checked there. Buyer says OK, they fly over there, and mechanic #3 does the check with the buyer over his shoulder. Everything within 1psi of the check my friend's mechanic did. Buyer got half his money back from his (former) mechanic and bought the plane. If it's a reputable, well-known place, I'd ask the guy for an explanation of why he won't let you take it there. If the deal looks good otherwise it might be worth trying to salvage. -cwk. |
#40
There really is no such thing as "a standard pre-buy". A pre buy can
consist of anything you authorize the mechanic to do. First do a lookup on who that N number is registered to. Are you really dealing with the owner? What I would then suggest is you check the plane out as completely as YOU can. Upholstry, paint, hail damage, how if flies, do the radios, lights, gyros etc work. Make a written list. Get the logs. See if they have all the annauls (did they skip any). Transponder, pitot check. Take the logs to a mechanic. Have him check the gear and the engine and have HIM look at the logs and AD's. Is there any damage history? How is the repair? An O360 Mooney is going to run dollarwise: FIXED COSTS $?? Hangar or tie down ($500 to $3000) $1000-2000 insurance depending on pilot, Call Avemco and get a quote $1500 annual (just the annual part, not the repairs) HOURLY COSTS $25 fuel and oil $10 maintenance (this one is the bigest unknown) $10 engine reserve Jon Kraus wrote in message .. . Jim, ROFLMFAO.. You don't even know me so your comment about my attitude is laughable. As far as the pre-buy inspection goes the folks that do them tell me that they take not anywhere near 25 hours to do. Maybe you are ripping people off (25 + hours is ridiculous) and that is why you aren't getting any pre-buy business. But then again I don't know you either so who's to say right? :-) I would think that a shop that deals with a specific aircraft day in and day out would be able to point to the "problem" (expensive) areas of the aircraft in a reasonable amount of time. At least that is what they tell me. I think Byerly is a reputable firm and if they told me they can do it in 8 hours I believe them. It is of course your prerogative to disagree. Huggs and Kisses Jon Kraus PP-ASEL-IA Student airplane purchaser Jim Weir wrote: That's about the furthest thing from the truth I've ever seen in these newsgroups. A prebuy is a DOZEN times harder than an annual inspection. All an annual inspection tells you is that nothing on the airplane is worn past service limits at the time of the inspection. An annual doesn't tell you that the oil hasn't been changed for two hundred hours. It doesn't tell you that the tires are down to within a hundredth of an inch of wear limits. It doesn't tell you that the brakes have less than 10% service life. It doesn't tell you that the battery has about two tugs left in it before pooping out completely. Shall I go on? I don't do prebuys for two reasons. One is that a good prebuy takes me the better part of 25 hours to do, and I can't charge that kind of money to somebody who may or may not be the owner of that airplane someday. Two is that I can actually miss something, by simple oversight or by opinion, that the new owner will rip me a new one when they have to have that item repaired or replaced. It just ain't worth it. And I sure as HELL wouldn't consider doing one for somebody with Kraus' attitude. Jim (Lynne Miller) shared these priceless pearls of wisdom: -Truthfully, a good pre-buy is actually an annual inspection. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Home Inspection Listings | Patrick Glenn | Home Built | 4 | April 26th 04 11:52 AM |
Service Manual - 50 hour inspection | O. Sami Saydjari | Owning | 1 | April 8th 04 03:17 PM |
51st Fighter Wing betters rating to ‘excellent’ with inspection | Otis Willie | Military Aviation | 0 | February 20th 04 11:29 PM |
100 Hour Inspection Question | FryGuy | General Aviation | 59 | November 19th 03 04:01 AM |
