#31
Aaron,
The certification test requires that the GPS stay active when the microphone is keyed on the following frequencies: 121.150 121.175 121.200 131.250 131.275 131.300 I don't know anything about an M3, but all the Garmin models have a page that shows the satellite acquisition strength. After you acquire the satellites, go to that page and select the above frequencies on the KX-155. Now key the mike and transmit for about 10 seconds. The GPS is not allowed to lose it's acquisition. If yours continues to function normally, congratulations! I've never seen a KX-155 that will do that, with or without notch filters. In fact, King had a white paper on the mods necessary to clean up the KX-155. The process went far beyond adding "notch filters." Noise comes out the front, back, top and bottom of the unit. I doubt anyone ever modified their straight 155 with regard to King's recommendations. Thus, the KX-155A was designed, and co-exists with GPS right out of the box. Plus these units have many new features and design improvements. Try the test on your ramp. Let me know! Best, Karl "Aaron Coolidge" wrote in message ... kage wrote: : That might be true. : But your installation will NEVER pass the required IFR certification tests : required buy the FAA. : Karl I have a pair of KX155 (not kx155a) and a Northstar M3. It passed the interference tests as required by the FAA. I will check and see if any notch filters were installed, but I do not believe there are any. -- Aaron Coolidge |
weight difference | Lou Parker | Home Built | 7 | October 27th 04 02:42 AM |
The main difference between Europe and USA | noname | Military Aviation | 0 | May 31st 04 03:23 AM |
Difference in a Lycoming 65 vs. Contenintal 65 | JR | Home Built | 1 | November 29th 03 03:20 PM |
KX155 Pinouts | Richard Kelly | Owning | 1 | September 3rd 03 04:24 PM |
Mode S Transponders - Can ATC tell the difference? | Doodybutch | Owning | 2 | August 10th 03 06:21 AM |
