Poll: best bird under $35K?
Old November 16th 04, 11:14 PM
Newps
OSKI 3 wrote:
Here is my 2 cents worth. Why not get
a 150 or 152 with a 150/160 HP engine.
Throw in a taildragger mod. and you are
somewhere near $35K. Now you have the
most bullet proof cessna made, parts are
still around, will outrun a 172, take off
in a litle over 400 ft, land in the same
distance, all metal, and burn about 7 plus
GPH.
And be totally useless because before you put any gas in the useful load
is less than 250 pounds. There was a magazine article on this 150/150
in the last couple of years. Nice idea but without a gross weight
increase it's useless.
  #32
Old November 17th 04, 09:03 PM
John Galban
Newps wrote in message ...
GPH.
I've flown one of these and the main drawback I saw was range. The
bigger engine burns 1/3 more fuel than the original, but the tanks are
the same size.
  #33
Old November 17th 04, 11:15 PM
G.R. Patterson III
the same size.
I would still agree with newps. The bigger engine weighs more and subtracts from
the useful load, which isn't very much to start with.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
  #34
Old November 18th 04, 01:54 PM
John Galban wrote:
: I've flown one of these and the main drawback I saw was range. The
: bigger engine burns 1/3 more fuel than the original, but the tanks are
: the same size.
I never have bought that argument. Just because a plane has a bigger engine
doesn't mean you need to *use* it. Aside from additional weight or ridiculous
extremes (e.g. running a huge engine at 20% power or the like), bolting a larger
engine onto the same airframe doesn't have to cost you range. In fact, I'd argue in
some situations it'll gain you range. Consider that a 150 with an O-235 lycoming
would have more range than one with an O-200 continental... Run it at 65% rather than
75% and the higher compression will get you farther on the same amount of fuel.
You'll also spend less time in extra-bad fuel economy regions like climbout if you
climb faster.
I've got more range on my 180 HP O-360 than on a 150 HP O-320... provided I
don't run it at the same *percent* power... rather the same *absolute* power. Now,
with a 150/150, it might be bordering on wretched excess, so the weight increase may
skew the results a little bit. Still... it's not going to have inherently less range
except for the added 25-50 lbs the engine weighs.
-Cory
* Cory Papenfuss *
  #35
Old November 18th 04, 05:06 PM
WARREN1157
Should that not be 2¢ worth.
  #36
Old November 20th 04, 01:54 AM
Carl J. Hixon
I have always wonderd. What has happened to the "¢" sign? Nobody uses it
any more and my computer doesn't even have one on its keyboard.
Lets start a move ment to bring back the ¢ sign.
  #37
Old November 20th 04, 05:04 AM
Elwood Dowd
I'm not sure that makes ¢.
  #38
Old November 22nd 04, 12:26 PM
WARREN1157
We are going two make a go around, you had to much power in. We are number too
two land after a Cessna.
Two, too. to and ¢ are never used Wright.
  #39
Old November 22nd 04, 01:56 PM
John Clonts
"WARREN1157" wrote in message ...
It's enough to make you loose your mind!
Dream Airplane poll Bob Babcock Home Built 39 December 24th 04 02:20 AM
T Bird - ZackGSD Home Built 1 December 15th 03 01:47 PM
Tying down the bird david whitley Owning 17 September 23rd 03 03:57 AM
Bird control David Naugler Aviation Marketplace 7 September 22nd 03 03:40 PM
