#31
Newps wrote:
$110 is ridiculous, do it yourself, it ain't rocket science. Mine costs $18 total for 9 quarts of oil. I don't have a filter and only do the screen at the annual. The first time I called up my mechanic for an oil change she said bring it over. She opened it up and changed the oil while I watched. When done she billed me $38 + the oil. The second time I called up, she said bring it over. She handed me a screw driver, a bucket, and the case of oil. I paid only for the oil. She divides her customers into two groups. "Owners" and "just pilots." Owners take an active role in the maintenance of their aircraft. The "just pilots" just write checks. |
#32
Michael wrote:
: Now let me tell you why some people don't log oil changes. : Oil changes are not actually required. It's perfectly legal to fly : the plane all year on the same oil, adding as necessary. The 25 (or : 50, 100) hour interval is just a recommendation. Ditto gapping plugs, In the old piston engine airliner days the oil wasn't changed until engine overhaul. No oil analysis either - it was the 1950's. The oil probably didn't need to be changed because it leaked out of the radials quickly, so the oil was probably "replaced" every 50 hours anyway. Presumably the oil screens were cleaned at some interval, though. -- Aaron Coolidge |
#33
$18 total for 9 quarts of oil. I don't have a filter and only do the screen at the annual. I'd recommend, just like my airplane service manual says, to check both the pressure and suction screens at every oil change. Why? Well, I found a hunk of bearing in my sump screen last oil change. Nothing weird on the oil analysis, nothing weird in the pressure screen, engine was running great and has excellent compression and performance with no sign of trouble. I'm waiting to get the engine split open to find out the extent of the trouble. If it did destroy a bearing, then maybe I just averted an in-flight engine failure. At the very least, I might have saved myself buying a new crank. Lycoming pressure screen gasket: $0.97 AN900-16 crush washer for the suction screen: $0.39 Case of oil: $30-$50 depending on preference. Add $15 for a filter if you have one. Should also check the gascolator and fuel screens while you're at it. Never know when a hunk of fuel bladder or sloshing compound might show up. Sure would make for a bad day if it clogged up. $110 isn't out of line. $40-60 for materials and an hour labor to clean everything, cut open the oil filter, wash down the engine with solvent, run up and check for leaks, sign the paperwork. -- Dr. Nuketopia Sorry, no e-Mail. Spam forgeries have resulted in thousands of faked bounces to my address. |
#34
No problem, file it with the Department of Redundancy Department.
"Ron Natalie" wrote in message m... Dan Thompson wrote: Go to Jiffy Lube, get an oil change, ask the tech if you can have about a dozen of his stickers. That's almost a lifetime supply for free. Nothing like a Jiffy Lube sticker in your plane to show you care. I think I already suggested that. |
#35
Since the FAA has been citing owner/operators for INCORRECT WORDING in
maintenance logs, what IS the correct wording for an oil change log? |
#36
![]() Doug wrote: Since the FAA has been citing owner/operators for INCORRECT WORDING in maintenance logs, what IS the correct wording for an oil change log? I write... Drained oil, serviced with 9 qts of Phillips XC 20W-50. Test ran and leak checked good. The I sign it, write in my cert # and also write "owner" next to it. That's it. |
#37
Newps wrote:
Doug wrote: Since the FAA has been citing owner/operators for INCORRECT WORDING in maintenance logs, what IS the correct wording for an oil change log? I write... Drained oil, serviced with 9 qts of Phillips XC 20W-50. Test ran and leak checked good. The I sign it, write in my cert # and also write "owner" next to it. That's it. Yep, all the regs require is a: 1. Description of the work. 2. The Date 3. The name of who did the work if different than the signer 4. The signature, cert type and number of the person approving the work. The only cases I've heard about the FAA having issues is when the pilots did not make the entry indicating that the aircraft has been approved for flight after the maintenance (that's what the item #4 does). |
#38
Newps wrote
If you didn't log it, it didn't happen. So clearly, you performed the preventive maintenance in a manner that might not have been acceptable to the administrator. Busted. No. Prove the oil change was done wrong. Unfortunately, that's not how it works with the FAA. The ALJ's handbook specifically states that you are an interested party, and the inspector is not, so if it's his word against yours, he is automatically right. With the FAA, you are guilty until proven innocent. Michael |
#39
![]() Michael wrote: Newps wrote If you didn't log it, it didn't happen. So clearly, you performed the preventive maintenance in a manner that might not have been acceptable to the administrator. Busted. No. Prove the oil change was done wrong. Unfortunately, that's not how it works with the FAA. The ALJ's handbook specifically states that you are an interested party, and the inspector is not, so if it's his word against yours, he is automatically right. With the FAA, you are guilty until proven innocent. No, if they are going to assert I did not do my oil change correctly they have to have proof. Saying I did it wrong is not proof |
#40
![]() Newps wrote: Doug wrote: Since the FAA has been citing owner/operators for INCORRECT WORDING in maintenance logs, what IS the correct wording for an oil change log? I write... Drained oil, serviced with 9 qts of Phillips XC 20W-50. Test ran and leak checked good. The I sign it, write in my cert # and also write "owner" next to it. That's it. My wording is similar. I also change the filter, so I add a note about that. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
Logging time on a PCATD | [email protected] | Instrument Flight Rules | 3 | December 18th 04 05:25 PM |
Logging Actual Time | Brenor Brophy | Instrument Flight Rules | 9 | November 3rd 04 03:00 PM |
CFI logging requirement | [email protected] | Owning | 9 | October 19th 04 07:11 PM |
Logging local flights. | Rich | Owning | 23 | July 16th 04 12:02 AM |
Logging again | Doug | Instrument Flight Rules | 10 | September 17th 03 02:38 AM |
