Curious as to why no soap and water. The paint is probably some
polyeurethane (Imron etc...) so it wouldn't be hurt. JK Jay Honeck wrote: Speaking of washing planes. How do you get your plane washed in the winter? Mine could use it and I have no idea what to do. I *never* wash my planes (or motorcycles) with soap and water. Everything is done with Lemon Pledge and cloth diapers. Unfortunately they no longer make pump-spray Pledge, and the aerosol stuff is just not right. (It comes out in a foam, instead of liquid.) Luckily, I bought 6 cases of the stuff before they stopped making it -- so I'm good for a few more years. ;-) Anyway, Pledge works on any above-freezing day. The paint looks new, and so does the plexiglass. I haven't had to find a substitute yet, so if anyone finds an equally economical solution, please post it here. |
Jay Honeck wrote:
Speaking of washing planes. How do you get your plane washed in the winter? Mine could use it and I have no idea what to do. I *never* wash my planes (or motorcycles) with soap and water. Everything is done with Lemon Pledge and cloth diapers. Unfortunately they no longer make pump-spray Pledge, and the aerosol stuff is just not right. (It comes out in a foam, instead of liquid.) Luckily, I bought 6 cases of the stuff before they stopped making it -- so I'm good for a few more years. ;-) Anyway, Pledge works on any above-freezing day. The paint looks new, and so does the plexiglass. I haven't had to find a substitute yet, so if anyone finds an equally economical solution, please post it here. You obviously don't get your cars or airplane very dirty. Washing off mud or any amount of dirt with Pledge and a diaper would make a great abrasive that would trash your paint in short order. Vehicles should always be washed with lots of water prior to touching the surface with a sponge or cloth. Soap helps loosen the dirt and avoid scratches, but water alone does a pretty good job. Never take a cloth to a dry and dirty painted or plexi surface. Matt |
![]() "Jay Honeck" wrote Unfortunately they no longer make pump-spray Pledge, and the aerosol stuff is just not right. (It comes out in a foam, instead of liquid.) Jay Honeck Have you tried turning a can upside down, and spraying out all of the propellant? Then you can stab or cut the can open and get the stuff out. I'll bet the foaming is not there without the pressure. -- Jim in NC |
I've been reasonably happy with Dry Wash N Guard... Enough so that I
quit using Pledge a few years back... http://www.dri-waterless-car-wash.com/ The devil is in the details, of course... Start with the 32 oz. with the pump sprayer to see if you like it... Shake it WELL before decanting or using - and after you have it shaken (not stirred), then shake it for double the time you thought was adequate... There are some 50 ingredients in it and some settle out... After the 32 oz. bottle gets low then the 64 oz. jug is good... Oh yeah... On the pump sprayer, do NOT tighten the cap crushing the O-ring seal, as this dents the O-ring and it eventually stops holding pressure... Gently screw the cap down until you can just feel the O-ring start to add drag, then add about one ounce of torque beyond that... My O-ring on the pump is 4 years old and still going strong - guys who just have to torque it down until it jams and the bottle starts to distort will be lucky to get a few weeks out of the 0-ring (gotta stop them leaks doancha know)... It looks pricey but goes a long, long ways... ymmv, bni, sar, etc. Denny |
On Sun, 19 Dec 2004 13:04:21 GMT, Jon Kraus
wrote: Speaking of washing planes. How do you get your plane washed in the winter? Mine could use it and I have no idea what to do. Thanks!! I figure that's added insulation. Mine rarely gets washed in the winter. OTOH you can use the so called "dry wash". It's not really dry and goes on much like wax with a wet cloth. It does a good job on everything except grease and oil. There, I guess you could use some solvent followed by the dry wash. It does need above freezing temperatures though. A couple of the catalytic LP gas heaters do a pretty good job of making the hanger warm enough you can shed the "long snuggies", but it's definitely not tropical in there. Jon Kraus PP-ASEL-IA Dirty Mooney Owner Jay Honeck wrote: I find walking out to a rental airplane that someone else has already washed, fueled, fixed, annualed, etc. etc. etc. pretty damn convenient. Down time is the only time I miss the multi-plane club. There are two sides to every story. Wow -- the rental planes I used to fly we a) Clapped out That's the only kind I can afford. b) Unwashed -- for years Why wash? Bugs stick better to a clean plane. Once they build up a layer it doesn't seem to get any thicker. As slippery as they are, you'd think they'd make the plane go faster. c) Rarely fueled by anyone except me Your contributions are appreciated, but not acknowledged publicly. d) Had lots of things wrong -- or, at least, not quite right You are describing a normal airplane. and they say, FORD = Fix, Or Repair Daily. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com And if it was hangared (few were), I had to drag the thing out of a group hangar from behind a couple of other planes. There is nothing about renting that I miss -- except at annual time. ;-) |
Jay Honeck wrote:
Wow -- the rental planes I used to fly we a) Clapped out b) Unwashed -- for years c) Rarely fueled by anyone except me d) Had lots of things wrong -- or, at least, not quite right There are two FBOs around here that have 172Rs and 172SPs that are in pretty- to quite-good shape. One is also a Cessna dealer, so I expect that this plays some role. Unfortunately, though, stepping up from the 172 is tougher to find. Add that to my list of club advantages. There are other FBOs here, of course, which are more as you describe. So I guess there is a market for that. - Andrew |
Vaughn wrote:
That said, I envy owners and hope to be one some day. Someday I hope to be two. :-) |
I carry my aircraft keys in my pocket. My headsets are in the plane,
plugged in. My logbook is in the plane. My charts are right where I need them, in their special place, in the plane. My sunglasses are tucked away into their place, in the plane. If I feel like it, I drive out to the airport, push it out of the hangar and away I fly! I don't have to ask anyone's permission, sign any forms or any of that rental stuff. It's about FREEDOM!!!!! |
![]() "Doug" wrote: I carry my aircraft keys in my pocket. My headsets are in the plane, plugged in. My logbook is in the plane. My charts are right where I need them, in their special place, in the plane. My sunglasses are tucked away into their place, in the plane. If I feel like it, I drive out to the airport, push it out of the hangar and away I fly! I don't have to ask anyone's permission, sign any forms or any of that rental stuff. It's about FREEDOM!!!!! You're dam' right. Owning is expensive and comes with headaches renters don't get, but it's well worth it, IMO. -- Dan C172RG at BFM |
Doug,
Just one suggestion. Take the log books out of the airplane and keep them in a safe place. If, God forbid, you were to have an accident that destroyed the logbooks, that wouldn't be a good thing. You probably would want them available to the accident investigators and the insurance company. Rick Graves N34759 - 1974 C177B On Sat, 18 Dec 2004 07:57:26 -0800, Doug wrote: I carry my aircraft keys in my pocket. My headsets are in the plane, plugged in. My logbook is in the plane. My charts are right where I need them, in their special place, in the plane. My sunglasses are tucked away into their place, in the plane. If I feel like it, I drive out to the airport, push it out of the hangar and away I fly! I don't have to ask anyone's permission, sign any forms or any of that rental stuff. It's about FREEDOM!!!!! |
Owning Update | mindenpilot | Owning | 9 | November 23rd 04 02:13 PM |
What is missile defense? An expensive fraud Bush needs Poland as a future nuclear battlefield | Paul J. Adam | Military Aviation | 1 | August 9th 04 08:29 PM |
Buying a plane versus renting | RD | Owning | 35 | March 5th 04 09:42 PM |
Legality of owning ex-military intercontinental aircraft. | Bill Silvey | Military Aviation | 71 | October 15th 03 09:50 PM |
renting plane out to flight school - profitable? | David Megginson | Aviation Marketplace | 1 | October 13th 03 02:36 AM |
