#31
#32
#33
On Sat, 08 Jan 2005 00:38:58 GMT, Paul Smedshammer
wrote: ne in that case that would allow me to find a clear spot on either side of the Central Valley fog could have been a life saver. I was very lucky and will think twice before going VFR over the top again on a single engine. Paul Smedshammer Mooney M20F I've pretty much been talked out of buying a twin. The way they talk about it, it sounds like you'd have to be nuts to buy a twin, especially an older one. I guess I have 3 choices: 1. Buy a twin, go broke 2. Fly a singe, eventually get killed 3. Don't fly John Szpara Affordable Satellite Fiero Owner 2-84 Indy Pace cars, 86 Coupe, 88 Formula 3.4, 88 Coupe, 88GT |
#34
The T210 is probably the best overall compromise between capability and cost
but it isn't really up to flying IMC over the Sierra, but the 340 and 421 would be marginal for that too. Mike MU-2 "john szpara" wrote in message news:1105148624.5add2b1a2ce8325fe6c0b0c877086475@t eranews... On Sat, 08 Jan 2005 00:38:58 GMT, Paul Smedshammer wrote: ne in that case that would allow me to find a clear spot on either side of the Central Valley fog could have been a life saver. I was very lucky and will think twice before going VFR over the top again on a single engine. Paul Smedshammer Mooney M20F I've pretty much been talked out of buying a twin. The way they talk about it, it sounds like you'd have to be nuts to buy a twin, especially an older one. I guess I have 3 choices: 1. Buy a twin, go broke 2. Fly a singe, eventually get killed 3. Don't fly John Szpara Affordable Satellite Fiero Owner 2-84 Indy Pace cars, 86 Coupe, 88 Formula 3.4, 88 Coupe, 88GT |
#35
On Fri, 07 Jan 2005 15:35:06 -0800, john szpara
wrote: On Thu, 30 Dec 2004 13:58:07 -0800, wrote: Update I've eliminated the 421 as the first plane. I've been having a long discussion on the cessna pilot's association forum, and the 421 isn't the right airplane for now. Good decision, I've made a list of planes I'd be interested in: T210 P210 T310 320 340 Just kind of curious as to why you have eliminated everything but Cessna products. Piper and Beech also have good small single and twin aircraft with comparable price. For the single engine, look at the Bonanza, it has better performance in almost all categories. And for the twin, I would also look at the Beech Baron or the Piper Seneca's. If it is just because your familiar with Cessna products, don't short yourself. I don't know what kind of aircraft that you have been taught it (suspecting a 172) but if you are looking for familiarization and easy transition into a larger plane, the 210 is the only plane on your list that would look similar to the 172. After that, the panels and their flight characteristics, IMHO, are no where close. But I can't speak for the 340 as I have never flown or even been in one but I am suspecting it is similar to the 320. The 340 would be nice, but the costs and complexity are too close to the 421, so it is basically out. I could use some opinions on the others. I've pretty much decided to get my instrument rating in a single first, then go from there. Good decision on getting the Instrument in a single engine. I would suggest getting it in like a 172 because things happen a lot slower and it gives your mind a chance to react and make decisions before you go blowing thru a localizer or you cross a fix before deciding what type of hold entry you are suppose to be making. Good luck. Scott D. Scott D To email remove spamcatcher |
#36
On Sat, 08 Jan 2005 11:04:55 -0700, Scott D. wrote:
Just kind of curious as to why you have eliminated everything but Cessna products. Piper and Beech also have good small single and twin aircraft with comparable price. For the single engine, look at the Bonanza, it has better performance in almost all categories. And for the twin, I would also look at the Beech Baron or the Piper Seneca's. If it is just because your familiar with Cessna products, don't short yourself. I don't know what kind of aircraft that you have been taught it (suspecting a 172) but if you are looking for familiarization and easy transition into a larger plane, the 210 is the only plane on your list that would look similar to the 172. After I've done a lot of reading and research, checking performance numbers, operating costs and flying characteristcs. There is nothing special about the Pipers. I've flown the Warrior, Archer and Arrow. Bonanzas evidently are very sensitive to CG. I have time in a Mooney 231, great airplane, but barely 4 pax, forget fuel and baggage. Also a bit crampt compared to most Cessnas. For the money, a T210 is a better overall buy. I've flown them before, and love 'em. Fast, powerful, heavy feeling (feels smoother in flight), good loading numbers. I don't know much about the Piper twins, but the Cessnas seem to fit the bill for me nicely. Perhaps I should consider, say, a Seneca turbo, but if I want cabin class, the 340, 414 and 421 would be a better goal (although a Navajo would fit the bill as well). that, the panels and their flight characteristics, IMHO, are no where close. But I can't speak for the 340 as I have never flown or even been in one but I am suspecting it is similar to the 320. The 340 is quite different. The 320 is *slightly* larger than a 310, but you wouldn't be able to tell that much just looking at it. The 340 is cabin-class, a bit shorter and narrower than a 400-series. You might have trouble telling a 340 from a 414 just looking at the pictures. Good decision on getting the Instrument in a single engine. I would suggest getting it in like a 172 because things happen a lot slower and it gives your mind a chance to react and make decisions before you go blowing thru a localizer or you cross a fix before deciding what type of hold entry you are suppose to be making. Yeah, I need to take a slower track on this. No problem, I have lots of time to figure things out after I get my instrument rating. John Szpara Affordable Satellite Fiero Owner 2-84 Indy Pace cars, 86 Coupe, 88 Formula 3.4, 88 Coupe, 88GT |
#37
Look at the safety numbers for a Cheyenne I.
Safest twin flying. |
