In my 1974 Helio Courier, the avionics bus is powered by a contactor that is
activated by the avionics master switch. There is no circuit protection between the contactor and the avionics bus. The wiring between the contactor and the bus consists of two 12ga wires. There also doesn't appear to be any circuit protection in the field circuit for the avionics contactor. It seems to me that since there is no breaker between the contactor and the bus, the wire size should be sufficient to supply the rating on all the avionics CBs (32.5A total), but I don't know what the absolute maximium permissible temperature rise is before the avionics CBs pop. Would one 12ga wire be sufficient between the contactor and the avionics bus? Also, am I looking at the problem correctly, sizing the wire considering all the avionics CBs to reach their limits simultaneously? Mike MU-2 Helio Courier |
Your should use the biggest wire you can comfortable use so it will contribute
the least voltage drop under the full load of all avionics and electrical systems. 12Ga wire is typically rated for 20amps continuous. I would try to go with al least 10GA or even 8 if you can work with it. Basically, in that section of the circuit (before the breakers) the bigger the better, within reason of course. Mike Rapoport wrote: In my 1974 Helio Courier, the avionics bus is powered by a contactor that is activated by the avionics master switch. There is no circuit protection between the contactor and the avionics bus. The wiring between the contactor and the bus consists of two 12ga wires. There also doesn't appear to be any circuit protection in the field circuit for the avionics contactor. It seems to me that since there is no breaker between the contactor and the bus, the wire size should be sufficient to supply the rating on all the avionics CBs (32.5A total), but I don't know what the absolute maximium permissible temperature rise is before the avionics CBs pop. Would one 12ga wire be sufficient between the contactor and the avionics bus? Also, am I looking at the problem correctly, sizing the wire considering all the avionics CBs to reach their limits simultaneously? Mike MU-2 Helio Courier |
The length of the wire is less than two feet and the avionics draw less than
15A when not transmitting so voltage loss isn't really the big issue. I assume that they used two 12ga wires for flexibility compared to a single 8ga wire. Mike MU-2 Helio Courier "kontiki" wrote in message ... Your should use the biggest wire you can comfortable use so it will contribute the least voltage drop under the full load of all avionics and electrical systems. 12Ga wire is typically rated for 20amps continuous. I would try to go with al least 10GA or even 8 if you can work with it. Basically, in that section of the circuit (before the breakers) the bigger the better, within reason of course. Mike Rapoport wrote: In my 1974 Helio Courier, the avionics bus is powered by a contactor that is activated by the avionics master switch. There is no circuit protection between the contactor and the avionics bus. The wiring between the contactor and the bus consists of two 12ga wires. There also doesn't appear to be any circuit protection in the field circuit for the avionics contactor. It seems to me that since there is no breaker between the contactor and the bus, the wire size should be sufficient to supply the rating on all the avionics CBs (32.5A total), but I don't know what the absolute maximium permissible temperature rise is before the avionics CBs pop. Would one 12ga wire be sufficient between the contactor and the avionics bus? Also, am I looking at the problem correctly, sizing the wire considering all the avionics CBs to reach their limits simultaneously? Mike MU-2 Helio Courier |
At less than two feet I wouldn't worry about it. There will be more
potential resistance in the connections at the ends of the wirer than in the wire itself. Mike Rapoport wrote: The length of the wire is less than two feet and the avionics draw less than 15A when not transmitting so voltage loss isn't really the big issue. I assume that they used two 12ga wires for flexibility compared to a single 8ga wire. Mike MU-2 Helio Courier "kontiki" wrote in message ... Your should use the biggest wire you can comfortable use so it will contribute the least voltage drop under the full load of all avionics and electrical systems. 12Ga wire is typically rated for 20amps continuous. I would try to go with al least 10GA or even 8 if you can work with it. Basically, in that section of the circuit (before the breakers) the bigger the better, within reason of course. Mike Rapoport wrote: In my 1974 Helio Courier, the avionics bus is powered by a contactor that is activated by the avionics master switch. There is no circuit protection between the contactor and the avionics bus. The wiring between the contactor and the bus consists of two 12ga wires. There also doesn't appear to be any circuit protection in the field circuit for the avionics contactor. It seems to me that since there is no breaker between the contactor and the bus, the wire size should be sufficient to supply the rating on all the avionics CBs (32.5A total), but I don't know what the absolute maximium permissible temperature rise is before the avionics CBs pop. Would one 12ga wire be sufficient between the contactor and the avionics bus? Also, am I looking at the problem correctly, sizing the wire considering all the avionics CBs to reach their limits simultaneously? Mike MU-2 Helio Courier |
Thanks, but the question remains: should the wire size be based on the
expected continous load (15A) or the combined rating of the circuit breakers. As an example, suppose the expected load is 15A and the circuit breakers total 30A. A single 12ga wire would easily handle the 15A expected load and would momentarily be over loaded by 36% if all the avionics shorted simultaneously. Is this OK? My understanding from reading the Aero-Electric Connection book and AC 43.13-1B is that the 22A rating on a 12ga wire is the *continous* load that produces a 35C increase in tempertaure and that some amount of overloading is permitted for short durations. The Aero-Electric Connection says that in some cases (short length, well ventilated wire) it is OK to run 10A through 22ga wire for short durations (a 100% overload). Mike MU-2 "kontiki" wrote in message ... At less than two feet I wouldn't worry about it. There will be more potential resistance in the connections at the ends of the wirer than in the wire itself. Mike Rapoport wrote: The length of the wire is less than two feet and the avionics draw less than 15A when not transmitting so voltage loss isn't really the big issue. I assume that they used two 12ga wires for flexibility compared to a single 8ga wire. Mike MU-2 Helio Courier "kontiki" wrote in message ... Your should use the biggest wire you can comfortable use so it will contribute the least voltage drop under the full load of all avionics and electrical systems. 12Ga wire is typically rated for 20amps continuous. I would try to go with al least 10GA or even 8 if you can work with it. Basically, in that section of the circuit (before the breakers) the bigger the better, within reason of course. Mike Rapoport wrote: In my 1974 Helio Courier, the avionics bus is powered by a contactor that is activated by the avionics master switch. There is no circuit protection between the contactor and the avionics bus. The wiring between the contactor and the bus consists of two 12ga wires. There also doesn't appear to be any circuit protection in the field circuit for the avionics contactor. It seems to me that since there is no breaker between the contactor and the bus, the wire size should be sufficient to supply the rating on all the avionics CBs (32.5A total), but I don't know what the absolute maximium permissible temperature rise is before the avionics CBs pop. Would one 12ga wire be sufficient between the contactor and the avionics bus? Also, am I looking at the problem correctly, sizing the wire considering all the avionics CBs to reach their limits simultaneously? Mike MU-2 Helio Courier |
The circuit breaker has a special element the heats on overload within
a specific time period that trips the breaker. If the wire feeding the breaker is not rated for current draw then it can end up dissipating some of the heat energy required by the breaker. You now have this total load divided up by many smaller breakers so the feeding wire has to be rated for at least the total maximum normal current load, plus the additional load of the highest breaker current. As I said before, you cannot err on the high side in the instance. Use the heaviest wire you can reasonable deal with that meets the above criteria. Mike Rapoport wrote: Thanks, but the question remains: should the wire size be based on the expected continous load (15A) or the combined rating of the circuit breakers. As an example, suppose the expected load is 15A and the circuit breakers total 30A. A single 12ga wire would easily handle the 15A expected load and would momentarily be over loaded by 36% if all the avionics shorted simultaneously. Is this OK? My understanding from reading the Aero-Electric Connection book and AC 43.13-1B is that the 22A rating on a 12ga wire is the *continous* load that produces a 35C increase in tempertaure and that some amount of overloading is permitted for short durations. The Aero-Electric Connection says that in some cases (short length, well ventilated wire) it is OK to run 10A through 22ga wire for short durations (a 100% overload). Mike MU-2 "kontiki" wrote in message ... At less than two feet I wouldn't worry about it. There will be more potential resistance in the connections at the ends of the wirer than in the wire itself. Mike Rapoport wrote: The length of the wire is less than two feet and the avionics draw less than 15A when not transmitting so voltage loss isn't really the big issue. I assume that they used two 12ga wires for flexibility compared to a single 8ga wire. Mike MU-2 Helio Courier "kontiki" wrote in message ... Your should use the biggest wire you can comfortable use so it will contribute the least voltage drop under the full load of all avionics and electrical systems. 12Ga wire is typically rated for 20amps continuous. I would try to go with al least 10GA or even 8 if you can work with it. Basically, in that section of the circuit (before the breakers) the bigger the better, within reason of course. Mike Rapoport wrote: In my 1974 Helio Courier, the avionics bus is powered by a contactor that is activated by the avionics master switch. There is no circuit protection between the contactor and the avionics bus. The wiring between the contactor and the bus consists of two 12ga wires. There also doesn't appear to be any circuit protection in the field circuit for the avionics contactor. It seems to me that since there is no breaker between the contactor and the bus, the wire size should be sufficient to supply the rating on all the avionics CBs (32.5A total), but I don't know what the absolute maximium permissible temperature rise is before the avionics CBs pop. Would one 12ga wire be sufficient between the contactor and the avionics bus? Also, am I looking at the problem correctly, sizing the wire considering all the avionics CBs to reach their limits simultaneously? Mike MU-2 Helio Courier |
The breaker protects the wire. The wire needs to be able to handle
the draw. You'll do no good by using a beefier breaker. If this were your house, I'd say use the biggest baddest wire going, but if this is an airplane, use the wire appropriate for the load, be it 10, 18, 0r even 24 gauge. On Thu, 06 Jan 2005 20:30:39 GMT, "Mike Rapoport" wrote: Thanks, but the question remains: should the wire size be based on the expected continous load (15A) or the combined rating of the circuit breakers. As an example, suppose the expected load is 15A and the circuit breakers total 30A. A single 12ga wire would easily handle the 15A expected load and would momentarily be over loaded by 36% if all the avionics shorted simultaneously. Is this OK? My understanding from reading the Aero-Electric Connection book and AC 43.13-1B is that the 22A rating on a 12ga wire is the *continous* load that produces a 35C increase in tempertaure and that some amount of overloading is permitted for short durations. The Aero-Electric Connection says that in some cases (short length, well ventilated wire) it is OK to run 10A through 22ga wire for short durations (a 100% overload). Mike MU-2 |
Mike Rapoport wrote: In my 1974 Helio Courier, the avionics bus is powered by a contactor that is activated by the avionics master switch. There is no circuit protection between the contactor and the avionics bus. The wiring between the contactor and the bus consists of two 12ga wires. There also doesn't appear to be any circuit protection in the field circuit for the avionics contactor. It seems to me that since there is no breaker between the contactor and the bus, the wire size should be sufficient to supply the rating on all the avionics CBs (32.5A total), but I don't know what the absolute maximium permissible temperature rise is before the avionics CBs pop. Would one 12ga wire be sufficient between the contactor and the avionics bus? Also, am I looking at the problem correctly, sizing the wire considering all the avionics CBs to reach their limits simultaneously? Two 12ga wires should be adequate; one is not. As kontiki said, the maximum steady load for a 12ga wire is 20 amps. In the absence of a breaker on the supply, you are looking at the problem correctly, IMO. You could total the actual maximum current draw of the avionics and add an appropriate safety factor, but this will be very close to the total of the avionics CBs anyway. George Patterson The desire for safety stands against every great and noble enterprise. |
"G.R. Patterson III" wrote in message ... Mike Rapoport wrote: In my 1974 Helio Courier, the avionics bus is powered by a contactor that is activated by the avionics master switch. There is no circuit protection between the contactor and the avionics bus. The wiring between the contactor and the bus consists of two 12ga wires. There also doesn't appear to be any circuit protection in the field circuit for the avionics contactor. It seems to me that since there is no breaker between the contactor and the bus, the wire size should be sufficient to supply the rating on all the avionics CBs (32.5A total), but I don't know what the absolute maximium permissible temperature rise is before the avionics CBs pop. Would one 12ga wire be sufficient between the contactor and the avionics bus? Also, am I looking at the problem correctly, sizing the wire considering all the avionics CBs to reach their limits simultaneously? Two 12ga wires should be adequate; one is not. As kontiki said, the maximum steady load for a 12ga wire is 20 amps. In the absence of a breaker on the supply, you are looking at the problem correctly, IMO. You could total the actual maximum current draw of the avionics and add an appropriate safety factor, but this will be very close to the total of the avionics CBs anyway. George Patterson The desire for safety stands against every great and noble enterprise. The maximium draw of the avionics (speaker on, transmitting on both coms) is 20A, the continous draw (not transmitting) is under 15A. I realize that the max for *continous* use is 22A with 12ga, but how much overload is permissible for short term use (long enough for the avionics CBs to pop. Starter cables are often overloaded to 250% of their continous rating.. Mike MU-2 Helio Courier |
Mike Rapoport wrote: The maximium draw of the avionics (speaker on, transmitting on both coms) is 20A, the continous draw (not transmitting) is under 15A. I realize that the max for *continous* use is 22A with 12ga, but how much overload is permissible for short term use (long enough for the avionics CBs to pop. You should design the system such that the maximum load that continues for more than a second or two is no more than 80% of the breaker capacity. This is intended to prevent deterioration of the breaker due to frequent operation at temperatures close to the trip point. Design for wire is a different matter, since the heat will not cause the wire to deteriorate until you get it very hot. The risk with wire is that an overload will cause a fire by melting the insulation. I don't know how far you can go and still avoid this, but it should be well above 20 amps. I know that "delayed action" breakers in home wiring situations allow temporary surges of up to 25% of the rated capacity. George Patterson The desire for safety stands against every great and noble enterprise. |
| Thread Tools | |
| Display Modes | |
| Charging Question (Electrical - Not Credit) | Michael Bremer | Owning | 15 | January 20th 05 03:00 AM |
