#31
#32
Take one of these apart:
http://www.ballsonline.com/details.a...t=136&path=136 then reverse the little flapper valve to make it suck instead of blow... -- Dan D. .. "Jim Weir" wrote in message ... Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. The reason I say this is that I'm getting ready to pack a fairly large number of bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like to put each part in a "baggie" (sandwich bag or equivalent) along with a little preservative oil, and then suck the baggie down with a football needle stuck into the top closing mechanism just before sealing. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
#33
On Sat, 17 Jan 2004 19:03:40 GMT, Tom Pappano
wrote: Jim Weir wrote: Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. The reason I say this is that I'm getting ready to pack a fairly large number of bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like to put each part in a "baggie" (sandwich bag or equivalent) along with a little preservative oil, and then suck the baggie down with a football needle stuck into the top closing mechanism just before sealing. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com Those aquarium air pumps pull air from around the case. How about placing one inside a cheapo tupperware-type container with a "suck" port mounted on the container, you'd also need to run a "blow" port from the pump's normal output through the container wall. HTH Mike Patterson Please remove the spamtrap to email me. |
#34
Now *that's* clever. I admire clever.
Jim Mike Patterson shared these priceless pearls of wisdom: - -Those aquarium air pumps pull air from around the case. - -How about placing one inside a cheapo tupperware-type container with a -"suck" port mounted on the container, you'd also need to run a "blow" -port from the pump's normal output through the container wall. - -HTH - - -Mike Patterson -Please remove the spamtrap to email me. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
#35
On Fri, 16 Jan 2004 08:41:07 -0800, Jim Weir wrote:
Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. Thoughts? When I was in college, the chem labs used a venturi on water faucets to create a vacuum for filtration. I've tried Google to show where to get them, and failed. Just a little attachment with a side barbed fitting ... good vacuum levels, CHEAP, and appropriate for one who utilizes Bernoulli in other ways ... now where do I get it? |
#36
Jim,
That air compressor sprayer I gave you a couple of years ago is just a venturi. Use the liquid imput end to generate the vacuum. Unless ypu lost it, you already have what you need. -- Bob (Chief Pilot, White Knuckle Airways) "John Mireley" wrote in message ... Jim Weir wrote: Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. If you have a compressor, use a venturi vacuum generator. Harbor freight has them for about $10 from time to time. |
#37
I built a few of those for a hot tub several years ago.
Being a frugal and saving kind of guy, I've still got most of them tucked away. Simple construction really and capable of several inches of mercury. John On Mon, 19 Jan 2004 21:36:37 -0500, GeorgeB wrote: On Fri, 16 Jan 2004 08:41:07 -0800, Jim Weir wrote: Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. Thoughts? When I was in college, the chem labs used a venturi on water faucets to create a vacuum for filtration. I've tried Google to show where to get them, and failed. Just a little attachment with a side barbed fitting ... good vacuum levels, CHEAP, and appropriate for one who utilizes Bernoulli in other ways ... now where do I get it? |
#38
![]() "GeorgeB" wrote in message ... When I was in college, the chem labs used a venturi on water faucets to create a vacuum for filtration. I've tried Google to show where to get them, and failed. They sell them at WAL*MART and other pet stores for draining aquariums. Also had a similar device to drain the waterbed back when those things were fashionable. |
#39
Check Fisher Scientific under "aspirator".
"GeorgeB" wrote in message ... On Fri, 16 Jan 2004 08:41:07 -0800, Jim Weir wrote: Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. Thoughts? When I was in college, the chem labs used a venturi on water faucets to create a vacuum for filtration. I've tried Google to show where to get them, and failed. Just a little attachment with a side barbed fitting ... good vacuum levels, CHEAP, and appropriate for one who utilizes Bernoulli in other ways ... now where do I get it? |
#40
On Mon, 19 Jan 2004 17:45:27 -0500, Mike Patterson
wrote: On Sat, 17 Jan 2004 19:03:40 GMT, Tom Pappano wrote: Jim Weir wrote: Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. Just get a little "mityVac" hand pump used for testing vac advance etc on cars. Or if you really need it mechanized, make an adapter for your vacuum cleaner with an adjustable bleed The reason I say this is that I'm getting ready to pack a fairly large number of bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like to put each part in a "baggie" (sandwich bag or equivalent) along with a little preservative oil, and then suck the baggie down with a football needle stuck into the top closing mechanism just before sealing. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com Those aquarium air pumps pull air from around the case. How about placing one inside a cheapo tupperware-type container with a "suck" port mounted on the container, you'd also need to run a "blow" port from the pump's normal output through the container wall. HTH Mike Patterson Please remove the spamtrap to email me. |
Newbie Question - Vacuum vs Electric | Bill Denton | Aerobatics | 1 | April 15th 04 11:30 PM |
Anybody need a fuel transfer pump? | Roy Smith | Home Built | 1 | January 5th 04 05:53 PM |
NACA duct ventrui | Chris W | Home Built | 7 | October 27th 03 04:11 PM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
Fiberglass Vacuum Bagging Technique...Resin Infusion | Steve | Home Built | 5 | August 8th 03 06:10 PM |
