#31
Maule Driver wrote:
I was trying to think through the meaning of 'radar services' and 'flight following'. I was thinking that you are not bound to maintain a heading or an altitude while under FF (right?). So that would mean that you can deviate from your reported heading and altitude and enter Class D without necessarily notifying the controller. Sure, you can change heading and altitude without necessarily notifying the controller, but situational awareness and common sense do enter into it. The radar controller will make a decision on whether or not he needs to coordinate based on your altitude and direction of flight. If you need to change either or both, and that change might put you in a surface area your original altitude and heading would keep you clear of, it may not be a regulatory requirement to communicate your intentions but it only makes sense IMO. The particular situation described is problematic, because the facility providing radar services terminated them w/out a handoff. In that circumstance, I personally would probably contact the tower immediately, including in my call up something like "I had radar services from XXXX, I assume they coordinated with you". (because that's what's supposed to happen). Really puts the focus on situational awareness when that happens! Well, Steve may be correct that the communication requirements have been met, but I'd personally contact the tower in those circs, just in case there was a need to communicate; IME it takes several minutes to establish communication and radar contact with a busy approach facility, and I really don't want to be distracted from keeping a sharp look-out when I'm close to an airport, either. Cheers, Sydney |
#32
![]() "Robert Henry" wrote in message news:57hYa.26627$5f.25359@lakeread05... 14CFR 91.126d as referenced in 14CFR 91.129a? Note that FAR 91.126(d) also begins with, "Unless otherwise authorized or required by ATC,..." § 91.126 Operating on or in the vicinity of an airport in Class G airspace. (d) Communications with control towers. Unless otherwise authorized or required by ATC, no person may operate an aircraft to, from, through, or on an airport having an operational control tower unless two-way radio communications are maintained between that aircraft and the control tower. Communications must be established prior to 4 nautical miles from the airport, up to and including 2,500 feet AGL. However, if the aircraft radio fails in flight, the pilot in command may operate that aircraft and land if weather conditions are at or above basic VFR weather minimums, visual contact with the tower is maintained, and a clearance to land is received. If the aircraft radio fails while in flight under IFR, the pilot must comply with § 91.185. According to whom? I see several references to the "ATC facility having jurisdiction over the Class D airspace area." Can there be more than one facility with that authority? VFR towers actually have little authority over Class D airspace, about all they can do is require VFR aircraft to remain clear of it. Authority and responsibility for IFR and SVFR operations rests with the overlying Center or approach control facility, although some of that is often delegated to the tower. |
#33
![]() "Robert Henry" wrote in message news:bihYa.26631$5f.4102@lakeread05... Remember, this is not an arrival, but a through flight. Would it be likely for through IFR traffic to be that low that the controller would normally provide such coordination for a through IFR flight. I'm thinking that would be quite unusual. The lowest practical enroute IFR altitude tends to be the MIA/MVA plus 1000 feet rounded up to the next cardinal altitude. That tends to be more than 2500 AGL and thus above typical Class D airspace. |
#34
![]() "Robert Henry" wrote in message news:4djYa.26675$5f.6442@lakeread05... Regarding the airspace classifications for IFR, understood. The original assertion that I responded to was : Most likely he had already given a call to the class D tower and coordinated your transition as he would with IFR traffic. The essence of my point is still valid. How often will a radar controller coordinate an IFR transition through Class D airspace? As often as he has an IFR aircraft flying through Class D airspace. |
#35
"Sydney Hoeltzli" wrote in message ... Yes, it does. Why would you think it doesn't? [14CFR 91.129 does not specify that the pilot must establish or maintain communications with the control tower, simply with "the ATC facility providing air traffic services". ] 14CFR 91.126d as referenced in 14CFR 91.129a? 91.126(d) is not referenced from 91.129(a). Rather 91.126 (the whole section) is referenced from 91.129(a). And it seems that 91.126(a) indicates that 91.126 is only relevant to persons operating an aircraft on or in the vicinity of an airport in a Class G area. In this particular instance, I was not in the vicinity of an airport that was in a Class G area. The only airport that I was close to was Mc Entire ANGS which is not in a Class G area (it is in a Class D area). Therefore I'm thinking that 91.126 has no real relevancy to this particular instance. A radar facility which provides approach services to a class D airport certainly counts. According to whom? I see several references to the "ATC facility having jurisdiction over the Class D airspace area." Can there be more than one facility with that authority? This jurisdiction thing seems to be a big whole to me -- the FARs reference "...the ATC facility having jurisdiction..." but nowhere does the FAA make it clear to pilots exactly what that means. I believe this whole facilitated my confusion in the first place. Arden |
#36
Robert Henry wrote:
According to whom? I see several references to the "ATC facility having jurisdiction over the Class D airspace area." Can there be more than one facility with that authority? Of course. If you want to get picky, I understand that all the controlled airspace in the US is under the jurisdiction of the ARTCCs, who cede it to various TRACONS and surface areas by LOA (letters of agreement) which are regularly revised. More to the point, every day various ATC facilities cede control of aircraft which are actually within the airspace they control, to other facilities for various reasons. This simply wouldn't work if aviation law couldn't accept the concept of more than one facility with authority over a particular airspace area, provided the question of who has authority at the moment is properly coordinated. That's why controllers spend a lot of time on the phone... But in particular, the radar facility which provides approach services to a surface area controlled by a VFR tower has to count as having jurisdiction over that surface area in order to separate aircraft within it. Just try and get a vector out of a VFR tower, one with a BRITE.... Cheers, Sydney |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
Night of the bombers - the most daring special mission of Finnishbombers in WW2 | Jukka O. Kauppinen | Military Aviation | 4 | March 22nd 04 11:19 PM |
Which post-WW2 combat aircraft have not been used in combat? | Kirk Stant | Military Aviation | 96 | December 10th 03 03:03 PM |
Hispanic Hero Recalls Experiences | Otis Willie | Military Aviation | 0 | September 30th 03 10:02 PM |
#1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 03:04 AM |
