#31
Robert Perkins writes:
Regarding position, it's true that one VOR won't tell you your exact position. But if you combine pilotage from a chart with the relative position data ("southeast of the station", "west of the station", whatever.), you will have your position. You get an approximate position fix from a single VOR transmitter by flying perpendicular to the radial and timing how long it takes you to get to a different radial (say, 10 degrees off). It's not all that practical or accurate in real-life, of course, but it does sort-of work. Apologies in advance if I've missed the point of the thread and duplicated a previous posting. All the best, David -- David Megginson, , http://www.megginson.com/ |
#32
![]() "gross_arrow" wrote in message om... if the vor system is properly explained to begin with, it is not all that hard to grasp. learning anything "wrong" would, imho, only lead to subsequent confusion and necessitate eventual re-learning the correct way. It's for this EXACT reason that I posted about what Duniho was saying, and it has nothing to do with the simple 101 fact that a VOR bearing has nothing to do with aircraft heading. Any pre cross country student should know this. The problem with what he was saying is that he was STRESSING beyond what was normal under the circumstances of the discussion, that a single VOR bearing from a single VOR is sufficient enough to be of great value in estimating a geographical fix ,which it absolutely is not. Every student from day one should be taught that a single VOR bearing is just step one in obtaining a "fix". If a single VOR is all that's available in the aircraft, then a second VOR should be selected to establish the cross reference necessary to establish a "fix". The point I'm making here is a simple one. In teaching navigation to students, it's my opinion that it's just not appropriate for ANYONE to stress the importance of a single VOR bearing as sufficient in any way whatsoever in establishing a fix. This is a student group; not rec.aviation.pilots. People are learning to fly over here. There's a right way and a wrong way to approach the issues that are discussed on this particular group. I have no problem with Duniho per se'. I don't post to him at all if it's possible to avoid it. If I see something from ANYONE that peaks my interest as a flight instructor, I usually post a response. It's not meant to be personal, although in Duniho's individual case, I'll admit freely that I just don't have any use for the man. There is much in what he says at times that is both true and useful. This occasion wasn't one of those times; in my professional opinion anyway. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired |
#33
"Dudley Henriques" wrote in message hlink.net...
you are absolutely right about one VOR radial ident NOT being a positive"position" fix. True, having a directional bearing from a single VOR is better than having nothing at all, but even if only a single VOR is involved, it is ALWAYS recommended that a SECOND VOR be chosen, and a cross check made before considering what you have as a "fix" When discussing a position FIX, TWO is the magic number, NOT one! The second of the two can be DME, an ADF bearing, or a second VOR positive radial ident, but when discussing a position fix, ESPECIALLY on a student newsgroup, using a single VOR radial as an example of a geographical fix is wrong in my opinion, and I would urge all students NOT to begin thinking of a positive geographical fix on these terms.....PERIOD!!!! Dudley, I know you're aware of this, but since this is a student newsgroup I think it should be mentioned that it *is* possible to obtain a reasonable position estimate using a single VOR. These days, I suppose a pilot is more likely to be in a cockpit with 2 GPS and no VOR than to be in a cockpit with no GPS and 1 VOR, but let's suppose that's the situation. Only 1 VOR station can be received, for some reason. Of course you're correct that a single VOR simply places you on a line. So to determine position, we need additional information. We all know (or can see, if we think about it) that the distance between VOR radials varies with distance from the station by a function of 1 in 60. At 60 nm from the station, it's roughly 1 nm between radials, 30 nm it's roughly 0.5 nm between radials. IOW, we use the distance between radials to estimate our distance from the station. How to do so practically? We use time and our knowledge of our plane's approximate groundspeed. One centers a radial, then turns the OBS to deflect the needle 10 degrees, notes the time, and flies until the needle centers. Note the time again. Let's say one is flying a typical GA plane with a groundspeed of about 2 nm/min. Let's say it took 3 minutes to fly 10 degrees. We calculate our distance as 60 * (2 nm/min * 3 min)/10 or 36 nm from the VOR. To boil it down: *know your airplane's approx. speed in nm/min *calculate 6 * speed in nm/min * time in min to fly 10 deg Of course, for accuracy, one would need to correct for wind either by estimating groundspeed, or by flying in both directions and averaging the time. I mention it because I was taught this technique as a student, but many don't seem to be. As I said, Dudley, I'm sure you're aware of it, and I don't mean to contradict what I see as your basic point that a single VOR radial by itself does not, in fact, give position but rather only 1/2 of the information needed to derive position. The practical aspect of the above method is that awareness of the distance between radials as a function of distance from the station helps smooth VOR intercepts, something I need to remind myself of as I use GPS far more often than VOR these days. Best, Sydney |
#34
![]() "Snowbird" wrote in message om... "Dudley Henriques" wrote in message hlink.net... you are absolutely right about one VOR radial ident NOT being a positive"position" fix. True, having a directional bearing from a single VOR is better than having nothing at all, but even if only a single VOR is involved, it is ALWAYS recommended that a SECOND VOR be chosen, and a cross check made before considering what you have as a "fix" When discussing a position FIX, TWO is the magic number, NOT one! The second of the two can be DME, an ADF bearing, or a second VOR positive radial ident, but when discussing a position fix, ESPECIALLY on a student newsgroup, using a single VOR radial as an example of a geographical fix is wrong in my opinion, and I would urge all students NOT to begin thinking of a positive geographical fix on these terms.....PERIOD!!!! Dudley, I know you're aware of this, but since this is a student newsgroup I think it should be mentioned that it *is* possible to obtain a reasonable position estimate using a single VOR. These days, I suppose a pilot is more likely to be in a cockpit with 2 GPS and no VOR than to be in a cockpit with no GPS and 1 VOR, but let's suppose that's the situation. Only 1 VOR station can be received, for some reason. Of course you're correct that a single VOR simply places you on a line. So to determine position, we need additional information. We all know (or can see, if we think about it) that the distance between VOR radials varies with distance from the station by a function of 1 in 60. At 60 nm from the station, it's roughly 1 nm between radials, 30 nm it's roughly 0.5 nm between radials. IOW, we use the distance between radials to estimate our distance from the station. How to do so practically? We use time and our knowledge of our plane's approximate groundspeed. One centers a radial, then turns the OBS to deflect the needle 10 degrees, notes the time, and flies until the needle centers. Note the time again. Let's say one is flying a typical GA plane with a groundspeed of about 2 nm/min. Let's say it took 3 minutes to fly 10 degrees. We calculate our distance as 60 * (2 nm/min * 3 min)/10 or 36 nm from the VOR. To boil it down: *know your airplane's approx. speed in nm/min *calculate 6 * speed in nm/min * time in min to fly 10 deg Of course, for accuracy, one would need to correct for wind either by estimating groundspeed, or by flying in both directions and averaging the time. I mention it because I was taught this technique as a student, but many don't seem to be. As I said, Dudley, I'm sure you're aware of it, and I don't mean to contradict what I see as your basic point that a single VOR radial by itself does not, in fact, give position but rather only 1/2 of the information needed to derive position. The practical aspect of the above method is that awareness of the distance between radials as a function of distance from the station helps smooth VOR intercepts, something I need to remind myself of as I use GPS far more often than VOR these days. Best, Sydney What you are saying here is completely accurate. However, if you read back through Duniho's posts on this thread, there is not ONE instance where he even comes close to mentioning what you and I, and I assume Duniho knows as well, is the correct procedure for establishing a reasonable distance check from a single VOR using the procedure you have outlined. His entire context deals directly with the premise that a single VOR bearing used alone is valuable POSITIONAL information. This is not true at all. He does mention that additional information is "helpful", but he is STRESSING the point that a single bearing alone is valuable positional information. The reason I entered a reply was because he was "correcting" someone who had correctly stated that a single bearing from a VOR was only that....a single bearing, and NOT a position fix, which is absolutely correct. In fact, Duniho's opening statement was "How is this not a position fix?" As I said, this is a student group. Pilots who post here should be keenly aware of that. In aviation training, we work fairly hard to get student pilots to understand that TWO sources are required for position fixes, not ONE! That second source can indeed be a second VOR bearing, an ADF bearing, a DME readout, or indeed, a distance check on a single radial as you have mentioned. If Duniho or anyone else for that matter wants to post here that a single VOR bearing is valuable positional information, they should include the need for that second source as PARAMOUNT to obtaining a position fix, and not simply mention a second source as being desirable, but not necessary, as did Duniho in his explanations on this thread. That's my opinion, and as a professional flight instructor, I'll go with that. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired |
#35
![]() Dudley, I know you're aware of this, but since this is a student newsgroup I think it should be mentioned that it *is* possible to obtain a reasonable position estimate using a single VOR. No offense intended, but you might have missed a crucial point in earlier posts in this thread. There was a contention that position could be derived from a single VOR simply by knowing which radial the airplane was on at a given moment. Of course you're correct that a single VOR simply places you on a line. So to determine position, we need additional information. Which is exactly my original point... ...that a single VOR radial by itself does not, in fact, give position but rather only 1/2 of the information needed to derive position. Thanks, Sydney |
#36
#37
On 20 Aug 2003 04:33:13 -0700, Snowbird wrote:
[snip] How to do so practically? We use time and our knowledge of our plane's approximate groundspeed. One centers a radial, then turns the OBS to deflect the needle 10 degrees, notes the time, and flies until the needle centers. Note the time again. [double-snip] I mention it because I was taught this technique as a student, but many don't seem to be. FWIW, this technique is the subject of a couple of questions in the IFR written test question bank. It's an interesting academic exercise, but I can't see much practical use for it, especially IFR. Morris |
#38
#39
"Casey Wilson" wrote in message .. .
Dudley, I know you're aware of this, but since this is a student newsgroup I think it should be mentioned that it *is* possible to obtain a reasonable position estimate using a single VOR. No offense intended, but you might have missed a crucial point in earlier posts in this thread. There was a contention that position could be derived from a single VOR simply by knowing which radial the airplane was on at a given moment. No offense taken, and I didn't miss that point at all. I thought I said so, but, it was probably too well hidden by too many other words ![]() My intention was only to explain an additional technique. Perhaps a clearer way to make my point would have been to say, while I agree two of *something* is needed, a 2nd VOR or ADF is not needed; a 2nd radial from the same VOR, and a method of determining the distance between them, may substitute. Cheers, Sydney |
#40
Don Tuite wrote in message . ..
On Thu, 21 Aug 2003 02:19:32 -0000, (journeyman) wrote: FWIW, this technique is the subject of a couple of questions in the IFR written test question bank. It's an interesting academic exercise, but I can't see much practical use for it, especially IFR. Morris, as I think I mentioned, for the technique itself I concur. The IFR written questions, though, are just geared towards seeing if the pilot is aware of the relationship between distance from the VOR vs. distance between radials. I do think there's some practical use for that awareness. For one thing, it allows one to understand what the error may be on a VOR approach where the VOR is 20-30 nm off the field (there are a number of those around here). For another, it is helpful in understanding how to intercept a radial smoothly at varying distances from the station, something at which I could improve. I believe it's a variation on a technique in *American Practical Navigator* (Bowditch) for determining how far a sailing vessel is off a lee-shore headland. It was probably known to Odysseus. Interesting, Don. I suppose it's off-topic, but could you explain? The reference to Odysseus implies that it's very low technology. It may have been known to Odysseus, but my impression is, it's not known to many of today's pilots ![]() repaired, and our avionics repairman opined that 9 out of 10 pilots couldn't find our airport from a nearby VOR with 2 working NAVS, 2 working OBS, 2 hands, and a flashlight. He might have a point. Thanks, Sydney |
