#31
![]() "Mike Beede" wrote in message ... In article , Ron Natalie wrote: Your information on RAIM is wrong. What is unique about the RAIM used in IFR approved GPS's is not that it determines when the satellite geometry is giving you an error NOW, but computes if it will fail while during the expected duration of flying an instrument approach. That's RAIM *prediction*. RAIM is very capable of failing during an approach if you don't check the prediction ahead of time, at least on our Garmin 430. Yes...and if you read his document, he doesn't distinguish between RAIM (which many non-IFR units do just fine) and predictive rain. |
#32
![]() The "overlapping spheres" model is NOT how GPS works. It's the same as the stupid flashing light analogy for VOR. It perhaps gives someone some concept, but it's not accurate at all. The way GPS works is to use pairs of satellites to determine hyperbolids which are intersected with ones generated from other pairs. Ron, I looked up some information. I have not had time to completely digest it, but I do see how a GPS system could be designed to use pairs of satellites with hyperboloids. I think that my explanation is sufficient for a pilot level operational understanding of how GPS works. Among other sources propagating a similar explanation are Trimble and Garmin, so at least I am in good company. My purpose is to provide a brief conceptual idea of how GPS works. The primary purpose of my text is to provide practical guidance as to how to actually use GPS. Trimble's explanation is at http://www.trimble.com/gps/how.html. And Garmin's "GPS for Beginners" is available at http://www.garmin.com/support/userMa...ory=53&product =999-99999-20 I did a Google search, http://www.google.com/search?hl=en&i...id+GPS&spell=1 , and did find some sources indicating that positioning could be done using pairs of satellites and the intersection of hyperboloids. I am not sure if GPS receivers actually use the intersecting hyperploids or intersecting sphere model in their actual design. It appears that both are different techniques to solve the same problem. I am not an electrical engineer and am not sure which explanation is correct or if they are merely different solutions to the same problem. I appreciate you responding back to explain why you think my explanation was wrong. John Bell www.cockpitgps.com |
#33
approach if you don't check the prediction ahead of time, at least on our Garmin 430. Yes...and if you read his document, he doesn't distinguish between RAIM (which many non-IFR units do just fine) and predictive rain. Ron, I am open to argument and corrections of any misunderstandings that I might have. It was my impression that RAIM is strictly a integrity monitoring scheme rather than a predictive function. RAIM uses redundant satellite signals as a cross check to monitor whether any satellite signals are bad. Since a GPS knows the satellite orbits from the almanac, a program can be designed to predict if satellite positioning will be adequate to support RAIM at a given time and place. Receivers such as the Garmin 430 have this RAIM prediction feature. Knowing the satellite orbit information, it is also possible to predict and issue a notam for areas and times when RAIM will be unavailable. Using the same techniques for predicting RAIM coverage, it would be possible to warn of impending satellite geometry and coverage problems. I do not know whether or not any GPS receivers do this automatically beyond the RAIM prediction program such as in the AUX menu of the Garmins. I guess I understand RAIM as a monitoring the integrity of the satellite signal rather than a predictive function. However, I will agree that there are ways to predict whether or not RAIM will be available. I am open to corrections if you will explain your reasoning and possibly site sources. Thanks, John Bell |
#34
![]() "John Bell" wrote in message ... That's RAIM *prediction*. RAIM is very capable of failing during an \ I am open to corrections if you will explain your reasoning and possibly site sources. I believe you understand it, now go back and read your book. It is NOT the presence of RAIM that distinguishes the IFR GPS's (many non-IFR GPS's also have it), it's the predictive feature that is required/distinguishing. |
#35
![]() The way GPS works is to use pairs of satellites to determine hyperbolids which are intersected with ones generated from other pairs. That's the way sailors do it, but they do it by hand using hyperboloids plotted on their charts. If there is a mathematically equivalent way to do it, it might be one that is easier to program into a box, and maybe that's what an aviation GPS does. If the alternative is not mathematically equivalent, then one of them is just wrong. Jose -- (for Email, make the obvious changes in my address) |
#36
On Mon, 03 Nov 2003 17:38:07 +0100, Thomas Borchert
wrote in Message-Id: : IMHO it [GPS] gives you more than positional awareness. Aside from ground speed, and three dimensional position (and time of day), what other information does GPS provide? Although the aircraft's position is displayed relative to geographical features (roads, rivers, towns, ...), most GPS databases do not contain terrain data. GPS doesn't tell you anything about the powerplant(s), ATC, traffic, fuel, in flight and destination weather, pilot health, ... which are all part of situational awareness. Here's one definition of situational awareness: http://www.refresher.com/!pilot.html Situational awareness is an ongoing process of the continuous assessment and accurate interpretation of reality. Effective environmental scanning when combined with the awareness of the performance capability of the aircraft, and the self awareness of personal capabilities and skill of the pilot result in competency and precision in the execution of maneuvers, and flight safety. More he http://aviation-safety.net/events/FCV.shtml http://www.acespilotshop.com/pilot-s...-awareness.htm http://www.hpti.net/aviation/situational.html |
#37
Larry,
Aside from ground speed, and three dimensional position (and time of day), what other information does GPS provide? Wind speed and direction, for example. GPS doesn't tell you anything about the powerplant(s), ATC, traffic, fuel, in flight and destination weather, pilot health, Larry, I never said it would. Not with one word. I know all the stuff you provided for my education. Let's stop the nit-picking and get back to the original topic: The statement was that, while GPS is nice, moving maps don't do much for a pilot. I disagree. Strongly. -- Thomas Borchert (EDDH) |
#38
Thomas Borchert wrote
Wind speed and direction, for example. How??? By itself, a GPS cannot do this. Only as a part of a Flight Management System (or similiar NAV System) with an input of TAS and HDG can wind speed and direction be computed. A GPS will only provide TRK (course made good) and GS of the six item wind triangle.... HDG, TAS, TRK, GS, Wind DIR, VEL. Bob Moore |
#39
On Tue, 04 Nov 2003 16:00:48 +0100, Thomas Borchert
wrote in Message-Id: : Larry, Aside from ground speed, and three dimensional position (and time of day), what other information does GPS provide? Wind speed and direction, for example. I wasn't aware of that. What GPS has the capability to display wind speed and direction? GPS doesn't tell you anything about the powerplant(s), ATC, traffic, fuel, in flight and destination weather, pilot health, Larry, I never said it would. Not with one word. The phrase you used, situational awareness, implies those things. I know all the stuff you provided for my education. Then please display your knowledge of that "stuff" by using the correct terms. Let's stop the nit-picking and get back to the original topic: The statement was that, while GPS is nice, moving maps don't do much for a pilot. I disagree. Strongly. Your disagreement is apparent. Unfortunately, in this message thread, you fail to provide any examples of evidence that supports your contention. You contend that moving-map GPS is second only to the AI in its usefulness, but you don't say how it's useful. Your opinion is always welcome, of course. But the logic you used to arrive at that opinion would be significantly more useful information, IMHO. |
#40
Larry,
Ok, you had your fun jerking my chain, so let's let it go. If you fail to see the usefulness of a moving map display, I can't help you. Just don't use one! -- Thomas Borchert (EDDH) |
Must the PLANE be IFR-equipped to fly over17,500? | john smith | Home Built | 11 | August 27th 04 02:29 AM |
most of eastern Massachussetts airspace closed in July | Christopher C. Stacy | Instrument Flight Rules | 29 | June 19th 04 12:47 AM |
AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 06:12 PM |
Help - I busted into the Class B SEATAC airspace last night, does anyone have any advice ? | steve mew | Piloting | 38 | October 28th 03 06:08 PM |
FA: Congested Airspace: A Pilot's Guide | The Ink Company | Aviation Marketplace | 0 | August 10th 03 05:51 PM |
