#31
Evan:
It's degraded and slow to update if the gps source is 1 hz (as most are), also assumes zero sideslip and assumes pitch is related only to difference between TE vario and vertical speed. Despite those limitations, I would consider that it would be possible (but not recommended) for a pilot of average skill to cloud fly with such an algorithm. Gps derived attitude is used in autopilots in low cost uavs. There are also more capable gps-only attitude systems that use three gps receivers, the phase differences yielding attitude at high accuracy and high rate. You can see now why I shudder when gyros are singled out as the evil component that supposedly enables cloud flying. |
#32
This is all such a distraction.
Why not ban FLARM? After all, if you're in a contest and considering climbing into a cloud what better time is there to do it then when you know that every other glider around has FLARM so you can tell if there is one already in that cloud above you? FLARM is the ultimate safe cloud flying instrument for sailplanes in a contest! (Also makes sure no one else is nearby to see you.) |
#33
On Feb 24, 3:01*pm, wrote:
Evan: It's degraded and slow to update if the gps source is 1 hz (as most are), also assumes zero sideslip and assumes pitch is related only to difference between TE vario and vertical speed. Despite those limitations, I would consider that it *would be possible (but not recommended) for a pilot of average skill to cloud fly with such an algorithm. Gps derived attitude is used in autopilots in low cost uavs. There are also more capable gps-only attitude systems that use three gps receivers, the phase differences yielding attitude at high accuracy and high rate. You can see now why I shudder when gyros are singled out as the evil component that supposedly enables cloud flying. I think -- with respect to modern sailplanes -- you are optimistic :-). I've flown simulated instrument in Cessnas on riotous soaring days. I actually did a 45 minute check flight in a new type that way, all under the hood, from 500 agl on take off, to 1000 agl in the pattern one time. Made me green as all get out. But the point is, the effective bandwidth of a real gyro horizon is probably on the order of 20 or 30 Hz. I am certain I could not cloud fly in turbulence on 1 Hz. I might be able to keep wings level on an emergency letdown (flaps & spoilers out) in reasonably smooth air. I'm hoping our RC interpretation is similar because it leads to a simplification in the rules interpretation for guys with older (1 Hz) equipment and modern softwa "No gyros / No 3G/4G / No problem". QT says otherwise in one of these threads, but I have had private conversation with one of the other RC guys that sounded amenable to this in principle. I think it's defensible for the short term, if not preferred for the medium or longer term. The contest season is upon us, we need solutions, pretty much right now. |
#34
On Feb 24, 11:22*am, wrote:
To be fair, there are others within the XCSoar group who are more inclined to help work this out so pilots can have complying software. Hopefully they will succeed. To be very clear, it would be trivial for a programmer to disable the artificial horizon feature (which is a very tiny info box that I'd find barely useable even as a get-out-of-jail safety feature). Once the rules have been clarified, and as long as there are no requirements that an application cannot technically implement without major difficulties, some people either related or unrelated to the XCSoar project will step forward and will make an Android version available on the Android market that is "ready for competition". This would have the info box removed or permanently disabled, and it would display the fact that it rules-compliant loud and clear in the splash screen. The IGC log file would carry evidence of the software used. It's open source and licensed as free software, and there is no unsurmountable difficulty in doing this. It may be difficult to convince Max K to spend his time on this, but that does not mean that nobody else would step forward. So, relax. |
#35
On Feb 24, 1:15*pm, David Reitter wrote:
Once the rules have been clarified, and as long as there are no requirements that an application cannot technically implement without major difficulties, some people either related or unrelated to the XCSoar project will step forward and will make an Android version available on the Android market that is "ready for competition". *This would have the info box removed or permanently disabled, and it would display the fact that it rules-compliant loud and clear in the splash screen. *The IGC log file would carry evidence of the software used. It's open source and licensed as free software, and there is no unsurmountable difficulty in doing this. *It may be difficult to convince Max K to spend his time on this, but that does not mean that nobody else would step forward. What prevents yet another individual from compiling another Android version that reproduces the "rules-compliant" splash screen, and produces the same evidence in the IGC file, but nonetheless implements the AH capability (with a stealth interface, of course). I do have to agree with others that, at least with a 1 Hz GPS, the capability is probably worthless in a modern glider in a real cloud. So, why is this even being discussed? Marc |
#36
Is there an assumption being made that an AH is required to cloud fly?
It is completely possible to cloud fly without an AH or XC Soar or a Bohli compass or T&B with existing instruments in our cockpits, just not as easily. By disallowing XC Soar, all we are doing is just making it less easy to cloud fly only and not solving a thing. On 2/24/2012 12:52 PM, kirk.stant wrote: Ok EVERYBODY JUST TAKE A DEEP BREATH AND RELAX! This is getting blown way out of proportion, IMO. Fact: Cloud flying is prohibited in contests. Period. Anybody caught intentionally doing it should be immediately kicked out of the contest. Fact: While it is easy to prohibit old school gyro AH and T&Bs from cockpits, it is becoming practically impossible to ban newer devices and/or software that would have some capability to allow cloud flying, such as PNAs/droid phones, etc. Fact: Many glider pilots like having some sort of attitude indicator available - especially if they have personally experienced the need for one and not had it available. BTDT, for example on a late evening final glide in Illinois, heading West into the sun - there was ABSOLUTELY NO HORIZON VISIBLE, even though it was technically still VMC. I basically used the position of the sun on the canopy to stay shiny side up while cruising, and while thermalling, when the sun was out of sight behind, had literally no way to maintain pitch attitude. That was scary...and I sure would have liked to have had a simple AH display! Fact: PowerFlarm is pretty soon going to be "required" at contests. So - I suggest we change the enforcement of the cloud flying ban from the prohibition of any device that would allow it, to the use of "sportmanship", coupled with the ability of PowerFLARM to show what other gliders around you are doing. If I'm circling 500' below cloudbase, and see a PF track 2000' above me and climbing, and I look up and see nothing but cloud - then I'm going to report that glider, and it should be pretty easy to find out who it is via the turned in logger traces. Then stop worrying about it and race! Kirk 66 No gyros - yet... PS - I don't understand all this drivel about smartphones. Unless you are down in the weeds, good luck getting any signal from a carrier, and if you are dicking around with your phone trying to get the AH app to work as you are getting sucked into a clout, I doubt you will be much of a racing threat! Give it a rest. |
#37
On Feb 24, 5:00*pm, Marc wrote:
What prevents yet another individual from compiling another Android version that reproduces the "rules-compliant" splash screen, and produces the same evidence in the IGC file, but nonetheless implements the AH capability (with a stealth interface, of course). Absolutely nothing. You can make things a little more tamper-proof, just like hardware in loggers can be made somewhat tamper-proof. The software itself could be signed digitally, and distributed with a non-public key used to sign IGC logs, though verification of the digitally signed software would have to be done using separate (technical) means rather than a splash screen, and perfect protection of the secret IGC signature key that has to come with the software is impossible. However, building (compiling) a fake XCSoar version is technically somewhat involved. That is where the rules committee may come up with a solution that will make it more difficult, but not impossible to cheat. I do have to agree with others that, at least with a 1 Hz GPS, the capability is probably worthless in a modern glider in a real cloud. *So, why is this even being discussed? With the present hardware, that is probably true. |
#38
On Feb 24, 12:57*pm, stephanevdv wrote:
By the way: if you favour an "honor" system to control compliance of the AH rule, you could just as well believe a pilot when he tells you he won't go / hasn't been going IMC. The same people (if any) will try to cheat... This is so true we are still relying on honor system. I have a real problem banning LK8000 just because it has a screen that shows estimated angle of bank based on GPS position. I think this clarification needs to be changed a bit. I am all for RC efforts but banning a screen like this would be too much. We are talking about processing GPS data not sensors signals. Please think about this you have the same data by zooming into your moving map display. I hope Evan is going to sort all of this with RC before this thread reaches 200 entries. Andrzej |
#39
LK8000 will not "put much work into it" as well.
If XCSoar delivers a stripped version, we shall do the same. If XCSoar does not deliver a stripped version, and shall be put on the black list, LK8000 will be there too. Paolo , for LK8000 "Max Kellermann" ha scritto nel messaggio ... wrote: This statement was in response to the position by the XCSoar individual that indicated that they would not be providing a version that would permit users to comply with US rules as requested by the RC of the XCSoar group. No, no, you are now being very inaccurate. To remind you of how it really was, here's what you replied to: "As I mentioned earlier, we could publish a stripped version, but unless anyone can prove how this will be useful to catch cheaters, we won't put much work into it." Can you? Max |
#40
On Feb 24, 8:35*pm, "PCool" wrote:
LK8000 will not "put much work into it" as well. If XCSoar delivers a stripped version, we shall do the same. If XCSoar does not deliver a stripped version, and shall be put on the black list, LK8000 will be there too. Paolo , for LK8000 "Max Kellermann" ha scritto nel . de... wrote: This statement was in response to the position by the XCSoar individual that indicated that they would not be providing a version that would permit users to comply with US rules as requested by the RC of the XCSoar group. No, no, you are now being very inaccurate. *To remind you of how it really was, here's what you replied to: *"As I mentioned earlier, we could publish a stripped version, but *unless anyone can prove how this will be useful to catch cheaters, we *won't put much work into it." Can you? Max I will not use the stripped down version of LK8000. I will use the full version (even though I have that screen disabled) because the full version does not provide any support for gyro sensors therefore it shows the same information as moving map on high zoom level. I think these interpretations are going too far. I understand true Gyros but we are talking about software that does not use any gyro sensors. |
Rules Committee | Sam Giltner[_1_] | Soaring | 5 | September 23rd 08 11:07 PM |
US Rules Poll and Rules Committee Election | Ken Sorenson | Soaring | 0 | December 1st 06 01:36 AM |
SSA Rules Poll and Rules Committee Election | Ken Sorenson | Soaring | 2 | October 6th 06 03:27 PM |
US Rules Committee Election and Rules Poll | Ken Sorenson | Soaring | 1 | September 27th 05 10:52 PM |
FLASH! U.S.A. Rules Committee to Address Rules Complexity? | SoarPoint | Soaring | 1 | February 3rd 04 02:36 AM |
