#31
On Friday, June 1, 2012 3:25:27 PM UTC-7, Matt Herron Jr. wrote:
For a product specifically designed for gliders, the designers don't seem to have paid much attention to the form factor of either the brick or the antenna as relates to gliders. Maybe a shorter antenna with less gain would be better than a long antenna with no place to install properly. Also (Darryl may correct me on this) a dual antenna configuration on the brick (not the dipole) will be very directional, with most of the signal radiating fore an aft of the plane of the antennas. So be careful how you orient them. I will eventually get flarm, but this is just another reason to wait until the bugs are shaken out. Incorrect polarization of the butterfly display is another one. Hi Matt I suspect the Flarm developers have a good understanding of antenna gain and radiation pasterns (remember the more on-axis gain the less off axis gain and Flarm has to optimize all this to detect threats that may be on the horizon or significantly angled below or above the glider) to optimize their product. The lower gain stubby little antenna of a Zaon MRX by comparison only has to receive relatively powerful transponder signals (compared to the flarm-flarm signals) and how PCAS operates means its only really interesting to work at relatively short range whereas the 1090ES data-in capability of the PowerFLARM means you probalby want higher antenna gain PCAS/1090ES antenna than just for a PCAS only device). I am not sure what you mean by the "dual antenna configuration on the brick". But maybe I can try to see if I can cover that. Both the PowerFLARM portable and brick units have connectors for Flarm A and Flarm B antennas. The Flarm A antenna transmits an receives flarm messages, the Flarm B antenna only receives flarm messages. The Flarm B antenna is really intended for mounting in a location to give improved reception in directions that would be largely shielded today when using a single Flarm A antenna (ideally located on top of the glareshield). That shielded direction is mostly rearward (and also below the glider), with areas shielded by the pilot's body and carbon fiber fuselage etc. I see a Flarm B antenna mounted in future under or on top of my glider tail boom (on top to potentially avoid being too close to the transponder antenna). In a configuration like this overall signal sensitivity may or may not be that directional. It might be much more isotropic than a single antenna blocked to the rear by a pilots body and carbon fuselage. The 1090ES/PCAS antenna next to the Flarm A antenna on the PF Portable will result in some directionality of both antennas (weaker signal towards the otehr antenna -- I'd wild guess several 10% signal reduction) but I am sure that is all well understood as a part of many tradeoffs the developers have to live with. Or am I missing what you meant? Darryl |
#32
On 6/3/2012 6:51 PM, RAS56 wrote:
But c'mon now...for those of us who don't like to spend our time off upside down in our cockpits chasing wires, fussing with antennas, seeing if maybe the re-programming took "this" time or wondering if I just "smoked" my new gizmo in an install error . But c'mon now ... the stuff you mention, and what I've seen in Dave's pictures and in person, comes from not following the simple directions for placement of the portable PowerFlarm, which basically are "put it on top of the glare shield". There is only one cable (power) - how hard is that? My portable PF would not quite fit directly on top of the glare shield, so I built a simple bracket out of aluminum that holds it just aft of the glare shield, and 1/2" lower. The PCAS works as well as my Zaon PCAS did, I get the airliners' ADS-B, and an hour long encounter with another PF equipped glider convinced me it enough range for collision avoidance (about 1 NM), about 2 NM of range for "buddy flying" purposes (intermittent loss of the other glider, but still easy to track), and about 3 NM range if we within 1000' vertically. He also had a PF mounted on the top of the glares shield. I expect all those ranges to improve with ongoing changes; until then, I'm hoping _everyone_ I thermal with has one, because it was a very comfortable, stress-free experience compared to the usual neck-craning and radio chit-chat, trying to keep tabs on each other in thermals and when flying close to each other. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
#33
On Jun 3, 6:51*pm, RAS56 wrote:
But c'mon now...for those of us who don't like to spend our time off upside down in our cockpits chasing wires, fussing with antennas RAS56 - Sounds like you're worrying about alot without even investigating things. You want to keep it simple? STEP 1: Buy a Portable PowerFLARM STEP 2: Stick it on top of your glareshield STEP 3: Make sure the antennas are pointed straight up. STEP 4: (Optional?) Run a wire from your power-bus/battery to the PowerFLARM. How hard is that? --Noel |
#34
![]() "Evan Ludeman" wrote in message ... On Jun 1, 6:18 pm, RAS56 wrote: WOW! Who wouldn't want one??? The pilot that hasn't tried one. -Evan Ludeman / T8 ....Or the pilot just faced with a $2,500 expense for a new parachute. Yeah, yeah... I know... How much is my life worth? I have eyes and ears, but I don't have wings. But, to be positive, I've had pilots whith FLARM installed tell me that they see my Trig TT22 transponder (which I just installed a few months back) on their screen. That's impressive! |
#35
On Jun 4, 1:59*am, "noel.wade" wrote:
On Jun 3, 6:51*pm, RAS56 wrote: But c'mon now...for those of us who don't like to spend our time off upside down in our cockpits chasing wires, fussing with antennas RAS56 - Sounds like you're worrying about alot without even investigating things. *You want to keep it simple? STEP 1: Buy a Portable PowerFLARM STEP 2: Stick it on top of your glareshield STEP 3: Make sure the antennas are pointed straight up. STEP 4: (Optional?) Run a wire from your power-bus/battery to the PowerFLARM. How hard is that? --Noel I think most people will find that the brick is an easier, more cockpit friendly install. I would recommend against buying a portable unless you are 100% confident that you have a good place to put it. -Evan Ludeman / T8 |
#36
The optimum FLARM antenna installation:
http://www.airforce-technology.com/p...2-aircraft.jpg Sorry, couldn't help myself. "Darryl Ramm" wrote in message ... On Friday, June 1, 2012 3:25:27 PM UTC-7, Matt Herron Jr. wrote: For a product specifically designed for gliders, the designers don't seem to have paid much attention to the form factor of either the brick or the antenna as relates to gliders. Maybe a shorter antenna with less gain would be better than a long antenna with no place to install properly. Also (Darryl may correct me on this) a dual antenna configuration on the brick (not the dipole) will be very directional, with most of the signal radiating fore an aft of the plane of the antennas. So be careful how you orient them. I will eventually get flarm, but this is just another reason to wait until the bugs are shaken out. Incorrect polarization of the butterfly display is another one. Hi Matt I suspect the Flarm developers have a good understanding of antenna gain and radiation pasterns (remember the more on-axis gain the less off axis gain and Flarm has to optimize all this to detect threats that may be on the horizon or significantly angled below or above the glider) to optimize their product. The lower gain stubby little antenna of a Zaon MRX by comparison only has to receive relatively powerful transponder signals (compared to the flarm-flarm signals) and how PCAS operates means its only really interesting to work at relatively short range whereas the 1090ES data-in capability of the PowerFLARM means you probalby want higher antenna gain PCAS/1090ES antenna than just for a PCAS only device). I am not sure what you mean by the "dual antenna configuration on the brick". But maybe I can try to see if I can cover that. Both the PowerFLARM portable and brick units have connectors for Flarm A and Flarm B antennas. The Flarm A antenna transmits an receives flarm messages, the Flarm B antenna only receives flarm messages. The Flarm B antenna is really intended for mounting in a location to give improved reception in directions that would be largely shielded today when using a single Flarm A antenna (ideally located on top of the glareshield). That shielded direction is mostly rearward (and also below the glider), with areas shielded by the pilot's body and carbon fiber fuselage etc. I see a Flarm B antenna mounted in future under or on top of my glider tail boom (on top to potentially avoid being too close to the transponder antenna). In a configuration like this overall signal sensitivity may or may not be that directional. It might be much more isotropic than a single antenna blocked to the rear by a pilots body and carbon fuselage. The 1090ES/PCAS antenna next to the Flarm A antenna on the PF Portable will result in some directionality of both antennas (weaker signal towards the otehr antenna -- I'd wild guess several 10% signal reduction) but I am sure that is all well understood as a part of many tradeoffs the developers have to live with. Or am I missing what you meant? Darryl |
#37
.....You want to keep it simple? STEP 1: Buy a Portable PowerFLARM STEP 2: Stick it on top of your glareshield STEP 3: Make sure the antennas are pointed straight up. STEP 4: (Optional?) Run a wire from your power-bus/battery to the PowerFLARM. How hard is that? --Noel This (Noel's comment) is what I "planned/hoped" to do in my Genesis. Interested if there have been any reports of interference between a CAI Model 20 mounted near Portable Flarm(?). My Model 20 is mounted behind instrument pod with antenna ~flush with top. The portable would be about 10" ahead on top of pod (so antenna bases would be ~1" above GPS-20 antenna). Flarm antennas can easily stand vertical. Any comments appreciated! Curt - 95 |
#38
On Jun 3, 1:53*pm, Dave Nadler wrote:
Hi All - I've added more installation info:http://powerflarm.us/powerflarm-installation-notes/ Also, a few pilots have posted notes about their PowerFLARM experiences (and we encourage you to do likewise) hehttp://powerflarm.us/2012/05/powerfl...fflin-and-elsw... Hope you find these helpful, Best Regards, Dave "YO electric" Quoting from Dave's website: Suggestion for Glare-Shields that Jettison with Canopy [i.e. Schleicher -JC] Make an antenna mount with a large base shaped to match glare-shield (hint: lay up a fiberglass base on top of the glare-shield). Cut a small hole through the glare-shield for the antenna and cable. Fasten the base of the mount to the underside of the glare-shield with a small amount of velcro. This makes it easy to remove the canopy/glare- shield, and safe in a bail-out. Comment: C'mon Dave. This is supposed to be a consumer product ready for release to the glider market. And you really are suggesting that half this market needs to go lay up fiberglass to install it? That's beyond half-baked. We really need to see one decent Shleicher install picture! Again -- the world is full of dipole antennas with physical and electrical connectors at the base. Why oh why are you not using such an antenna in this most obvious place for it? John Cochrane |
#39
On Jun 4, 9:46*am, CLewis95 wrote:
This (Noel's comment) is what I "planned/hoped" to do in my Genesis. Interested if there have been any reports of interference between a CAI Model 20 mounted near Portable Flarm(?). *My Model 20 is mounted behind instrument pod with antenna ~flush with top. *The portable would be about 10" ahead on top of pod (so antenna bases would be ~1" above GPS-20 antenna).. *Flarm antennas can easily stand vertical. Any comments appreciated! Curt - 95 Curt, I have a Model 20 located under the glareshield of my Nimbus 3. It is less than a foot ahead of and below the portable FLARM mounted on top of the glare shield. Only time I had a problem was at the end of one day, when pushing back to the tiedown spot, the FLARM came loose from it velcro mount and slide to the front of the glareshield. The GPS location in the Cambridge took a big jump away from Garner Field (during the Open Nationals last year, at Uvalde). Seemed to have as good a FLARM reception and transmit as anyone else there. I also have a flight with the portable installed on top of the panel on my BS1. Cambridge Model 20 secured to the top of the panel, probably not more than 2-3 inches between the boxes. No problems with the Cambrigde log. Not sure of the FLARM performance with that installation. Couldn't get my antenna vertical and there was only one other FLARM equipped plane flying, so I need to make a different mount. Anyone interested in making cables in standard lengths (6 inch increments, maybe?) to go from the portable to a base mount for the supplied antenna? Yes, YO, I am working on getting more seperation of the two. If the prefered antenna seems to be the dipole with a simple plastic angle bracket for mounting, are we going to see this become the standard antenna shipped with FLARM units at some point in the future? Less m ounting height required than the rubber duckie that had to be mounted at the top of the portable because of the batter box. Just a thought. Steve Leonard ZS, VJS, KN, PN, and a few others. |
#40
On Jun 4, 7:25*am, Evan Ludeman wrote:
I think most people will find that the brick is an easier, more cockpit friendly install. *I would recommend against buying a portable Evan - I was specifically responding to RAS56's complaints about complexity. The Portable is (by definition) a self-contained unit with no worries about an external display or other wiring. --Noel |
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
If your bored, think about this and notes about Ely, Nv. | [email protected] | Soaring | 15 | February 9th 07 11:30 PM |
Notes from the RAP pre-OSH party | Viperdoc | Piloting | 2 | July 23rd 06 06:24 PM |
DG500 AD notes | Sailplane Mechanic | Soaring | 2 | August 27th 04 05:35 PM |
A few notes from Uvalde | Dave Nadler YO | Soaring | 0 | August 13th 04 05:26 PM |
