PowerFLARM Range Issues - Part Two with info from todays flights
Old October 17th 12, 12:21 PM posted to rec.aviation.soaring
Default PowerFLARM Range Issues - Part Two with info from todays flights
David,
that's a good idea and we'll keep it in mind when it comes
to further development decisions!
Best
--Gerhard
My solution to that is simple. The third party app or device can as
easily keep track of all thermalling/climbing gliders withing Flarm
range at all times and present them to the pilot in some order of
preference such as some smart combination of distance and climb rate.
Then all the struggling pilot needs to do is, for example, tap on the
first one on the list (~1 second) and voila, he gets the voice vector.
All am saying is that it would be highly beneficial to keep a forward
looking approach because it has been shown again and again we don't
really know what the killer app is going to be that will stimulate the
widest adoption. And the widest adoption is what the Flarm concept
(and we all) needs for it to really succeed.
Best,
David
(proud early adopter of many many devices, including a Brick
PowerFlarm).
  #32
Old October 20th 12, 01:08 AM posted to rec.aviation.soaring
pcool
That's how LK8000 is actually doing since two years, and maybe LX8000/9000
(the Big brother).
You enter a list of traffic ids, you can keep this list sorted by distance,
direction, lift.
You choose the traffic you want to monitor (we call it target)
Target is now available as a normal "goto", already selected as destination.
You can flight to the target always looking at it in a sight, telling you if
(at your current glide ratio) you will get there higher or lower.
Or you look at the target on the map, just like a waypoint, with an arrival
altitude relative to it.
But apart from user interface aspects, there is an important issue here to
be kept in mind, if you are thinking about improving traffic monitor for
non-safety purposes.
Flarm traffic will not be always broadcasted, even if in range.
And even if in range, your antenna might not be in view with the other
antenna, resulting in a perfect "invisible" traffic maybe a few miles away.
This is normal, as we have experienced so far in europe.
So the concept of "traffic" on display is misleading, a lot! In fact, I came
to conclusion that it is better to have 3 kind of traffic objects:
1- Live traffic (data received in the last 10-20 seconds for example)
2- Ghost traffic (data missing since up to a minute, or two.. dont remember)
3- Zombies. Traces of old traffic that disappeared.
Experience shows that zombies or ghost can reappear as live anytime, maybe 1
second after they were elected non-live.
It depends on the above factors.
Now if you log the nearby trafic data, for showing a trace of objectes, like
we do, in different colors to show where they actually climbed or sinked,
this trace will be held valid even if it belongs to an object that it is no
more visibile, for any reason, but still a ghost or a zombie.
I know this might sound funny, at least, with all these ghosts and zombies
going around, but this is like it is really happening in the air when you
transmit with small antennas at 10mw, and the antenna is not placed
externally to the canopy, with lots of carbon fiber around..
It is actually very fun to think about the infinite approaches a
manufacturer can choose from, for its technology.
Personally, I think the little butterfly is such a nice device to have, and
so simple to use...!
But people want more gadgets and beep machines aboard..
paolo
David,
Best
--Gerhard
Best,
David
PowerFlarm).
  #33
Old October 20th 12, 10:40 AM posted to rec.aviation.soaring
Kimmo Hytoenen
Paolo,
very good writing, thank you.
This traffic display you described also improves situation
awareness about the traffic near you. You can see if there is
someone near you, gliding the same direction, and you can see
his call-sign. If he keeps in the blind spot behind you, you can
ask on radio if the other pilot is aware of situation (without this
application he might not) and what are his/her intentions.
-kimmo
maybe LX8000/9000
(the Big brother).
distance,
direction, lift.
destination.
telling you
if
an arrival
issue here to
monitor for
the other
miles away.
fact, I
came
example)
dont
remember)
anytime, maybe
1
objectes,
like
or sinked,
is no
and zombies
when you
placed
have, and
paolo
  #34
Old October 20th 12, 05:25 PM posted to rec.aviation.soaring
On Saturday, October 6, 2012 12:11:32 PM UTC-4, bumper wrote:
For those of us who don't relish the "opportunity" to dive in and experiment with config files and such . . . Butterfly has a free config file builder that does it for you using a multiple choice format that even I can figure out.
http://www.butterfly-avionics.com/in...core-config-en
bumper
Bumper,
thanks for the pointer. I used this site just now to generate a config file, and it works GREAT!
TA
  #35
Old October 20th 12, 08:21 PM posted to rec.aviation.soaring
(the Big brother).
direction, lift.
paolo
David,
Best
--Gerhard
Best,
David
PowerFlarm).
This is a very impressive capability of LK8000! And pretty much what I had in mind, although I indicated speech output to reduce head-down time.
The classification of targets (Live, Ghost, Zombies) is sensible given the constraints of the system (10mW power output) which limit the continuous visibility of targets (which is rather unfortunate). Recording the location of another glider in the recent past and it's climb rate at the time can be very useful information for those that like team flying.
Combined with some good audio alerting capability is there really a need for a dedicated Flarm display (ie, Butterfly)? Assuming of course the Collision Alert capability on the app is as fast as it is with the Butterfly display. Wouldn't want any further delays on that.
Although I keep recommending pilots to "fly your own flight and not someone else's flight, make your own decisions, good and bad", team-flying is fun once in a while and actually the preferred modality for some pilots. And besides, a friend's thermal can be quite handy at times. Plus, if it cuts down on radio chatter, then everyone wins.
There is another thread on leeching. The fundamental question is: should one rely just one's own capabilities to find all lift or is it a collaborative effort? Should one use technology to find lift (ie, thermal detectors, in the not too distant future). Each pilot should answer this question for themselves depending on what their goals are. Also this question has different meaning depending on the context (ie, competition vs recreational)
What is pretty clear is that the widest adoption of Flarm is beneficial to all soaring pilots as a group, regardless of the individual's main motivation to use it. So casting the widest net of adoption is what we should be aiming for.
David
PowerFlarm BRICK range issues - are we alone???? Mark Soaring 79 October 17th 12 12:17 PM
PowerFLarm expected range [email protected] Soaring 6 August 30th 12 03:43 PM
PowerFLARM deployment issues SoaringXCellence Soaring 6 December 6th 10 12:23 AM
Places for good info on US-Canada flights? Colin W Kingsbury Piloting 9 January 27th 05 12:03 AM
FAA to End part 91 Sightseeing flights? Vaughn Rotorcraft 7 November 2nd 03 01:20 AM
