Question about spoilers and pitch stability
Old February 1st 13, 04:42 AM posted to rec.aviation.soaring
Larry Suter
Default Question about spoilers and pitch stability
In his article on avoiding PIO in Grob 103's,
http://www.soaringsafety.org/pilots/ic8.htm
Dean Carswell writes, "the more the airbrakes are closed, the less pitch stability the Grob will have, making a PIO more likely if otherwise mishandled"
Is there a simple explanation why opening the spoilers increases the pitch stability? Does it somehow move the center of lift further aft? I believe increasing the separation between the cg and center of lift is the classic way to increase pitch stability.
And if that's how it works, why does the center of lift move aft? I would guess spoilers destroy the lift downwind of their location, causing the center of lift to move forward.....
Larry
Stability variation WingFlaps Piloting 2 April 28th 08 03:45 AM
Towing stability studies Dan G Soaring 27 February 21st 08 08:38 PM
Tow vehicle -- electronic stability control Greg Arnold Soaring 4 June 8th 06 12:31 PM
Atmospheric stability and lapse rate Andrew Sarangan Piloting 39 February 11th 05 05:34 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
