#31
![]() "Ron Natalie" wrote in message . .. "Dudley Henriques" wrote in message news:IIp3c.4260$ Here in the UK, setting the altimeter to This, considering an average atmosphere, denies you setting an altimeter to 0 on any airport runway above about 2500 to 3000 feet MSL!!! The highest elevation (Ben Nevis) in the UK is under 4500 feet. The highest airport isn't even close to that. Discovering this is the answer. It's basic enough, but the regulations writers in the UK leave it to the pilots to discover this limitation instead of just telling everyone that a QFE setting can only be used at airports below the ASL limits for the Kollsman window. All I've been able to find in the UK regs is that QFE is an option. They don't state any limitations at all for elevation as far as I've been able to discover; perhaps not for the UK pilots, but it's not too clear for pilots flying into the UK for the first time. It's interesting, and confuses a lot of pilots. Dudley |
#32
![]() "Stefan" wrote in message ... Dudley Henriques wrote: It's amazing that the governing agencies who write this stuff just assume that sooner or later all of us will just figure out that only airports under 3K feet are eligible for the QFE option. Interesting!!! Don't you have this backwards? Shouldn't it read: Just because QFE isn't common in the USA, the manufactorers assume that it's not common elsewhere either, and sell unsuitable instruments? Stefan Could be, if the Brits altimeters were indeed superior, but I'm understanding so far from everybody that the UK altimeters don't actually have a wider Kollsman range than the US altimeters, and that it's the same above sea level limit there as we have here; so that would apparently take you right back to square one with understanding the regs, wouldn't it? :-)) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
#33
![]() Dudley Henriques wrote: Well, not really. If you can get the actual station pressure, (not the altimeter setting for the station reduced to sea level ) and the airport elevation is within the Kollsman limits, the altimeter should read 0 on the ground after landing. This is the definition as I understand it, for the QFE setting. Dudley OK then what's the point? Why would you want the altimeter to read zero for normal flying? |
#34
In article et,
"Dudley Henriques" wrote: Hey, you mountain types out there :-) I'm doing some research on a safety issue and need your help . I need a post from someone flying out of Colorado somewhere, preferably Telluride or a field very close to Telluride. I need as close to the highest elevation in the U.S. as I can get. I'm not dealing with this issue in the context of right or wrong as it pertains to mountain flying. I need to know if the Kollsman window in your altimeters has a wide enough range to allow you, IF YOU DESIRED TO DO SO, to set your altimeters to 0 elevation on a consistent basis before take off at your field instead of a MSL setting. Again, I'm only interested in the possibility, not the right and wrongs involved with doing this. Thanks, Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt I think AAL was the last major to set QFE for takeoff and landings. They special ordered altimeters that would handle Mexico City. -- Ron |
#35
Normally you wouldn't. The whole world uses MSL! Why the Brits have a QFE as
an option is a big mystery to most of us in the US, but apparently they have it as an option for pattern and VERY local work. Personally, I would never use it. I have zeroed my altimeter for low altitude demonstration aerobatics, but I'd never recommend that pilots use a 0 set for any other purpose...and only under special circumstances with aerobatics. Dudley Dudley "Newps" wrote in message news:Oqr3c.92126$PR3.1462720@attbi_s03... Dudley Henriques wrote: Well, not really. If you can get the actual station pressure, (not the altimeter setting for the station reduced to sea level ) and the airport elevation is within the Kollsman limits, the altimeter should read 0 on the ground after landing. This is the definition as I understand it, for the QFE setting. Dudley OK then what's the point? Why would you want the altimeter to read zero for normal flying? |
#36
![]() Newps wrote: OK then what's the point? Why would you want the altimeter to read zero for normal flying? If you can set the altimeter such that it reads 0 on the field, you can maintain pattern altitude without having to do any arithmetic and without looking up the field elevation. Of course, someone's gonna have to tell you the pressure at the field. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. |
#37
I wonder if having the extra raw data QFE monitor by the FO on approach was
worth the cost of retrofitting the airplanes? I understand in the end they crap canned the idea anyway. Dudley "Ron Parsons" wrote in message ... In article et, "Dudley Henriques" wrote: Hey, you mountain types out there :-) I'm doing some research on a safety issue and need your help . I need a post from someone flying out of Colorado somewhere, preferably Telluride or a field very close to Telluride. I need as close to the highest elevation in the U.S. as I can get. I'm not dealing with this issue in the context of right or wrong as it pertains to mountain flying. I need to know if the Kollsman window in your altimeters has a wide enough range to allow you, IF YOU DESIRED TO DO SO, to set your altimeters to 0 elevation on a consistent basis before take off at your field instead of a MSL setting. Again, I'm only interested in the possibility, not the right and wrongs involved with doing this. Thanks, Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt I think AAL was the last major to set QFE for takeoff and landings. They special ordered altimeters that would handle Mexico City. -- Ron |
#38
![]() Dudley Henriques wrote: It's amazing that the governing agencies who write this stuff just assume that sooner or later all of us will just figure out that only airports under 3K feet are eligible for the QFE option. Interesting!!! If the Feds had to explain everything in the AIM, it would be the size of the Encyclopedia Brittanica. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. |
#39
![]() Stefan wrote: Don't you have this backwards? Shouldn't it read: Just because QFE isn't common in the USA, the manufactorers assume that it's not common elsewhere either, and sell unsuitable instruments? It's not unsuitable if it does the job, and it appears that the Kollsman range is quite adequate for those areas in which QFE is the norm. It is also the case that the altimeter design predates the regulations by about 70 years, so it's not backwards at all. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. |
#40
![]() "G.R. Patterson III" wrote in message ... Dudley Henriques wrote: It's amazing that the governing agencies who write this stuff just assume that sooner or later all of us will just figure out that only airports under 3K feet are eligible for the QFE option. Interesting!!! If the Feds had to explain everything in the AIM, it would be the size of the Encyclopedia Brittanica. EVERYTHING!!!! Hell George...I'd be happy if they only explained ONE thing!!! :-)))) Dudley |
Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 02:16 PM |
Please help -- It's down to the wire | Jay Honeck | Home Built | 12 | July 14th 04 06:05 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
Airport Manager position, Fitchburg, MA | David Reinhart | Piloting | 6 | August 12th 03 11:46 PM |
