Absurdity of US Rules (in fairness to FAI)
Old August 15th 13, 12:32 AM posted to rec.aviation.soaring
Default Absurdity of US Rules (in fairness to FAI)
On Wednesday, August 14, 2013 5:58:53 PM UTC-4, wrote:
Jerzy:
Perhaps you misunderstand the rule. You do NOT have to stay below start top height the whole time before the start. You only need to stay down there for two minutes. So in these situations, fly around above MSH to your heart's content, come down for two whole minutes, and then start.
John Cochrane
Do you really think that XG does not know the rules? Almost insulting.
  #32
Old August 15th 13, 03:08 AM posted to rec.aviation.soaring
Tim Taylor
Changes I would like to see is:
1. Reduce the time to one minute. Not sure where the two minutes came from.. There is no need for that long and it just puts more pilots in the area longer.
2. Make the start penalty realistic for leaving too soon. Currently is is about 200 points for a two minute error. Totally unreasonable. How about a maximum of 50 points.
XG, the top at Logan was 1500 to 1700 feet above most of the ridges at Logan. The reason for not higher than 11,000 is that then too many pilots spend too much time hanging around trying to get that last 1000 feet in the start gate. Also at Logan very few pilots start out the top, it is usually a waste of time and costs you points.
The only site that starting out the top is really beneficial is Parowan and sometimes at Hobbs, other than that most sites it is not that important.
TT
  #33
Old August 15th 13, 12:38 PM posted to rec.aviation.soaring
flgliderpilot[_2_]
I don't fly contests (yet) but, couldn't pilots just be required to leave the start cylinder below a max altitude AND airspeed? The would eliminate the need for a 2 minute delay to prevent zooming would it not?
  #34
Old August 15th 13, 01:41 PM posted to rec.aviation.soaring
The pilot must leave the cylinder below max height and have at least one fix in the cylinder after the task is open. In order to prevent diving starts of any kind, the requirement is to be below the top for 2 minutes. This eliminates any incentive to try to carry excess energy into the cylinder. During the development of the rule, the RC looked at how long useful energy was retained and found it to be somewhat over a minute. 2 minutes was selected as not being onerous. Speed is also limited, even though this is very hard to enforce due to wind amnd logs not recording airspeed. That has not proven to be a problem.
With a 5 mile cylinder radius, and usually a couple of decent choices for start location, my experience is that the traffic issue is within the control of the pilot and is over stated.
Pilots gather in a clot because they choose to, not because they have to. Commonly the best strategy is to try to find your own best place to start.
UH
  #35
Old August 15th 13, 02:45 PM posted to rec.aviation.soaring
K
TT,
Would this not be more of a function of conditions? As you know I am far from being a racing veteran but I spent some time at the last contest I attended analyzing my starts and it seems that (For example) if one is in a strong climb on a blue day it would be an advantage to stay with it out the top.. Conversely, when CU were popping on the ridge between the start and the first TP, I would plan exiting the side of the start gate whenever I had the altitude to connect with the clouds and 120 seconds on SYM. What am I missing?
  #36
Old August 15th 13, 07:03 PM posted to rec.aviation.soaring
My view of start strategy, which disagrees with TT:
A start out the top is always the most efficient. Any start out the side will necessarily be less than MSH unless you're really lucky to have a thermal right near the edge. If you start out the top, you are at the maximum energy you can get.
If the thermal is at least as strong as what you'd take on course at similar altitude, keep going. (To find such thermals, it's best to scout 1000' below MSH, so you can effectively core it and evaluate it before hitting the top. That also avoids all the gaggles we've been talking about.)
Most of the time, MSH is near the top where thermals are weak. In that case, just poke your nose above the top enough that you're sure you have a fix up there and head off on course. (A logger with altitude display is helpful, your altimeter may be 200 feet off) It doesn't matter if you sink back in the start cylinder, you've marked a start at maximum possible energy.
Start location should be at the upwind part of the start semicircle. A lot of people miss this. If your first leg is cross wind, all the way to the upwind edge is the best place to start. If your first leg is downwind, poking out the top in the middle of the cylider is the best place to start.
Of course, lining up with clouds, ridges, or gaggles is helpful too.
John Cochrane
  #37
Old August 15th 13, 09:21 PM posted to rec.aviation.soaring
Papa3[_2_]
TT
Hi Tim,
Not to hijack the thread, but I'm not sure where/how you determine that "at most sites [starting out the top] is not that important." Looking at some of my best performances at Cordele and Mifflin, it's been due to nailing a corker at the start and climbing at 5 knots to 1500-2000 feet above the top, allowing me to bypass the slow gaggle and catch up to some of the faster guys. I ran some numbers that showed only a 2kt (already centered) improvement in the climb was worth the time "penalty". Is there something I'm missing.
Curious in Jersey (P3)
  #38
Old August 15th 13, 10:46 PM posted to rec.aviation.soaring
Tim Taylor
TT
Hi Tim,
I agree with John about starting, so not saying that starting out the top is not better most of the time. What I was saying is grinding around at 300 below the top for an hour is not worth it to find that one that pops you out the top if the group you want to start with has gone out the side 45 minutes earlier.
If you find a good thermal out the top take it, but in eastern conditions you usually don't go that much higher over the top versus someplace like Parowan where you may climb 6,000 to 7,000 feet over the top. In general the distance between thermals is inversely proportional to the strength and height. If the thermal strength is 3 knots in the gate you are likely to find others pretty close by unless there is some blue hole or change in terrain in the direction you are going to go.
Kirk, you are correct in western sites like Air Sailing if you start on the western side of the cylinder and have to go south getting a good climb out the top is important.
In general, the top of the cylinder is set to allow all pilots to reach the same height after fifteen minutes from last launch and to be below the cloud base so they aren't tempted to cloud fly or get conflicts in the mist below the clouds. Other parameters can come into play in setting the top, such as how high the lift is likely to go in the cylinder and the probability of many thermals reaching that versus the rare thermal or odd wave over the clouds. When I have been CD or on task committees we have always tried to set the top as high as practical so that everyone gets a fair start and has a good chance to either climb out the top or reach the next lift from the start height.
If the lift is above the MSH I tend to hang out higher than the top until I am ready to start, drop down to about 500 to 1,000 below, core a thermal and climb out the top. At Logan, I try to start out the side at or slightly below the top because unless it is a 10 knot thermal the average speed on task most days on the first ridge run is faster than can be achieved by climbing.
Back to the original concern, there is very little reason to sit around grinding with the gaggle for an hour unless the maximum thermal height is lower than the MSH and even then if there are a few thermals around I tend to go someplace else until I am ready to start to conserve energy.
  #39
Old August 15th 13, 11:50 PM posted to rec.aviation.soaring
Tim Taylor
Sorry, it should have said "proportional" to the strength and height, not inversely.
  #40
Old August 16th 13, 05:47 PM posted to rec.aviation.soaring
Sean Franke
On Tuesday, August 13, 2013 12:07:26 PM UTC-7, wrote:
Having thought long and hard about this for many years, I'm curious what alternative you guys would prefer.
Unlimited altitude start? Then on blue days you absolutely have to sit with the gaggle for 20-30 minutes to get that last 500 feet. Or, everyone goes off into the clouds (demonstrated fact). It can also be remarkably unfair, when early takeoffs find thermal wave or it takes a long time to get to start altitude.
Limited altitude, no 2 minutes, a la IGC? Back to VNE dives. Or VNE dives after orbiting up in the clouds, a la IGC.
The current system has the advantage that you don't have to do any craziness for competitive reasons. If the max height is set sensibly low enough, as the rules suggest, then orbit above or away from everyone else. When it's time to start, return to the cylinder, climb up and go. Or better yet, stay below, well away from the nutty gaggle, and climb out through the top.
"Start anywhere" adds to the options as you get credit for distance flown and can more easily choose to avoid the big gaggle.
I grant many people still do some silly things, like orbit just below MSH in a big gaggle for half an hour. They don't have to, but they choose to and it's not great.
Still, let's hear a better alternative.
John Cochrane
BB, I'm trying really hard not to get drawn in this again.
Do you think VNE dives and orbiting up into clouds is old school IGC? I haven't experienced that in the last two WGC's. Max height was set a bit above maximum expected altitude. No need to dive. Is it really a problem? Anomaly?
Cloud flying is prohibited under US rules and IGC. At the last WGC gliders were thermalling right near the home field where prohibited before the start. One day the organizers said if you do it from now on there WILL be a penalty. They sent up an observer every day after. Interesting, pilots stopped thermalling right where prohibited. Seems to me if you don't want cloud flying then enforce the rule.
Sean R Franke
Junior World Championships - FAI Rules Absurdity Kevin Christner Soaring 37 August 15th 13 09:46 AM
SSA Rules Poll and Rules Committee Election Ken Sorenson Soaring 2 October 6th 06 03:27 PM
US Rules Committee Election and Rules Poll Ken Sorenson Soaring 1 September 27th 05 10:52 PM
FLASH! U.S.A. Rules Committee to Address Rules Complexity? SoarPoint Soaring 1 February 3rd 04 02:36 AM
New SRA Site - New 2003 Rules Minutes and 2004 Rules Summary Ken Kochanski Soaring 0 December 17th 03 03:38 AM
