Butterfly
Old September 4th 13, 07:07 PM posted to rec.aviation.soaring
jfitch
Default Butterfly
On Tuesday, September 3, 2013 8:36:08 AM UTC-7, glidergreg wrote:
I have flown with one since the spring in combination with an Oudie,it replaced a a L-NAV/GPS-NAV system. Although it fits the smaller 67mm panel hole it's front footprint is almost the size of an 80mm instrument. I would recommend placing it in a 80mm hole using a reducer ring. The instrument is very daylight readable, functions as advertised except for the wind info. Maybe I have a defective ISU too as was posted by someone else. I bought it as it seemed to be the most advanced instrument on the market since I was doing a major panel upgrade. The Flarm data from a portable flarm unit passed through the Butterfly to a NEMA interface box and then onto the Oudie display. It actually showed the flight path of other gliders near me right on the Oudie moving map. Very useful. The Flarm display on the Butterfly is of little value except as a secondary backup display. Voice warnings work very well however. This device is more expensive than others but not all that much more. Good support from the manufacture too. email or call if you want more info. 847-922-1234 USA
On Tuesday, August 27, 2013 7:59:06 PM UTC-5, wrote:
Hello
The Butterfly vario was advertise has a revolution, well almost, on the market.
Is there any pilots using the Butterfly vario who care to comment on the advantages,if any, of this instrument? I am serously interested in acquiring
one but it as to be better than my LX 7000.
Thanks for your input.
Gilles
What problem are you having with wind? Was the ISU installed per the manual? Yeah I know this is almost impossible, just wondering if you have obvious sources of EMI near the ISU?
  #32
Old September 6th 13, 01:08 AM posted to rec.aviation.soaring
glidergreg
Default Butterfly
Hello
Gilles
Butterfly iGlide App now available in the US Marc - Butterfly Avionics Soaring 25 June 2nd 14 08:10 AM
Butterfly Vario IGC Richard[_9_] Soaring 3 April 3rd 13 03:24 PM
Butterfly iGlide Reed von Gal Soaring 4 May 2nd 12 06:00 PM
New Butterfly Vario Paul Remde Soaring 238 February 20th 12 04:05 AM
This Just In- Butterfly [email protected] Soaring 6 February 17th 12 09:00 PM
