Best cross country ship class
Old October 15th 13, 10:29 PM posted to rec.aviation.soaring
Seattle
Default Best cross country ship class
I'm in the market for a standard class or 15 meter flapped ship. This is my first ship, and I doubt I want to deal with 18 m of wings.
An example would be a Discus 2 vs ASW 27. Currently most of my flight goals are simple: get as high up, and far out as possible. Speed is nice, but I'm doubtful I'll be comfortable in a competition for many seasons.
All other things being equal, which is the better type (flapped or non-flapped) for staying up a long time and, eventually, cross country flights?
Thanks!
Old October 15th 13, 10:52 PM posted to rec.aviation.soaring
It's like stick shift vs. automatic. No significant performance difference unless you are a pro. Most of the time your flap settings will inevitably be sub-optimal, but it is fun to fool yourself that you can go a wee bit faster.
Thanks!
Old October 15th 13, 11:07 PM posted to rec.aviation.soaring
BobW
flights?
Thanks!
Remember Bill Murray in "Meatballs"? (It doesn't matter. It just doesn't
matter. It REALLY doesn't matter!!!...)
"Pilot, know thyself!" applies, e.g. your comment, "...I doubt I want to deal
with 18 m of wings" suggests to me you're pondering these sorts of aspects. In
performance terms, there's no practical difference between flapped/unflapped
15-meter ships, for where you are on soaring's grand and endlessly long
learning curve (hence the Bill Murray reference)...and there won't be for
years, if you're "a typical human glider pilot." (You'll know if and when
you've reached "the detectable performance difference" stage.)
Find something within your budget and geographic convenience parameters, in
which you can fit, that has "a decent trailer" (your definition), have someone
more knowledgeable than you co-inspect it and its paperwork if you wish, buy
it, and then go and have even more fun than looking for it was!
Lettuce know what you eventually get!
Bob W.
Old October 16th 13, 01:19 AM posted to rec.aviation.soaring
Craig R.
Perhaps a better movie analogy would be "show me the money!". Your choice in gliders will be dictated by how much you want to spend on one. Once you have a dollar figure in mind, you can narrow down your options.
Craig
Old October 16th 13, 04:53 AM posted to rec.aviation.soaring
Craig,
I hear you. However, I can pick a budget of $30k and usually pick between a flapped and non-flapped (flapless?) for close to that budget. The same seems true for $50k and $70k.
Based on the replies, now I'm trying to understand why anyone bothers to make flapped sailplanes if there is no measurable difference in having them...
Old October 16th 13, 05:50 AM posted to rec.aviation.soaring
In my experience owning various flapped and unflapped gliders, with flaps, you have a better view over the nose and can make a slower approach than is typical of equivalent unflapped gliders. If you always land at airports, it won''t make much difference, but I made my share of mistakes while learning cross-country flying, flaps saved my bacon more than once. I also found it advantageous to crank in full thermal flap (and sometimes more) when climbing full of water in the kind of small tight cores we sometimes need to deal with out here on the west coast. And, if you're cruising at 90+ knots with water, negative flaps do make a noticeable difference.
On the other hand, the work load in a flapped glider is noticeably higher than without flaps, for that reason alone I'll probably do without in my next glider...
Old October 16th 13, 02:18 PM posted to rec.aviation.soaring
kirk.stant
On Tuesday, October 15, 2013 10:53:11 PM UTC-5, wrote:
Based on the replies, now I'm trying to understand why anyone bothers to make flapped sailplanes if there is no measurable difference in having them....
Well, when you top out that last thermal with a good final glide home, it sure is nice to push the flaps up and walk away from your buddy in his un-flapped glider...
Seriously, there is a small but significant difference in performance with flaps. But it depends a lot on where and how you fly - Eastern US, fun flying, not so much (except on the ridge?). Out West, racing or pushing hard, it can be significant. Same can be said about water - both are a bit addictive when sampled in the right conditions (120+ knot final glides, for example!)
For some, the slower landing speed of flapped gliders is appealing.
Me, I like having something useful to do with my left hand!
Kirk
66
LS6-b
Old October 16th 13, 03:05 PM posted to rec.aviation.soaring
Good feedback.
So, I'll run this by my CFI-G and some more of my club mates.
Here is where I am now:
Discus 2b
ASW-27
a distant third: SZD 55-1
long shot: DG 303 Elan (this is probably a DQ due to A/D spar issue)
In my research, it has become clear that the Discus is pretty much the best standard class you can get.
For the 15m class I like the ASW for some reason, even though the Ventus 2 seems to win many more championships.
I'm open to comments and advice from all, especially if you have flown any of these ships. I'm going to make a buy decision in the next week or so...hopefully.
Thanks for the help!
Old October 16th 13, 09:11 AM posted to rec.aviation.soaring
Jim White[_3_]
nice,
flights?
Thanks!
Had both. Flapped gliders are more complicated than standard class gliders.
If you want to learn cross country flying then there is plenty to be
getting on with without the complication of flaps. You are also more likely
to make good field landings in an unpowered unflapped glider.
IMO best first gliders are either LS4/8 or Discus. These types have very
good performance, are strong, reasonably priced, and are great platforms
for developing your cross country skills. When you have done a few 500s you
can then trade up to a 15M or 18M class ship and push further and faster.
Old October 16th 13, 09:16 AM posted to rec.aviation.soaring
Justin Craig[_3_]
All the reply's you have had are really relevant, in the short term you
will find it easier to get the performance out of a non flapped glider,
however flaps are a bonus especially in strong conditions.
I fly a 27 and absolutely love it. It has no real vices and is easy to
handle and goes very well. You will get to grips with the flaps quite
quickly, but it will take a little longer to get the best out of it.
I am also lucky to have about 300 hours in an LS8 which is also a stunning
glider, however when I get into the LS8 now, I really miss having the
flaps.
Flaps.....push the handle forward = go faster......pull it back = slow
down.
Forgive me if this is a simplistic view, but they are really not difficult.
In summary, I guess what I am saying is that you will be happy for a very
long time in a 27. If you can afford a 27...go for it and have fun.
JC
nice,
flights?
Thanks!
Cross Country Miles Bill[_22_] Soaring 17 September 8th 12 02:36 PM
Cross Country again! Michelle Piloting 10 August 6th 06 06:45 PM
Our first IFR cross-country trip: NY-MI-IL-MI-NY Longworth Piloting 16 July 15th 05 08:12 PM
Cross country in the 1-34 mat Redsell Soaring 3 October 22nd 04 04:56 PM
A 4,200 NM cross-country Phil Verghese Piloting 0 September 1st 03 10:03 PM
