Does anyone use a tug tow hook that releases automatically whenglider kites?
Old February 19th 14, 07:23 AM posted to rec.aviation.soaring
Surge
Default Does anyone use a tug tow hook that releases automatically whenglider kites?
On Tuesday, 18 February 2014 12:07:20 UTC+2, Chris Rollings wrote:
That might work but I suspect it would be impossible, in the real World, to
get a sufficiently high degree of reliability that we did not get more
accidents from innocent gliders be jettisoned at low altitudes than we
currently get from kiting accidents.
Hi Chris
This is not a personal attack - I appreciate your valuable input but ...
With modern technology we can reliably detect pitch, roll, acceleration of a tug plane IMO.
e.g. My Note 2 has a magnetometer, electronic gyros, accelerometers, barometer, and GPS. I downloaded an artificial horizon app for my Android phone and when it blends all the sensor data you get a very reliable pitch and roll output.
It doesn't even experience gyro drift because it is able to compensate using the magnetometer to sense gravity.
Another example are all the Ardupilot projects.
If they are capable of flying DIY autonomous drones around for under $300 then I think the technology is available and good enough for us to use.
Even so, I'd rather have a 1 in 1000 chance of accidentally being dumped than kill a tug pilot and myself through a momentary lapse of judgement/attention.
I happen to fly at the club in South Africa which had the low altitude, tug upset on Sunday 16th Feb 2014, resulting in the death of the tug pilot in a Cessna 182A.
I simply refuse to believe that we can fly to the moon and back but can't devise a reliable automatic tow release mechanism.
How many more tug pilots around the world do we have to kill before we devise a mechanism which works?
To detect a tug upset reliably I think one would only need:
1. To sense the tug elevator at the back stop +
2. The pitch of the tug (say 20 degrees down and increasing) +
3. The load on the rope (glider still attached).
I can't imagine the above being present in any normal operational situation.
Paul
Old February 19th 14, 07:43 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
Default Does anyone use a tug tow hook that releases automatically when glider kites?
World,
to
Hi Chris
of
a tug plane IMO.
pitch
and roll output.
tug
a
Cessna 182A.
situation.
Paul
Paul, by the time your items 1, 2 & 3 are present it is probably too late,
the tail-plane is almost certainly stalled and even if the glider were
jettisoned at that instant, the tow-plane would probably still pitch down
another 40 or 50 degrees before recovery (I say probably, could someone
please test it with a camera plane alongside at safe altitude, done
deliberately it should be possible to pull the release at exactly the right
moment - might take three or four goes to get on exactly right).
The thing that is constantly under-estimated by those that haven't
experienced it is how quickly it all happens. LESS THAN 3 SECONDS FROM ALL
NORMAL TO ALL OVER. People take at least that long to react to something
unexpected unless it is something they have practiced frequently, certainly
not the case in kiting incidents.
Old February 20th 14, 12:36 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
Chris has hit the nail on the head with his testing and reporting. When it goes wrong, it goes wrong fast. Faster than you can possibly react. We can try all we want to teach how to not do it, but it will sometimes happen. Why not come up with a system that will minimize the risk to the towpilot? I think we have concluded that for now, we cannot eliminate it without creating other significant problems.
If we are considering an automatic system, why wait to full nose up elevator and nose down 20 degrees? As Chris said, if you are there, you are probably doomed. If the nose is down 10 degrees (or maybe even 5?) and the elevator is half way to full up, something is wrong. Would you agree? On tow, elevator is up, nose is up. On descent, elevator is down, nose is down.
Why not develop and test a parallel releasing system that has inputs from a gyro for pitch attitude and a simple sensor for elevator position? Test at safe altitude, as Chris and company did. I know this is not going to prevent kiting, but if we can reduce the risk when it happens and maybe not even add bad failure modes, it should be well worth the effort.
Just my thoughts.
Steve Leonard
Old February 18th 14, 10:03 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
At 17:41 17 February 2014, SF wrote:
If this was an industrial control problem. I would try two things.
1: Mount a Tost CG release on the tow plane upside down and at an angle
whe=
re the upwards angle of the tow rope would initiate a back release. The
an=
gle required, reliability, tendency for unintended operation,and whether
or=
not this would actually work, to be determined by testing. Based on
somet=
hing like this that was attempted and reported on here earlier, I have a
lo=
w confidence in this scheme working out.
We actually tried exactly that as our first attempt (can't remember now if
it was a Tost or Ottfur Hook we used, but they are much the same anyway).
It didn't work because, as I said, the "kiting" departure is caused by the
upward component of the pull on the rope, not the upward angle. If a light
weight single seat glider is flying in steady flight behind the tow-plane
at about 60 knots the tension in the rope is only a few 10's of pounds. If
the glider is pitched 45 degrees nose up the tension in the rope is about
700 - 900 lbs. In the first case, the glider being high enough that the
rope angle is 30 degrees upwards is easily containable by the tow-pilot, in
the second case he is pitched 70 degrees nose down in less than 2 seconds.
2: Using a TOST release, add an electric solenoid activation device
somewhe=
re in the cable run to the release. The solenoid could be activated by a
full back stick" limit switch and a short time delay circuit on the tow
pla=
ne, the normal manual pull handle in the cockpit, or a switch on the
stick.=
"...A short time delay circuit...." The whole sequence from everything
normal, to tow-plane 70 degrees nose down and destined to lose about 400
feet, takes less than 3 seconds.
On most tail-draggers (= many/most tow-planes currently in use), it's
normal to bring the stick fully back shortly after touch-down, be tedious
to have to go and find the rope after every tow.
Again, testing would have to be done to confirm that this scheme would
ac=
tually work.
I have no idea how any of this could be accomplished given it's an
airplane=
and the FAA is involved. Their requirements are baffling to someone
that
does not live in that world.
Ultimately, taking the human element out of the equation could prove
imposs=
ible. The cure being worse that the disease is also a real possibility
due=
to unintended consequences. However we have always done it this way,
isn't=
a good answer either. =20
Old February 18th 14, 06:48 AM posted to rec.aviation.soaring
Another fatality on Sunday in South Africa - with a Cessna glider tug crashing just on the initial part of the flight. Eye witnesses seem to have seen the glider (Ventus CM) kite and force the tow plane into the ground. A very experienced tow pilot and gliding instructor will be sorely missed by the gliding community.
Here is the link to the active thread on the AvCom site regarding this incident including the eye witness account. Registration on the site will be required to view the topic. http://www.avcom.co.za/phpBB3/viewto...p?f=9&t=130916
Whether an automatic release would have saved the plane and pilot can be speculated but its certainly worth investigating if it will save lives from being lost in this type of accident.
Clinton
Old February 18th 14, 08:17 AM posted to rec.aviation.soaring
Pieter Oosthuizen[_2_]
Not an 'auto release', but some info from this document :
http://www.glidingmagazine.com/pdfs/...20Rollings.pdf
"That of course is the reason that attempts to produce a hook that released
if an certain angle was
exceeded were unsuccessful. The quite small angle needed to trigger
the“Kiting”when the
glider is pitched significantly nose-up is not much greater than the amount
of out of position
commonly experienced in turbulent conditions. We did build an experimental
hook and tried it,
but, set to an angle that prevented“Kiting”it occasionally dumped an
innocent glider in
turbulence, and set to an angle that prevented that, it didn’t prevent
the“Kiting”. What was
needed was a hook that responded to the vertical component of the load, not
the angle at which it
was applied, and that problem we decided was beyond us (at least in a form
robust and foolproof
enough to be attached to the rear end of a tow-plane)"
Solved by
"We solved that problem on our tow-planes by replacing the bolt that the
hook latches onto with a
small roller bearing. So far as I know, no one has tested the Schweitzer
hook as fitted to a glider,
but I would not be surprised if it exhibited the same characteristics at
high loads."
http://www.facebook.com/KranskopGliding
Old February 18th 14, 10:30 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
That didn't solve the Kiting problem, merely made it probable that the
release would still be able to be operated when the rope was under very
high tension. It remained the opinion of all involved that in a real,
accidental Kiting incident, there was effectively no chance that either
tow-pilot or glider pilot would re-act in time to release before it was too
late.
released
the“Kiting”when the
amount
of out of position
experimental
hook and tried it,
innocent glider in
not
form
Solved by
high loads."
Old February 18th 14, 11:54 AM posted to rec.aviation.soaring
Thanks Chris - appreciate your comments!
Apologies if I interpreted it incorrectly.
PO
too
late.
released
the“Kiting”when the
amount
of out of position
experimental
hook and tried it,
innocent glider in
not
form
Solved by
high loads."
Old February 18th 14, 01:17 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
PO
I think Chris has made it pretty clear that the fitting of an automatic
system is not at this time a practical solution. I think he has also made
it pretty clear that once the sequence starts the result, as far as the tug
is concerned, is inevitable.
This is one of those situations where tug pilots are going to have to
decide what risks they are willing to take. I would support any tug pilot
who said that he would not tow a glider on a CoG or Compromise hook. On the
other hand I would not tell him he could not do it. There is also a
responsibility for those of us who teach aerotowing to really get across to
students the danger, to the tug pilot, of getting out of position. I am not
sure we have done this in the past, I know I have not been as pedantic as I
should in getting this point home.
Tug pilots do not always know the people they are towing so they are
perhaps not aware of the experience, or lack of it, of the pilot on the
back. In those circumstances the saviour should be the authoriser. We all
know that does not work. Perhaps tug pilots need to be more circumspect in
who they are prepared to tow.
Old February 19th 14, 11:42 PM posted to rec.aviation.soaring
son_of_flubber
On Tuesday, February 18, 2014 1:48:05 AM UTC-5, wrote:
Here is the link to the active thread on the AvCom site regarding this incident including the eye witness account. http://www.avcom.co.za/phpBB3/viewto...p?f=9&t=130916
Based on what was posted on that link, the pilot of the glider was expert, current, and flying a modern glider.
inReach website not updating track automatically Eric Greenwell[_4_] Soaring 4 September 23rd 13 09:59 PM
Compare/Contrast: CG hook on aerotow vs. CG hook on winch son_of_flubber Soaring 37 June 4th 12 10:40 PM
TOST E85 RELEASES [email protected] Soaring 2 March 6th 05 04:21 PM
Cumulus releases version 1.2.1 Andr Somers Soaring 0 March 2nd 05 09:58 PM
NSA releases EC-121 Liberty tapes: no smoking gun Mike Weeks Military Aviation 0 July 9th 03 05:06 AM
